Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Atom 500
Atom 500 Compass Atom 500 Model Helicopter Discussion
Old 04-05-2011, 08:46 AM   #61 (permalink)
@Dflyer, I'm running a 10 tooth pinion and on my DX7 St -2 throttle setting is 67 % and HS seem to be around 2900 I haven't tach'd it yet. But changing timimg to 18 will my HS increase a lot?
Sent from my EVO, cause I can't reach the PC
Atom 500 VBar (Takes a licking), MCPx 2s (Flying ), Atom 7HV-Bar (Flying LARGE!!)
BBRFST is offline        Reply With Quote Quick reply to this message
Old 04-05-2011, 11:02 AM   #62 (permalink)
Hi Sean,
this setting will not affect your headspeed !
Grtz,
Dirk
The heli virus has infected me and i hope that there is NO CURE !! Compass Support Team
__________________________________________________ _____
Warp 360 / 6HVU / CY Stingray / Invertix 400 / SH Little Spyder
Dflyer is offline        Reply With Quote Quick reply to this message
Old 04-05-2011, 11:20 AM   #63 (permalink)
Old 06-15-2011, 12:04 PM   #64 (permalink)
Motor Shaft Info / Part Number
Originally Posted by kevinator9 View Post
Hi Guys,
Found that Compass now sell the motor shafts separately. It seems they come attached to the outer can so you buy the shaft and can together.
Atom 500 Motor Shaft and Can Part #08-5016
Atom 6HV Motor Shaft and Can Part #08-5026
Jimmy! is offline        Reply With Quote Quick reply to this message
Old 06-15-2011, 12:05 PM   #65 (permalink)
Atom 500 and 6HV Motor Bearings
Originally Posted by TheBum View Post
One 6x15x5mm and one 6x12x4mm.
Last edited by TheBum; 06-15-2011 at 03:19 PM.. Reason: Added 6HV since it uses the same bearings
Old 06-15-2011, 03:26 PM   #66 (permalink)
Atom 500 Tail Pulley Roll Pin:
Part #84-0214
http://www.hobbyhangar.co.nz/hardwar...mm-p-6061.html
Atom 6HV/3D+ Tail Pulley Roll Pin:
Part #84-0212
http://www.hobbyhangar.co.nz/hardwar...mm-p-6060.html
(Courtesy of kevinator9)
HeliFreak Support
Protos Max Evo 700 (Brain 2), Protos Max V2 770 (iKON 2), Synergy 516 (Brain 2), DT520Ev2 (VBar)
Graupner MZ-32
Old 12-12-2014, 06:36 AM   #67 (permalink)
Short question
What value's should i use for the stock atom 500 motor?
I've got a new hobbywing platinum v3 100a esc.
I'm flying with a stretcht atom, stock motor and 10t pinion and like headspeeds
So i'm not shure with frequency and timing degrees i should take.
Anyone suggestions?
I've used now 18 degrees timing and 16khz pwm frequency.
sven75 is offline        Reply With Quote Quick reply to this message
Old 12-13-2014, 06:01 PM   #68 (permalink)
With the stock motor it doesn't get much better than that, so you're pretty much right on the money. You *can* do 22.2 timing, but honestly it's just wasted heat for not enough of a power gain at that point. Unless you're flying in really cold weather, you're better off getting a bigger/stronger motor (ie - 6HV canister, or running HV) and keeping the timing a little lower if you need that kind of stupidity! (pardon the pun!)
I've seriously considered putting an 8S-12S setup on my Atom since I'll pretty much have the stuff on hand to do it once I switch out the ESC. I'm loving the HW PP3 50 on my 450 right now, so I can imagine the 100A is really nice too (although I can't remember if it's HV or just up to 6S/8S). I have an HV 85 and an extra 70HV sitting around either way. It just might be a winter project if I run out of stuff to do around the house.
Tim
KBDD TEAM PILOT
--Si vis pacem, para bellum--
skunkworx is offline        Reply With Quote Quick reply to this message
Old 12-13-2014, 06:47 PM   #69 (permalink)
"if I run out of stuff to do around the house."
Please let me know how to do this, Tim.
I seem to be busier with household cr@p than I ever was before!
Old 12-13-2014, 08:13 PM   #70 (permalink)
Hahaha! I bet. We got a lawn tractor to help around the yard and boy, is it ever paying dividends already! Mulching up the leaves and getting the yard cleaned up is the first chore in my life that I can truly say was nothing but fun. The kiddos like jumping on and going for a ride too, so, double the awesome because I get to spend some time with them as well.
Tim
KBDD TEAM PILOT
Old 12-27-2014, 01:54 PM   #71 (permalink)
Thanks for the answer guys.
The timing was fine with those settings, the atom flew great for 2 flights...
i made a huge mistake and lose orientation and smackt it into the ground... totall loss.. rip atom.
Old 12-29-2014, 07:22 AM   #72 (permalink)
Bummer...
Tim
KBDD TEAM PILOT
Human Verification
