View Poll Results: What is the weight of your 250?
less than 320g 58 18.13%
320g to 340g 105 32.81%
340g to 360g 92 28.75%
More than 360g 67 20.94%
Multiple Choice Poll. Voters: 320. You may not vote on this poll
Old 07-04-2012, 07:43 AM   #161 (permalink)
Original version of 250 with FBL head - 348.5g with Voltz 850mAh 35C lipo and training gear:
- Tarot FBL head
- 250 pro main shaft
- DS410 cyclic servos
- MKS DS480 rudder servo
- carbon tail boom
- R617F receiver
- ZYX Gyro
- xheli $7 CF 195mm main blades
- all Align metal upgrade
Nano CPx, Hirobo Quark
250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar
450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540
465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE
lcc014 is offline        Reply With Quote Quick reply to this message
Old 07-24-2012, 01:19 AM   #162 (permalink)
I am at 334 grams, fully stock 250 Pro.
3x DS410 cyclic
DS420 tail
GP790
zippy compact 850mAh (great batts by the way)
Blade mSRX - Blade Nano S2 - Blade mCpx - XK K110 - Blade 150S - Blade 230S V2 - Blade 250cfx - Blade 400 - T-Rex 250 Pro DFC - T-Rex 450 PRO DFC - T-Rex 500 Pro DFC - T-Rex 550 DFC - A bunch of planks - Spektrum
gionir is offline        Reply With Quote Quick reply to this message
Old 08-04-2012, 06:15 PM   #163 (permalink)
I'm at 255g sans the lipo. My GA 3s 20c 800mAh lipos weigh 72g. All up weight (AUW) is 327g. Would have been under 320g with stock tail servo. The DS 95i is a bit of a pig but it works very well.
terrabit is offline        Reply With Quote Quick reply to this message
Old 08-05-2012, 04:43 AM   #164 (permalink)
Just finished 250 DFC combo (DS415m/425m) with AR7200BX and CC25 weighs in at 279g without lipo, with the Align 30C lipo this comes in at 351g flying weight, I don't understand how others are lighter when this is all stock stuff ?
My 250SE (DS410/420) with Align FBL head, AR7200BX, CC25, and some nose weight for CofG weighs 261g without lipo (333g flying weight with Align 30C lipo).
Weighing the SE vs DFC without canopy extra weight of the DFC TT/metal gear servos is 18g heavier.
jamesb72 is offline        Reply With Quote Quick reply to this message
Old 08-05-2012, 06:36 AM   #165 (permalink)
MBX: 20g, AR7200BX: 18.6g, 3GX: 11g. I also did away with the boom supports, mounting clamp and horizontal stabilizer, and shortened the servo and esc leads.
Old 08-05-2012, 07:49 AM   #166 (permalink)
Aaaah, OK I see, I think people should say this stuff when they give the weights, as I wasn't sure if my scales read high (or theres low), I can see removing stuff is going to reduce weight though !
Old 10-11-2012, 09:34 PM   #167 (permalink)
Smile
Mine is bang on 350gms with lipo.
Stock 250 DFC PRO with all wiring sleeved.
Weighed with a Turnigy 800mah 20-30C battery.
Trex family.....100, 450L, 550E 3GX. Goblin 770.Goblin 700 speed machine. Goblin 380.
JR X9503.
PHANTMXR6 is offline        Reply With Quote Quick reply to this message
Old 10-22-2012, 03:30 PM   #168 (permalink)
250 Pro DFC all stock servos, motor and ESC/BEC.
Weighs in at 359 grammes with a Turnigy Nanotech 850mAh pack, stock CF 205 mains, Futaba R6203SB RX and a BeastX Microbeast.
Gas Goblin 700 - Goblin 380
VBar Control - VBar NEO
Rubin RC - Gas Powered Helicopters - TRM Power
Matwes is offline        Reply With Quote Quick reply to this message
Old 11-13-2012, 03:22 PM   #169 (permalink)
270 grams AUW!!!!! 200 without the 1300 mAh 2s battery.
https://www.helifreak.com/showthread...18#post4446018
helihaven is offline        Reply With Quote Quick reply to this message
Old 02-22-2013, 02:04 PM   #170 (permalink)
just finished a se with gaui 3 blade head ,2s 1000ah nanotec zyx fbl hkscm9 servos
auw 340 grams ...mick
t250se 3blade head]t 250se fbl 250spmotor ,hitec 65hb cyclic gp780 giro mks 480mg /t250pro 250mx motor savox 257mg align g31 /ds 480mg tail/alzrc devil 450,kst 115mg cyclic/ds520 tail turnigy typhoon motor/yep 45a esc /dx8...my flying ability
noddyflyer is offline        Reply With Quote Quick reply to this message
Old 03-02-2013, 11:22 PM   #171 (permalink)
348g with battery.
Align 250SP Motor
Align BL15X ESC
Align DS410 Cyclic
Align DS420 Tail
Detrum GY48V ($12 gyro performs almost flawlessly )
Spektrum AR6100
Thunder Power 910mAh 3s 20C
Spektrum Dx6i
EXI 250 Full CNC Machined Aluminum Tail Case and Blade Grips
Align Plastic Tail Blades
Align 205D Carbon Fiber Blades
Align Carbon Fiber Tail Boom
EXI Tail Control Pushrod
Canomod Canopy
Getting absolutely none or minimal tail wag. For $23 this EXI tail assembly is doing really well!
