View Poll Results: What is the weight of your 250?
less than 320g 58 18.13%
320g to 340g 105 32.81%
340g to 360g 92 28.75%
More than 360g 67 20.94%
Multiple Choice Poll. Voters: 320. You may not vote on this poll
Old 03-17-2010, 08:45 PM   #81 (permalink)
Well, guess it's my turn to "weigh in"
T-Rex 250SE
Stock motor
Stock ESC
Aluminum boom block
CF Boom
CF pushrod
Aluminum bellcrank on t/r
Small stock "bat wing" t/r blades
Align Carbon blades
JR DS290G tail servo
Stock GP750 gyro
Stock Canopy
Outrage 860mAh battery
Total weight: 343g.
Joe
T-Rex 250 SE w/Walkera 2801 radio. alloy boom block, CF boom, alloy servo mounts, CF pushrod, alloy t/r bell crank, JR DS290G, Kevlar t/r belt, 40mm KBDD t/r blades, Titanium turnbuckles.
HeloJoe is offline        Reply With Quote Quick reply to this message
Old 03-23-2010, 03:39 AM   #82 (permalink)
Wink
Here we go. Mine weighs in at 358 grammes
Tarot 250
GE power 850 mah 20 C batts
TowerPro Cyclic servos
Align DS 420 tail servo
KDS 800 Giro
Hobbywing 18 amp ESC
Hobbymate HS2625 motor
Walkera RX2801E rx
Tarot CF main blades
Few extra metal pieces, Main shaft bearing blocks, ARB, tail boom brace, tail brace holder
Turnbuckles
Thanks Phill
babber411 is offline        Reply With Quote Quick reply to this message
Old 03-27-2010, 01:57 PM   #83 (permalink)
360g all in, Mine is a 250se Super combo
Has CNC upgrades
MH bottom plate
CF tail control rod
CNC main bearings
CNC battery mount
CNC tail bell crank
Carl
Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544
Starcruiser is offline        Reply With Quote Quick reply to this message
Old 03-28-2010, 10:41 AM   #84 (permalink)
It's a pleasure to finally be able 'weigh' in on this thread.
Here's what mine comes in at:
- T-Rex 250SE
- Stock motor & ESC
- JR g270 gyro
- JR ds290g tail servo
- JR 287mg cyclic servos (3)
- Spektrum ar6110 receiver
- 205mm non-tapered CF blades
- Outrage NRG 860mAh battery
- Everything else is stock
Total weight: 330g.
Prtos 500, Nano CPx
exit44rc is offline        Reply With Quote Quick reply to this message
Old 03-30-2010, 11:22 AM   #85 (permalink)
T-Rex 250SE
DS410M Cyclic
Stock Motor and ESC
JR 3500G Tail Servo
All the Aluminum Bling
Flightmax 1000 25C 3S
Fully loaded 390g
riccardoc is offline        Reply With Quote Quick reply to this message
Old 04-04-2010, 05:12 PM   #86 (permalink)
Default Guess mine's a fatty...
I get 342g with a Hyperion CX G3 Batt and both securing straps.
If it's too nice to throw around, SELL IT!
Blade-T-Rex-Tarot- 450 and under-DX6-AMA#977655
intro is offline        Reply With Quote Quick reply to this message
Old 04-06-2010, 04:57 AM   #87 (permalink)
Default T-REX 250SE Super Combo
My little guy weighs in at 339 grams. Using the Outrage 860mah pack, carbon fiber blades and the rest is stock.
I am curious to know the procedure you guys are using for shortening your servo wires? Are you just cutting off the extra and soldering in the middle of the wire and then using heat shrink or are you taking the receiver apart and resoldering there? I want to shorten my wires but want it to look good after. Help is appreciated.
starrant is offline        Reply With Quote Quick reply to this message
Old 04-06-2010, 05:49 AM   #88 (permalink)
I bought a crimp tool and a pack of spare male and females plugs. Cut to length and refit with a new plug. I personally think it's looks better than cutting the leads and then resoldering.
In fairness both solutions work.
Thanks Phill
Old 04-08-2010, 10:47 AM   #89 (permalink)
I fed my T-Rex 250 toooooooo well.
