View Poll Results: What is the weight of your 250?
less than 320g 58 18.13%
320g to 340g 105 32.81%
340g to 360g 92 28.75%
More than 360g 67 20.94%
Multiple Choice Poll. Voters: 320. You may not vote on this poll
Old 10-08-2010, 09:48 AM   #101 (permalink)
Originally Posted by pitchp View Post
mine weighs 373 grams with lipo
It majorly needs some form of weight loss management.
wow, I just weighed mine, now mind you, it has the bigger of the scorpion motors, full metal & all the ya ya, it's only 345g
This flying machine thang may be an illness like Alcoholism. If there isn't a support group yet someone should start one...
Current addiction: Align 250, 2x 450s, 500,12s 600e, 700e CX2 and several 3D planks.
AviatorsAnonymous is offline        Reply With Quote Quick reply to this message
Old 10-08-2010, 01:45 PM   #102 (permalink)
253g less battery
weaselbean is offline        Reply With Quote Quick reply to this message
Old 10-09-2010, 03:15 AM   #103 (permalink)
3S? what's the headspeed on that?
pitchp is offline        Reply With Quote Quick reply to this message
Old 10-09-2010, 09:35 AM   #104 (permalink)
Yes, 3s.
I don't know the headspeed, went to test just now and the 9V batt in the meter is dead. Sorry.
It's the 2208 Scorpion motor w/ a kv of 3600, I don't remember which pinion I used...I think it was one from the Garbage 200
Old 10-09-2010, 06:54 PM   #105 (permalink)
Default copterX 250 net weight
I just received my unassembled version in the mail this morning, and am slowly
assembling it (by putting loctite everywhere).
Without any electronics, my copterX weighs in at 151g (quite a bit heavier
than the advertised 138g).
The quality of the kit is so-so, the tail has very little slop as far as I can tell, but
unfortunately one of the tail blade grip is slightly defective (I think the hole
for the bearing is drilled at an angle, so the bladegrip isn't parallel to the
other blade, we'll see if it'll cause excessive tail vibration.
The stock pinion seems to be for a 2.5mm shaft as it has lots of play
on my tonic-X (zpower) 2.3mm shaft, but nothing a little epoxy/CA won
t fix :-)
mayday1 is offline        Reply With Quote Quick reply to this message
Old 10-12-2010, 11:12 AM   #106 (permalink)
^Mine was a CopterX, terribale quality, it's 3/4 align now. Only thing left CrapterX is the Frame, a 1/2 the tail and 1/2 the head.
Lincoln
#HIGHONHELIS ):>
Pull Hard
RCHO Flying Field, Knightdale NC
lazor 22 is offline        Reply With Quote Quick reply to this message
Old 10-12-2010, 12:13 PM   #107 (permalink)
you ever add up all those align parts, probably cheaper to buy the whole trex then upgrade the copterx
Mikegigabyte is offline        Reply With Quote Quick reply to this message
Old 10-12-2010, 12:41 PM   #108 (permalink)
Yep, I have, it's almost twice the price. And I also just found out I have to spend $40 to get a Align tail now, cause the control arm on it snapped and you have to buy the whole Align tail because CrapterX did some dumb design that isn't compatibale with Align (probably the .1% in there 99.9% claim)
Lincoln
#HIGHONHELIS ):>
Pull Hard
Old 10-12-2010, 12:42 PM   #109 (permalink)
Oh, and my 250 is insecure about it's wait, so I'm not allowed to post it, sorry.
Lincoln
#HIGHONHELIS ):>
Pull Hard
Old 10-19-2010, 06:34 PM   #110 (permalink)
mine is a FBL 250 SE with sk720
mine is 379.9 grams
micro heli head with frame brace
skorpion 3900km motor
skorpion 25A esc
cc bec
fiber glass blades
blue lipo 20c 800mah lipo
cf tail boom
Trex 700E DFC V-Bar , Trex 600N , Logo 600 SE FBL V-bar, Logo 600/550 FBL V-bar,Logo 400 FBL V-Bar ,Goblin 500 V-Bar, Blade 130X , Blade MCPx , Blade 500X
celm is offline        Reply With Quote Quick reply to this message
Old 10-19-2010, 07:00 PM   #111 (permalink)
This is my other 250, the build is almost in completion. So far her AUFW 353grams(3S 800mah 20C lipo included). This is a very very cheap setup. Designed HS @ 100 thottle just over 5600-5100. I am still in the process of trying to cut down her weight. My aim for this bird is AUFW 300 grams(Lipo 3S 800mah 20C included). The best I think i could do is 315-320 grams.
I also have another 250 but that weighs 383grams. [email protected] 100 throttle 4500-4400. I am also planning for another 250 5000-5100 HS. Weight is so hard to lose on these little birds.
Old 10-24-2010, 12:12 AM   #112 (permalink)
353g. HK250GT, Hxt(00 cyclics, DS480 tail, HK G401B gyro, Turnigy 2627 4200kv, Fusuno canopy, Nano-tech 850mAh batteries.