BladeScraper is offline        Reply With Quote Quick reply to this message
Old 05-19-2013, 10:18 PM   #172 (permalink)
375 grams all in. Bone stock DFC Pro super combo with Gens Ace 850's, CC 10A BEC, Futaba 6203.
Might be a little piggish but it handles the wind nicely and can fly far beyond my capabilities at this point in time anyways.
Align 800 PRO DFC w/CGY750 / Align 700L Dominator w/CGY750 / 74" EF Slick 580 EXP / Futaba 18SZ / RealFlight 7.5
shawnlh is offline        Reply With Quote Quick reply to this message
Old 09-21-2013, 02:13 AM   #173 (permalink)
Default What's your 250's weight?
359 grams
342 without canopy.
250MX - motor
DS95i - tail servo
Pulse 860 35c - lipo
BD3sx helicommand - FBL controller
Talon 35 - ESC
So amazing!!
ID:	452363   Click image for larger version
Its all about having fun
ShaneJourdan is offline        Reply With Quote Quick reply to this message
Old 10-02-2013, 07:46 PM   #174 (permalink)
Purchased a 250se and just gave her her final tweaks tonight after maiden. Flies solid for a little fb heli. Flying weight with batt. and canopy she weighs 336.5 grams or 11.87 oz. Hopefully she'll remain that weight AFTER alot of flights.............the thought of a rebuild after struggling with Taiwanese directions or rather Pictures is making my head hurt, not enough brainpower left. But the nice thing about building is you know exactly what goes where, and now, setup should be a breeze. She is one pretty heli though and solid. But we all know you could fly a titanium overloaded (in parts) heli and when it crashes hard, they all look the same as we run a record sprint to get to them lol! BTW, this little heli has been discontinued, replace by the fbl 250. Had to do a little hunting to find one. Hopefully parts will be around for awhile.
ID:	455048   Click image for larger version
Flyin' keeps me grounded!
bobbygz is offline        Reply With Quote Quick reply to this message
Old 10-07-2013, 02:32 PM   #175 (permalink)
Align T-Rex 250 DFC Pro Combo
+Kontronik MiniJazz 20
+Microbeast + Satellite
+Scorpion HKII-2208-24
+MKS DS95/DS95i Cyclic/Tail
+KDE Upgrades V2
+[Heimi Joint's] Chinese Weights
It's on the heavy side:
312g bare (no battery or canopy)
332g + canopy
412g flight weight (canopy and Thunder Power G6 850mAh)
ID:	456318   Click image for larger version
ID:	456319   Click image for larger version
gazor is offline        Reply With Quote Quick reply to this message
Old 10-19-2013, 06:55 AM   #176 (permalink)
Just finished my first from scratch heli build.
345g with lipo & FG canopy
250 pro DFC
Stock 415 & 425 servos
Stock 250MX Motor
Stock Yellow ESC
3Gx with Speky Sat Rx
Tarot Alloy bottom plate
Alloy Main bearing blocks
Custom 3mm CF tail push rod
Optipower 850mAh lipo (70g)
Ripmax CF 205mm main blades
Stock plastic 37mm tail blades
Fususo FG tail fin Yellow
Nano CPX x 3, mCPX-BL x 3,130X, 180CFX, Lynx 450X-L, T-Rex 250 DFC, T-Rex 450L, T-Rex 500, KDS Chase 360, SAB G380, G500 Spt, BT650, BT700-T, BT700 Spt, XLP500
"More the Knowledge Lesser the Ego, Lesser the Knowledge More the Ego" Albert Einstein
Miracle Boy is offline        Reply With Quote Quick reply to this message
Old 10-20-2013, 12:37 AM   #177 (permalink)
Hi, gazor.
Where did you get your Chinese weight for tail rotor grip?
Kozy2009 is offline        Reply With Quote Quick reply to this message
Old 10-20-2013, 12:24 PM   #178 (permalink)
Originally Posted by Kozy2009 View Post
Hi, gazor.
Email Robin here:
[email protected]
I just bough some from him a few weeks ago. Very fast service.
Here's the thread about it:
https://www.helifreak.com/showthread.php?t=107276
Besen is offline        Reply With Quote Quick reply to this message
Old 10-28-2013, 08:15 PM   #179 (permalink)
Heli Only - 256.9 g
Heli + Canopy - 272.3 g
Heli + Canopy + Bat - 339.5 g (Glacier 800 mah 25C)
250se converted to FBL / DFC
Pro upper frame
se lower frame
DS410 Cyclics
JR DS290G Tail
Microbeast with dsmx Sat
Yellow BEC + CC 10A BEC
Align CF Main Blades
Will be working to drop some weight
Jerry P - 180CFX, OXY3, X3, 500X, TT 550E
jypt01 is offline        Reply With Quote Quick reply to this message
Old 11-16-2013, 08:09 AM   #180 (permalink)
My weight on 250 dfc 362grams
With:
Ikon fbl system
850mah 3s 45c nanotech turnigy
1 dsmx satelite
Aluminum bearing blocks
All stock only bearing blocks upgraded
+12 0 -12 pitch
Fly really awesome with the ikon flybarless system and power on this bird haha
kunuk is offline        Reply With Quote Quick reply to this message
