Go Back   HeliFreak > R/C Electronics Support > Spartan RC
Spartan RC Spartan RC - Quark, DS760 Gyros and other Spartan RC Electronics Factory Support
Old 06-02-2009, 10:40 AM   #1 (permalink)
Registered User
Default Spartan Servo Compatibility List
http://www.spartan-rc.com/resources/servodb/servo.php
William James
Old 06-04-2009, 02:15 PM   #2 (permalink)
Will,
thank you for posting the link to the servo table. I would like to add that this list of servos is not exhaustive. Our gyros offer several servo pulse modulations to cover all flavours of digital servos on the market.
We provide some general rules on how to determine the correct mode here: http://www.spartan-rc.com/resources/...=12&category=3
-Angelos
SPARTANRC - R&D
Angelos is offline        Reply With Quote Quick reply to this message
Old 06-04-2009, 04:25 PM   #3 (permalink)
Angelos what do the red line under the blue line on some servos mean
rcer04 is offline        Reply With Quote Quick reply to this message
Old 06-04-2009, 04:31 PM   #4 (permalink)
Looking at it, they are rating bars for speed and torque. longer bar=better. the red bar just indicates the rating at 6v
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
The Front Porch, Nexgens Lounge
nexgen is offline        Reply With Quote Quick reply to this message
Old 12-23-2009, 11:58 AM   #5 (permalink)
is there a sub-micro digital servo in 3 to 4grams range to be matched with the spartan quark?
baygenco is offline        Reply With Quote Quick reply to this message
Old 12-26-2009, 01:09 PM   #6 (permalink)
I think the key is to nail down what the pulse width and frame rate of the servo is, so you can pick the best match on servo selection part of the Quark setup
Old 01-25-2010, 02:58 PM   #7 (permalink)
are we able to get some Hyperion servo specs listed on the list.
DS09
DS11
DS20
Old 05-05-2010, 04:03 PM   #8 (permalink)
DS09
DS11
DS20
+1
Gaui X3 Avoiding the ground Gaui X5 FES:
Blade Nano QX Blade NCPX : stock, DX7s
gunkle is offline        Reply With Quote Quick reply to this message
Old 05-14-2010, 12:33 AM   #9 (permalink)
Originally Posted by gunkle View Post
+1
+1 for the hyperion servos. They are compatible right?
HK450 | 3x HXT MG14 | Metal Spartan Quark | Hyperion DS12GMD
Gaui Hurricane 200 V2-SE | 3x Hyperion DS09AMD | Spartan Quark | INO_LAB D201HB
Guru-Z Xeon CP | 3x HXT900 | Logictech 2100t | Hyperion DS09GMD - not yet finished
Blade mSR - MAAC# 80042
dmulligan is offline        Reply With Quote Quick reply to this message
Old 05-14-2010, 12:51 PM   #10 (permalink)
+1 for can we get them added to the list. I have read that they work. Still working on my build.
Old 05-21-2010, 03:46 PM   #11 (permalink)
The Hyperion servos definitely work (and quite well at that). I use the 1520/250 setting.
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 05-21-2010, 08:51 PM   #12 (permalink)
I had read that the 270Hz limit was conservative and that 400Hz is the actual limit. I read that in ******* Magazine. Apparently they contacted the manufacturer. It seems to run fine at 333Hz but I have a slight wag that I cannot seem to get rid of so I will try 250Hz.
Old 05-21-2010, 11:38 PM   #13 (permalink)
Definitely lower the setting. Also, If you have a slight wag on the Hyperion you need to read this thread for a fix and then this post for an in-depth reason why the fix worked. Fascinating stuff!
Chris Boultinghouse
Old 05-22-2010, 11:00 AM   #14 (permalink)
I wish I had found this information a long time ago but alas I guess the threads are weeks old. Have you and Northern James spoken about this on your podcast? (I am a little behind as I an in the middle of a good audiobook.) It was on your recommendation that I bought Hyperion servos after all
edit: I just realized that macr0t0r was responding to what you said in the podcast. I need to catch up My book is in a real heavy chapter so maybe some IH while mowing the lawn today would be good.
Also it is not your job to be making this known, why is Hyperion so quiet in the community? This is certainly a big shortcoming of the company and they could be doing so much better as they make some damned good batteries and servos. Oh I guess without even trying this my confidence is restored eh?
edit2: That thread is by Northern James! Oops! Good work Northern James!
Old 06-15-2010, 12:02 AM   #15 (permalink)
I tried from 2uS to 8uS of dead band. No change at all. I then tried dropping in an ino lab hgd201 servo and the problem went away. I am afraid that the little ds09gmd has let me down.
Old 06-15-2010, 07:29 AM   #16 (permalink)
Bummer!
I'm using the DS11 / Quark combo with great results, I guess the little DS09 just isn't up to the task.
Chris Boultinghouse
Old 02-13-2011, 05:01 PM   #17 (permalink)
Thumbs up
Can anyone tell me what the setting details are for the Hitec HS7966HB hi speed servo? I have tried looking on hitecs website, but could not find any details about frame rate etc. Thanks in advance.
Swashed is offline        Reply With Quote Quick reply to this message
Old 02-28-2011, 03:24 PM   #18 (permalink)
Originally Posted by Angelos View Post
Will,
-Angelos
Hello,
What is the correct mode for the Hitec 5084MG tail servo?
Thank you,
arquitron is offline        Reply With Quote Quick reply to this message
Old 04-29-2011, 08:07 PM   #19 (permalink)
I tried to use an align ds520 but it would not initialize. I had to unplug and replug the servo after the gyro initialize before i could get any response.
Can anyone please help me setup this servo on my ds760
funprise is offline        Reply With Quote Quick reply to this message
Old 09-17-2011, 05:04 AM   #20 (permalink)
This was posted a while ago, but what size heli are you using the DS11 in - or any one else that is using the DS11 Hyperion.
RC Heli Pilot = Control Freak
maverickk is offline        Reply With Quote Quick reply to this message