Used to be 310g when I ran 2s1p
Now she's 352g AUW after upgrades and running a 1000mAh 3s Lipo
QueadlunnRau is offline        Reply With Quote Quick reply to this message
Old 04-16-2010, 05:45 PM   #90 (permalink)
Default 330.08 grams
T rex 250-stock airframe
stock tail blades,align carbon fiber tapered main blades
stock align motor,esc,servos
spartan quark
outrage 860 mah 35c 11.1 lipo
spektrum 6110e rx
330.08 grams.
geral is offline        Reply With Quote Quick reply to this message
Old 04-19-2010, 09:30 AM   #91 (permalink)
Originally Posted by starrant View Post
I am curious to know the procedure you guys are using for shortening your servo wires? Are you just cutting off the extra and soldering in the middle of the wire and then using heat shrink or are you taking the receiver apart and re-soldering there? I want to shorten my wires but want it to look good after. Help is appreciated.
I am wanting to do the same, need to get the connector kit and crimpers. I would like to reduce my 250's weight but also like to rid my heli of the long wires I do not need.
Carl
Old 04-21-2010, 11:44 PM   #92 (permalink)
353g.
800mah 20c lipo
EXI (D231F) cyclic servos
Raiden DMA-016 tail servo
MKS 292 gyro
I have some carbon fiber landing gear coming soon, should take off a bit weight. looking for a lighter tail servo as well. anyone have a suggestion?
Mr dan is online now        Reply With Quote Quick reply to this message
Old 04-22-2010, 09:17 PM   #93 (permalink)
250SE is 341 grams with 850ma Hyperion battery and JR DS290G tail servo and carbon blades. Everything else stock.
I fly this for a while and it makes the 450 and even the B400 seem easy to fly.
JW
New England Heli Crew www.Nehelicrew.com
MCX, CX3, B-400 w/500E Fuselage, MCPx(2X), TREX450(2X),TREX250, TREX550FBL, HK600(2X). Almost forgot - Ikarus ECO-8. Yea, I'm a junkie.
weng is offline        Reply With Quote Quick reply to this message
Old 04-27-2010, 01:30 PM   #94 (permalink)
JW
I noticed the same, Fly the 250 for several paks and then the 450 seems tame.
Carl
Old 05-01-2010, 03:14 AM   #95 (permalink)
355.88 grams.
250se super combo kit, Align 850 mAh 30C battery
Robin.
rritchey is offline        Reply With Quote Quick reply to this message
Old 05-02-2010, 03:18 PM   #96 (permalink)
mine is 240 gr w/o lipo and 312 with it (align )
KABAL99 is offline        Reply With Quote Quick reply to this message
Old 05-03-2010, 10:33 AM   #97 (permalink)
349.7 800mah battery some type of all plastic landing gear im trying out, all cf blades and pushrod. Align servos, gaui tail servo. Gy520 gyro. Align motor /esc, walkera rx
Mikegigabyte is offline        Reply With Quote Quick reply to this message
Old 05-04-2010, 06:28 AM   #98 (permalink)
356 grams
Align 3G and FBL head
Align 850 20C batteries
Hitec 5084 on tail.
DS 410's on cyclic
Futaba 608FS Rx
It is jam packed with every upgrade Align make except metal main bearing holders (getting swapped out next time I kill the heli).
Mick
aussiemick is offline        Reply With Quote Quick reply to this message
Old 05-05-2010, 03:01 PM   #99 (permalink)
I don't think shortening a few wires is going to help here! Box stock late model 250 super combo. An extreme 469 grams (16.5 ounces) with Align MD500 fuselage and 1000 mAh 3S. I normally fly about 6 minutes for safety but indoors I've hovered and flown gently up to 9 or 10 minutes a few times. I'm amazed that it flies as well as it does given the weight, see this thread. To help with the CG I made a forward extension of the floor from ply which replaces the front mechanics mount and allows the battery to sit well forward in the canopy (see pic) If anyone really wanted I could provide a drawing of this, see CAD model (I'm a Design Engineer!).
Andrew
ID:	155078   Click image for larger version
ID:	155088   Click image for larger version
ID:	155089   Click image for larger version
Name:	TRex 250 Assembly.JPG
CAndrewGreen is offline        Reply With Quote Quick reply to this message
Old 10-07-2010, 11:55 PM   #100 (permalink)
mine weighs 373 grams with lipo
It majorly needs some form of weight loss management.
pitchp is offline        Reply With Quote Quick reply to this message
