Go Back   HeliFreak > R/C Helicopter Support > 450 Class Electric Helicopters > 450 Aftermarket Upgrades
450 Aftermarket Upgrades 450 Aftermarket Upgrades
Old 10-24-2010, 08:05 PM   #21 (permalink)
Originally Posted by jpinn View Post
I just fitted my KDE tail upgrade last night. One thing I noticed was that if I tighten down on the long screw that goes through the metal mount and through the bearing part of the tail link then the whole assembly gets noticeably tight. I therefore backed off the screw ever so slightly and made sure to apply locktite. This way everything is free and there is no slop. Does this sound like the right way to do it?
I'm having the same problem with just one side. The other side works perfect. Waiting for KDE to respond...
~Cliffman~ is offline        Reply With Quote Quick reply to this message
Old 10-31-2010, 09:17 PM   #22 (permalink)
I ordered up a set from wherever, el'cheap o's waited about 4 weeks, just got them and they don't fit.
thinking about ordering from the american performance fabrication shop. but reading this thread is discouraging me.
AMAIN Heli Team
u8at711 is offline        Reply With Quote Quick reply to this message
Old 11-01-2010, 10:23 AM   #23 (permalink)
I think the duds (like the one I got) are all due to whoever is running the CNC machine not changing out a bit that needs changing in time. I saw the same parts I got (tray/clip and tail) on a 450 pro at a hobby shop and the parts on that heli were smoother and had less machine marks. Even my tray and clip have some slight deviations but they are in a location that does not affect anything, even cosmetically you would need to be inside the heli to see...
Regardless though, they really ought to not skimp out on those CNC bits... These parts are not exactly cheap.
Hey KDE, if youíre listening...
How about a CNC ball bearing bell crank for the tail? The plastic one has too much slop!
A CNC motor mount? The stock one kinda sux cuz it can flex even when installed on the heli.
CNC plastic main and auto gears? The stock ones seriously suck!
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is offline        Reply With Quote Quick reply to this message
Old 11-08-2010, 08:46 PM   #24 (permalink)
I also had trouble with the KDE upgrade with binding with the brass bushings. I had to play around with it for a while and try it with a couple sliders until I got it smooth. Even then, with the slightest torque on the phillips head screws it would bind. I hope that Loctite holds!
I wish the KDE upgrade came with hex screws in place of the stock phillips, like the knock off does.
Montana is offline        Reply With Quote Quick reply to this message
Old 12-04-2010, 10:00 AM   #25 (permalink)
has the tail binding issue been figured out or maybe the tolerances goten better? i was thinkn about getn the metal tail bling but ill wait for some good reports
Evan03 is offline        Reply With Quote Quick reply to this message
Old 12-04-2010, 10:16 AM   #26 (permalink)
Mine still binds if I put ANY torque on the screw that has the brass bushing. Maybe I'm clueless or just have bad luck but I've always had trouble with that slider design. I just ordered a Microheli version that says it replaces all the bushing with bearings, but it hasn't arrived yet. I've had bad experiences with Microheli's stuff but I decided to give them another try because I have so much trouble with the bushings. I'll report back when I get the Microheli part.
http://www.microheli.com/product_inf...oducts_id=1637
Old 12-04-2010, 10:34 AM   #27 (permalink)
I hope that MicroHeli tail slider works better for you than it did for me. I had to return the POS because the hole in the slider bearing, that the tail shaft inserts into, was just a hair too big. This caused extreme binding! I returned it. The KDE links that I got did the same thing when I first got them. They would bind if I tightened them too much. Then I tried to overtighten them and then backed them off. After doing that they seemed to "seat" or something. Then I was able to tighten the screws down with no binding. I really don't know what happened, but they've been fine for months and dozens of flights now with no binding at all.
johnsma22 is offline        Reply With Quote Quick reply to this message
Old 12-04-2010, 10:37 AM   #28 (permalink)
Align makes an aluminum bell crank for this heli, and also an aluminum slider bearing holder. These pieces, along with the aluminum KDE links have removed just about all the slop from my tail assembly!
Old 12-06-2010, 10:14 AM   #29 (permalink)
Do you have a part number? I have been looking but canít seem to find the bell-crank... I found the bearing holder though.