Brian's RC Corner
Flasher 500
HK-250GT
bwoollia is offline        Reply With Quote Quick reply to this message
Old 10-24-2010, 04:00 PM   #113 (permalink)
350grams. All stock, no boom supports/horizontal fin, R617 with case, Nano-tech 1000mAh batteries and counting much wire in excess
dk31 is offline        Reply With Quote Quick reply to this message
Old 10-28-2010, 06:18 PM   #114 (permalink)
367grams now, Since she's now using one of the latest PP blades, she's put on a couple of grams. But It's got a bit more pop.
T250 Specs:
Main Blades: PP Blades 4th Generation
Motor: Turnigy 2627 4500kv
Pinion: 16T
Tail Blades: PP Tail blades 3rd Generation (more tail authority)
ESC: HK30A
Lipo: Turnigy 800mah 3S 20-30C
Gyro: Assan GA410( plug and pray gyro)
Cyclics: HXT900s
Tail Servo: Turnigy DS480
Canopy: Ebay special $5
Just how deep does the rabbit hole go?
Old 11-06-2010, 12:37 AM   #115 (permalink)
Just finished building my copterX 250.
AUW 277.6 gr
Setup: tonic-x 4850kV motor (26 gr), 15T pinion
castle creation phoenix-10 ESC, heli fixed throttle mode, firmware a few months old.
turnigy nanotech 850mAH, 2S (49gr)
decased logictech 2100T gyro, wires shortened (7gr)
align ds-420 tail servo, wire shortened
hextronics hxt-500 cyclic servos, two with wires shortened (6.8gr, 6.2gr, 6.2gr)
spektrum ar6100 (v1.2), this is about 1 gr lighter than my 6100E, but it isn't v1.6 with
the quick reconnect firmware.
Servos seem too weak for the job, but we'll see how it goes when I maiden it.
ESC gets hot side of warm from less than a minute of spinning, so may overheat in actual flight.
Headspeed seem ridiculously fast, I nevered spun it up fully since the tailcase kept slipping.
Old 11-15-2010, 07:29 PM   #116 (permalink)
Aprox. 315g with my 65g Voltz packs I can only get aprox since my scale is analog but I guess that's a pretty low weight.
Lincoln
#HIGHONHELIS ):>
Pull Hard
Old 11-15-2010, 09:15 PM   #117 (permalink)
AUW 277.6 gr
You have a super kool setup. Will you be running it at 100% throttle? I am interested to know the flight time you would get with that lipo. The current one I have is on the 5500 HS no gov( I only get 3 mins flight time). I've put some cheap lighter paddles, the weight is just under a gram for each ( it really makes the bird boogie.). I'm using the turnigy 30A ESC, and it only runs warm, not hot like my 450. The next one(250) I am building, will be around the 6100+ HS similar to your AUFW. I'll be using the E-sky 8g digital servos($4 each). They work really well on my other 250. I use them on the cyclics and the tail. The tail is solid! Do you have any pics of the bird? Very nice setup.
Old 11-19-2010, 09:57 PM   #118 (permalink)
thanks, I was shooting for a low maintenance, somewhat crash resistant
heli, hence the low weight build. It now flies at 253g without canopy and 26X with
a bladeCP canopy.
My headspeed at 100% throttle 0 pitch is 4200rpm. But I've been flying at 70% at idleup
so I'm probably flying below 3500rpm. It has been a troublesome heli with parts flying
off at spinup and during flight until I found that the tail blades needed balancing. After
that it was much better. I crashed on my maiden because my aileron servo had a
internal short.
It has been my worst heli, but is rapidly improving as I get the problems sorted.
Old 12-05-2010, 06:10 PM   #119 (permalink)
I officially weigh in at 342 grams
Every aluminum upgrade I could find.
Sparten Quark/JRds290G
Align cyclic servos, I shortened the wires on all of these.
Scorpion Motor
Spectrum 6110 Receiver mounted at the rear inside the frames
Align Blades/Carbon
Canomod Canopy
KBB tail blades
Fusono Tail fins.
Stock Align ESC mounted under motor
Voltz 850 MAH 35C battery/s
Balance comes out a little nose heavy but not much. Kind of wishing I went with a JR 3500 tail servo but I think the 290G will be fine, at least for now.
Pistol Pete is offline        Reply With Quote Quick reply to this message
Old 12-05-2010, 06:47 PM   #120 (permalink)
dze
a bladeCP canopy.
internal short.
sweet! i didnt realize someone else ran theirs on 2S .. mine is flying great at a svelt 307.4g AUW -- my timer is set for 4 minutes, 3 1/2 minutes is better for alot of aero.
my setup:
-copterx250:
-align skids,boom, tailhouse, swash,shafts,washout base,plastic links,gears,bearings, bottom plate
-MH control arm/slider (nothing special the stocker was fine)
-align 205 carbons
-fusuno canopy
-850 2S hyperion
-tonicx 4850/15T @100%
-gaui18 esc
-exi D213 metal gear servos (heavy and required modding the mount ears and removing frame side to mount but the price and reliability was right haha)
-telebee gyro/ inolab201 analog servo (not so great but good enough for me)
dze is offline        Reply With Quote Quick reply to this message
