Like Tree1Likes
Old 07-31-2009, 09:24 AM   #21 (permalink)
I think I know what you meant, but just in case...
It's low end only on price!!
Also, just because it is not carbon fiber, doesn't mean it is low end! Carbon fiber is not necessary better!!! Certainly not in this case!!
take care
Mesnik is offline        Reply With Quote Quick reply to this message
Old 08-04-2009, 09:32 AM   #22 (permalink)
Default Tail Pinion Bearings
Bob,
I was watching your build video on the pantera frame assembly part 1 and wanted to inform you on something I spoke about with John Beach. Apparently there is some confusion on how the tail pinion bearings should be orientated. I believe John plans to make corrections on this in the next manual update. The bottom bearing block #4 should be reversed then add one M3 washer with one M3x6 Button Head Bolt to the bottom of the shaft. I have done this on my build and it goes together perfectly. It makes sense seeing the shaft is tapped for it anyway. It holds the bearings & shaft in place mechanically without relying on locktite. As well a bit of green locktite is always good insurance to minimize spinout on the shaft.
PS, I really enjoy your videos and have learned a lot from them...Great Job
Thanks Bob
moore429 is offline        Reply With Quote Quick reply to this message
Old 08-05-2009, 10:17 AM   #23 (permalink)
Team Taco VP
Hmmm OK the manual talked about 2 ways to install that and flipping that one block over. Is this the same thing your talking about?
Bob
Old 08-05-2009, 10:05 PM   #24 (permalink)
No what I am recommending is not in the manual at all. The manual suggest flipping the top bearing for additional clearance for the servo. I didn't have any clearance problems. The top bearing should stay as shown and flip the bottom bearing. Basically the open side of each bearing blocks face out towards the shaft ends. This way the bearings will be retained and can't move inward. Here are a couple pictures that may help explain.
ID:	109274   Click image for larger version
Old 08-12-2009, 03:36 AM   #25 (permalink)
Default What happened to Audacity
After watching the build videos for the Pantera I toyed with the idea it was a cheap way of trying Nitro but not at the expence of quality. Today I decided why not, it will not break the bank but where have Audacity gone. No more adverts, their web site cannot be reached????? In Australia the only advertising I see is for a Twister Pantera 50 due for delivery "sometime". Details not available. Has the bubble burst????
A geriatric flier pushing the brain cells and reaction time.
RC addict with lots of helis, planks and cars.
watdazit is offline        Reply With Quote Quick reply to this message
Old 08-12-2009, 06:01 PM   #26 (permalink)
http://www.genesishobby.com/Products...1/Default.aspx
works for me.
TRaeside
Blade CX2 - T-Rex 250 T-Rex 450 - T-Rex 500 CF
HIROBO Shuttle ZX - E-Smart 600 All Metal - Gaui 200- Vision 50 - T-Rex 600ESP
traeside is offline        Reply With Quote Quick reply to this message
Old 08-12-2009, 06:02 PM   #27 (permalink)
Originally Posted by OMFGitzDanny View Post
bob we need to see Ely Q vision 50 bulid videos.
I would like to see this build too, but i wont say that here or it might look like a hijack. O no Sorry
TRaeside
Old 08-12-2009, 11:12 PM   #28 (permalink)
Originally Posted by traeside View Post
I was looking for Audacity not Genesis. Cheers. Checking on supply now.
Now I find they are on holiday but never mind I have found an Australian dealer. Obviously with the Oz $ they are a bit more expensive but still a good deal and I can pick one up complete with an OS 50 motor for $aus595 and all I have to supply is Rx, servos amd gyro all of which I have knocking around the workshop. Looks like I am joining the Pantera club.
Old 08-13-2009, 10:21 AM   #29 (permalink)
Roger that sorry. glad you found what you were looking for.
TRaeside
Old 08-20-2009, 04:20 AM   #30 (permalink)
Been watching the build and then nothing for a while from Bob.Is all ok?