AMA# 977012
Old 12-07-2010, 07:30 AM   #30 (permalink)
heres the align metal bellcrank
http://highflyheli.com/index.php?mai...roducts_id=349
aling metal anitirotation bracket
http://highflyheli.com/index.php?mai...oducts_id=1065
tail servo mount
http://highflyheli.com/index.php?mai...oducts_id=1011
im probly going to get one on my next order
Old 12-07-2010, 09:31 AM   #31 (permalink)
Cool.... thanx for that.
AMA# 977012
Old 02-14-2011, 11:24 AM   #32 (permalink)
After the binding issue with the bronze sleeve bushing I run into the exact same issue. ^^
Tighten the long socket head screw = binding the whole assembly.
I love this upgrade on my 500 but for the 450 I can't recommend it.
This is from my personal experience.
Just my 2ct.
Edit: I choose the refund route. Thx KDE for taking care of this.
TSH Gaui X5 FES, Spirit, S.Bus, HW100A V3, Formula swash/head
TSH Gaui X3, Spirit, 6S, S.Bus, HW50A V3
Futaba T7C (I admit, also a Spektrum DX8 and some planks.) ;-)
Phoenix R/C v5
helidude71 is offline        Reply With Quote Quick reply to this message
Old 02-14-2011, 11:57 AM   #33 (permalink)
Can you see whatís binding though? I have found 3 causes.
1) Over tightened screw, you need to feather it at the end, the margin of error is a really fine line in this case.
2) Excessive loc-tite use, the thread lock got between the bushing and the bolt and is causing it to stick. Apply thread lock directly to the threads (use a toothpick) of the hole rather then on the bolt itself.
3) The little arm is contacting the aluminum piece it attaches to, this requires some gentle filing... A few strokes and check again (dry) then repeat till you get it smooth.
I had all 3 issues... Itís quicker and easier to just do the fix yourself rather than wait on a replacement. At least I think so anyway.
AMA# 977012
Old 07-27-2011, 02:59 PM   #34 (permalink)
Default Binding with KDE Tail "upgrade"
Same issues are reported previously. Bushing was very tight and I had enough binding problems that I went back to stock parts.
cheddah is offline        Reply With Quote Quick reply to this message
Old 08-25-2011, 07:21 AM   #35 (permalink)
Received my tail upgrade today and im sorry to say im not impressed. Both brass sleeves are not in the packet and the bearings are a long way from being bind free and smooth.i ordered this from the states so its not really worth my time or expense to send it back.does anyone know the size of the bearings please? Will be quicker and cheaper to repkace them myself I think...had high hopes for this upgrade but feel really gutted its not what I hoped for. Thankyou.
Edit...are there even meant to be brass sleeves included in the kit??!! Just looking on the kde website at a pic of the upgrade and there are none in the picture.....confused now.
Double edit...ok,i take my moan about no brass sleeves in the kit back.in the installation diagram it advises to use the ones from the original tail assembly.my apologies kde.
Still have notchy,tight bearings though! :0(
mrmurder1975 is offline        Reply With Quote Quick reply to this message
Old 08-26-2011, 11:28 AM   #36 (permalink)
does anybody please know the right bearings to order for the kde assembly? im starting to take this being ignored personally now!
Old 08-30-2011, 11:08 AM   #37 (permalink)
ok i give up
Old 10-01-2011, 11:32 AM   #38 (permalink)
Got the kde tail upgrade at all my helis, great parts.
But need a upgrade part for the arm what is connected between the linkarm rod and shaft slider at tail shaft. Got a play there i mean is too big.
anyone know to get ???
SA1000E . MiniVolt-500.CncEfects: K7-1000E K6-800E. K700E.K550-600
Align:2x Trex 450 Dominator 6s. 2x Trex 550E 4◊ BeastX- 3◊ Vbar- 3◊ Spartan VX1n- 1◊ Sk720
runesb is offline        Reply With Quote Quick reply to this message
Old 10-13-2011, 08:02 PM   #39 (permalink)
scottkoblitz is offline        Reply With Quote Quick reply to this message
Old 10-16-2011, 03:00 PM   #40 (permalink)
thanks
