Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCX
mCX Blade (eFlite) Micro CX Helicopters Information and Help
Old 05-18-2009, 03:57 PM   #1 (permalink)
Default The Official E-Flite mCX Modification Resource Thread
This thread was designed to help users like me find information about the E-Flite Blade mCX and S300. If you have any URLs you would like to suggest, feel free to PM or post here.
https://www.helifreak.com/showthread.php?t=114568
mCX Solder Modification
mCX Swash Play Removal Modification
mCX AC Adapter Charger Modification
https://www.helifreak.com/showthread.php?t=130807
mCX Do It Yourself Aluminum Flybar
mCX Blue LED Modification
https://www.helifreak.com/showthread.php?t=126557
https://www.helifreak.com/showthread.php?t=115877
S300 Instruction Manual
mCX Instruction Manual
https://www.helifreak.com/showthread.php?t=139901
iflymyhelishigh is offline        Reply With Quote Quick reply to this message
Old 05-20-2009, 03:06 PM   #2 (permalink)
I'll add one here, not to mention a bump.
Washers to remove free play in the blade attach points (Washers can be ordered from here)
Johnny Dangerously is offline        Reply With Quote Quick reply to this message
Old 05-24-2009, 12:19 PM   #3 (permalink)
Remember, if you have any more links, PM me or post them here!
The code is
[url="inserturlhere"]label[/ url]
remove the space between the / and the url in the last box.
Old 06-07-2009, 07:43 PM   #4 (permalink)
NEW LINKS!!
Replacement Battery Connectors
Setting up Blade mCX with DX6i!
Old 06-14-2009, 10:14 PM   #5 (permalink)
Default mCX performance kit
This kit dramatically improves the mCX performance. Check out the videos. http://cuskerrc.webs.com/
eagleedge is offline        Reply With Quote Quick reply to this message
Old 06-16-2009, 06:47 PM   #6 (permalink)
LOL, I just realized something, I don't even have an mCX but I'm so involved with them, I know them inside out
Old 06-16-2009, 07:00 PM   #7 (permalink)
Hi Chris/iflymyhelishigh:
May I ask, what's holding you back from the mCx?
Thanks.
-Linac
SRB SG Quark on XP9303 FM, Oct. 2010 I mSR on DX6i, Aug. 2009 I SRB Quark, Jun. 2009 I mCX, Jan. 2009
linac is offline        Reply With Quote Quick reply to this message
Old 06-17-2009, 05:46 AM   #8 (permalink)
I am 14 years old and have no money haha
Old 06-23-2009, 06:48 PM   #9 (permalink)
But you have a T-Rex?
krosenqu is offline        Reply With Quote Quick reply to this message
Old 06-23-2009, 08:25 PM   #10 (permalink)
I have just enough to keep em flying... but this resource will be helpful... subscribed
Blade Cp, T-Rex 450 Se V2.75 (mikado head, beam swash and tail, 7200BX), Airwolf 450sa, Blade mCx, mCPx, mSR, Cx2, Swift, Havoc Heli
The Steve-O is offline        Reply With Quote Quick reply to this message
Old 07-04-2009, 10:00 PM   #11 (permalink)
How can you be so "involved" with them and know them "inside out" if you do not even have one? Only a hands on experience can give you the knowledge to know them "inside out"!
But, aside from that some good links.
~Phil~
Philup is offline        Reply With Quote Quick reply to this message
Old 07-05-2009, 10:57 AM   #12 (permalink)
Cause I know people who have them, and I'm crazy like that
Old 07-05-2009, 11:02 AM   #13 (permalink)
I think that being crazy is a prerequisite of flying heli's!
~Phil~
Old 07-08-2009, 09:52 AM   #14 (permalink)
What is the recommended shortening length? I don't think there is a thread devoted to the shortening of the flybar mod?
Also do you guys shorten it with a soldering iron? How do you retain it?
Mooshu Beef is offline        Reply With Quote Quick reply to this message
Old 07-08-2009, 07:21 PM   #15 (permalink)
I use a 750 to 800 deg. F heat gun, a candle should also work. Keep the heat off of the carbon fiber rod. Youíll most likely melt the plastic end cap but thatís OK, itís bound for the trash can anyway. Use some small pliers to slide the plastic cap off and slide the weight to the center. I use a razor knife to scrape the CA off of the carbon fiber rod before I start cutting.</SPAN>
Before you start heating and moving the weights try just cutting the plastic end caps off and doing some flying. It worked well on one of the MCXs I just modified. You can sand the plastic end off or cut it off with a small saw. Put a drop of CA on the end of the weight when you are done to help hold the weight in place.
cryo-tek is offline        Reply With Quote Quick reply to this message
Old 07-09-2009, 11:26 PM   #16 (permalink)
I can confirm that heating the rod will NOT help you :p
Cryo, I cut off the outer part of the weight and then moved the metal weights in so the overall length is now 4 inches. It works fine. I will try adding more weight later to see how it affects it, but I will most likely leave it as it is.
Old 07-26-2009, 01:28 AM   #17 (permalink)
Default AC Dual Charger Mod
As many others have done to their stock chargers, I modified mine for AC as well. I suggest at the minimum adding a wall charger but I figured why not make it a dual charger. I don't know what the circuits of the stock charger are rated for current, but I don't think it would be good looking at the size of the wires if you went over 1A?
-Drilled 21/64" hole for DC Type M plug in back of charger.
-6v 600mA DC wall supply (got lucky found one lying around)
-Parkzone connector glued in and wired parallel for dual battery charging.
$1.35 for the Parkzone connector, $3.29 for the DC M switched panel plug @ Radioshack, hot glue stick 5c.
Notes:
-Make sure you use a "switched" M panel plug, wire it so it opens the circuit on the batteries when the AC charger is plugged in.
-You still need a single AA battery in the charger on the positive side (where the red wire connects to the +) to power the LED.
The only thing left that I want to do is add another LED to the front of the charger since the one on top is pretty useless when you need to get a charging status while you're flying across the room from it.
http://picasaweb.google.com/lh/photo...eat=directlink
shantec is offline        Reply With Quote Quick reply to this message
Old 11-22-2009, 06:48 PM   #18 (permalink)
I thought I'd put this in here. Some of you may have seen it. I'm just browsing this forum (I'm usally in the trex 250 section) so if you want some info, pm me. This was fun to do and kind of an experiment. When these mods are done, the heli is almost uncontrollable (servo speed), so I don't recomend this to the newbee. Thank for whatching.
[nomedia="http://www.youtube.com/watch?v=98pLFcF4VIg"]YouTube- Broadcast Yourself.[/nomedia]
HeliHoverAP is offline        Reply With Quote Quick reply to this message
Old 11-22-2009, 11:57 PM   #19 (permalink)
after all that work you could have just got the cusker kit for $20, and 20 min of time, but your setup is nice.
cx2, mcx, T Rex 450 SA, GAUI 550, walkera cb100, 4#6, 4#6S, 4g6S, trex 450 clone, V911/FP100, DX7, DX8
never hold your farts in. they travel up your spine, and that's where s****y ideas come from.
shaggybirdman is offline        Reply With Quote Quick reply to this message
Old 11-23-2009, 08:42 AM   #20 (permalink)
There was a little more work done than just the swash plate. I dont think anyone would release a "kit" with this amount of modification. Like I said It was almost uncontrolable, and I was just having fun. It is now back in stock form.