Pro Anti is offline        Reply With Quote Quick reply to this message
Old 08-20-2009, 01:04 PM   #31 (permalink)
Team Taco VP
Yea... going to start back up again. IRCHA, etc stopped the build.....
Bob
Old 08-20-2009, 02:16 PM   #32 (permalink)
IRCHA was worth it!
New Toys, Logo 600SE, Futaba 18MZ
Align 450 Pro V2, Mini-v
Pantera 55, Pantera XE Elec
Trex 600 ESP, Gaui 425
edhall is offline        Reply With Quote Quick reply to this message
Old 08-21-2009, 01:35 PM   #33 (permalink)
Eagerly and impatiently waiting..................
These vids are top notch, Bob.
mdlott is offline        Reply With Quote Quick reply to this message
Old 08-22-2009, 11:00 AM   #34 (permalink)
Bob,
Page 12 of the manual has a tip about using adhesive for the bearing to bearing blocks to secure them. It's at the top of the page.
John Beech - GM (and janitor)
www.promodeler.com
407-302-3361
AMA # 47381, IRCHA #745
jbeech is offline        Reply With Quote Quick reply to this message
Old 08-22-2009, 11:04 AM   #35 (permalink)
Team Taco VP
John, Yes I know that and I mentioned it in the following video segment after that one
John should I recommend the bottom bearing flip with the screw in the shaft as noted above? Looks like a good idea to me?
Bob
Old 08-22-2009, 01:28 PM   #36 (permalink)
Good question Finless! I spoke with John on the phone this morning and he is looking into the bearing setup mod. I told him about the pics and that it looked and sounded like a reasonable and valuable mod. He was going to look at the pics and give us a post on what he thought about it. I was curious because I'm about to start my build and noticed the mod on here and thought...."hmmm, I wonder if John would recommend this?"..... Hopefully, he'll get back with us pretty soon on what he thinks. I'm holding my build until I hear his input, but it sure looks like it would work well. BTW....enjoying the vids and just in time to start building #1 of the Pantera twins. Thanks a bunch for your hard work in helping us all out on a proper build. Cheers.
_________________________________________________
Pantera 50 nitro, Kinetic 50 nitro, Century Hawk Sport/Pro nitro, Exi 450 Pro, Dragonus II, Blade 400, Extreme-modded HBK2, Blade mCx and S300, Novus CP brushless, and M.P.V.S.T. (Multiple Planks of Various Size and Type).....
rnbiker is offline        Reply With Quote Quick reply to this message
Old 08-22-2009, 08:41 PM   #37 (permalink)
Yes, Bob, please mention the tail drive shaft is now drilled and tapped one the bottom side now. FWIW, previously, a drop of threadlocker secured the bearing to the shaft but enough folks skipped over this that we decided to use the new method. It's especially easy since we can perform this step while we're already manipulating that shaftand thus, it doesn't add appreciably to our unit cost. You've probably already noticed several running changes we've made to the product versus what's photographed in the manual. In effect, you're showing the V2 despite the fact I've not mentioned it yet. As I get time I'll update the manual and tell the world about it. Goes to show I'm not the world's best marketer, eh?
600 or Bust! likes this.
www.promodeler.com
407-302-3361
Old 08-28-2009, 08:47 PM   #38 (permalink)
Come on, Bob! There's at least one person that would like to see this series continue.
T-Rex 450 S, T-Rex 500, Pantera 50, Turbulence D3 (one can dream)
benwhite22 is offline        Reply With Quote Quick reply to this message
Old 08-29-2009, 02:55 PM   #39 (permalink)
I like it... I like it a lot. I think I'll grab a few for the winter build. Is the sale still on?
theLane is offline        Reply With Quote Quick reply to this message
Old 08-30-2009, 07:17 PM   #40 (permalink)
I assembled like the directions instructed with the black ca and red loctite. I went to flip the block around and insert the screw, but can't get the bearing out of the block, or the bearing off the shaft! Is it really a necessary mod or can I just wait until it needs replaced?
z_man_95 is offline        Reply With Quote Quick reply to this message
