Like Tree1Likes
Old 09-07-2009, 11:26 AM   #61 (permalink)
Team Taco VP
Take a sanding block and go at the seam. If you see your are starting to get into the FP or CF laminates STOP. Hopefully it is just the seam.
Bob
Old 09-07-2009, 11:34 AM   #62 (permalink)
Just removed the blade and put the old and new together with the bolt and the root tip needs to be rounded on the trailng edge. I'll give it a try. Other than that the ProTek blades balanced perfect which suprised me. Thanks Bob
Spell is offline        Reply With Quote Quick reply to this message
Old 09-07-2009, 11:59 AM   #63 (permalink)
That did the trick, They just nick the spindle bolt a tad. Thanks again
Old 09-07-2009, 12:01 PM   #64 (permalink)
Team Taco VP
Old 09-07-2009, 12:08 PM   #65 (permalink)
Well have a good labor day, Its off the the field.
Old 09-07-2009, 12:09 PM   #66 (permalink)
Team Taco VP
Yep... I am heading that way myself in about 30 minutes! Just one more cup of coffee
Bob
Old 09-09-2009, 10:59 PM   #67 (permalink)
Originally Posted by Spell View Post
In regards to putting in the fuel tank pickup and gromet, I put the clunk, fuel hose and fitting together first with a piece of fuel line attached to the fitting outlet, then put it in the tank then installed the gromet and used the fuel line to pull the fitting into the gromet, beats trying to work the whole assembly into the fuel tank. Then just hold the fitting in with the fuel line and slip the washer and nut over and tighten. WaLa
Hey! That's my trick....Oh well, if I'm too lazy to post pics and a write up it's my own fault.
Build's looking good, Bob! If you sweat the details like me, and I know that you do, you'll end up with one very smooth machine.
T-Rex 450 S, T-Rex 500, Pantera 50, Turbulence D3 (one can dream)
benwhite22 is offline        Reply With Quote Quick reply to this message
Old 09-09-2009, 11:02 PM   #68 (permalink)
Team Taco VP
I am off to the Lexington Ky Funfly and wont be back till Monday afternoon. Videos will restart then.
I am going to check out that tank trick and if nobody minds use it in the videos with credit of course to Spell for posing it first
Bob
Bob
Old 10-04-2009, 06:32 PM   #69 (permalink)
any updates?
hillar73 is offline        Reply With Quote Quick reply to this message
Old 10-04-2009, 07:48 PM   #70 (permalink)
Team Taco VP
Yep coming soon... My issues have been gear. I will be going back to using a OS 50 as I had an early KME and it's back getting updated. Also had a bad servo from an order (while shooting servo setup) and replacement is on it way.
ALSO I got the new Airtronics SD-10G that I am going to use in this heli to show a heli setup so I have been learning this radio and plan to do full vids on it.
Anyway it just got put on hold for a couple weeks. Updates to come soon.
Bob
Old 10-20-2009, 05:42 AM   #71 (permalink)
As soon as funds come available, I'm gonna get my grubby hands on 2 of them. Even with shipping, 2 of these cost the same as my Sceadu 50.
Well maybe a little more. Gotta get crash parts:o
Airtronics SD-10G
JR 9X
T-Rex V2 Hitec HS-5065x3, Futaba S9650
Hirobo Sceadu Evolution HPM / OS Hyper 50 - K&S tuned pipe
AHF Aeolus 50 on the bench!
heli-junkie-jp is offline        Reply With Quote Quick reply to this message
Old 10-29-2009, 10:01 AM   #72 (permalink)
After I see how your test flight goes, I think I am going to get one for a winter beater heli! Come on Bob, is your job getting in the way of the build! Ha
Zaaaguy72 is offline        Reply With Quote Quick reply to this message
Old 10-29-2009, 11:31 AM   #73 (permalink)
Team Taco VP
Yes work and too many funflys in the last 2 months, the AT radio vids as I am using it in this heli, equipment issues, etc. I still have not gotten my KME engine back yet so I am probably just going to use an OS 50 hyper for now. Seems like every year around this time, I run out of time! Just like last year my vids took a lot longer to get done.
This heli will be my priority to finish by mid November though! I have another heli coming and want to finish that one by Xmas
Bob
Old 10-29-2009, 11:51 AM   #74 (permalink)
No changes are permanent but...change is.
badastinner is offline        Reply With Quote Quick reply to this message
Old 10-29-2009, 11:54 AM   #75 (permalink)
HMM.... what does Bob have on the plate next? Maybe a radical G20 3d Gasser I hope! Those things look really cool.
Old 10-29-2009, 04:49 PM   #76 (permalink)
ok but can you do a supplamental vid when you get your KME back?
I only crash when i get to excited, and try something new, or when something technical goes wrong (hey, that's my fault to, i do the setup and pre-check....)
dxtarl is offline        Reply With Quote Quick reply to this message
Old 10-29-2009, 06:38 PM   #77 (permalink)
Could anyone explain please how the pitch control works on this heli?
It's advertised as having 3 links and a 90degree swash, the elevator lever is set into the frame and I cannot see at all how the third servos is going to change the pitch..
Any photos/diagrams etc?
Radios: DX7, RD6000(JP 2.4GHz)
Electric: Cypher 3D, Skya 250se, CX450ae/Hughes 500D,
Century Bell 47II (Hawk), w Z30a
Nitro: Hirobo Shuttle Plus, 450se Flasher, Walkera 4#3b.
Globs is offline        Reply With Quote Quick reply to this message
Old 10-29-2009, 08:08 PM   #78 (permalink)
You can download the manual, it has all the information you need.
http://www.genesishobby.com/Document...P50-MANUAL.pdf
joediamond is offline        Reply With Quote Quick reply to this message
Old 10-29-2009, 08:18 PM   #79 (permalink)
The front servo moves opposite to the two rear servos. Move front down, back two go up, rotor pitches forward.
F6Hawk is offline        Reply With Quote Quick reply to this message
Old 10-30-2009, 03:46 AM   #80 (permalink)
Thanks for that, very informative read - I can see now it is a CCPM 120, for some reason the advertising suggested to me that it was a 90degree system - like a century hawk.
