Go Back   HeliFreak > R/C Helicopter Support > 450 Class Electric Helicopters > 450 Aftermarket Upgrades
450 Aftermarket Upgrades 450 Aftermarket Upgrades
Old 10-25-2011, 04:32 AM   #41 (permalink)
Originally Posted by cheddah View Post
Same issues are reported previously. Bushing was very tight and I had enough binding problems that I went back to stock parts.
I'm installing mine now.
The flanged bearings go together nicely into the KDE links and don't bind at all, even after the Allen screw is snugged up properly on the tail rotor grips.
When I first installed it, the slider would bind. Under magnification it could be seen how the links weren't lining up with the gap in the slider where the link and brass bushing is supposed to fit.
If you look really closely at the link, the link isn't symmetrical. The side that bolts to the tail rotor blade grip (and has the flanged bearings) is slightly higher than the side that screws onto the slider (and has the brass bushing).
If the link is installed "upside down", the parts will not align properly and will bind.
So if yours binds, then try flipping the link the other way around.
The "higher" side of the link should be against the blade grip, and not against the head of the Allen bolt.
With the link properly oriented, you should be able to snug up the screw and bolt normally and nothing should bind.
Hope this helps.
Custom quad copter, Cobra C-3525/18 motors and ESCs; APC 15x4 thin electric props. OpenPilot ControlCopter board. Futaba 8FG Super 2.4 gHz FAAST system.
Windbreaker is offline        Reply With Quote Quick reply to this message
Old 10-27-2011, 09:22 AM   #42 (permalink)
Does anyone have a part number for the Align aluminum slider bearing holder?
The stock slider bearing holder is plastic with a steel insert to hold the ball link.
Thanks in advance for any feedback.
Bill
DILLIGAFF is offline        Reply With Quote Quick reply to this message
Old 12-13-2011, 07:14 PM   #43 (permalink)
Do u hv video showing the correct installation for this upgrade?.....and 1 more thing, is it ok (has anyone try it yet?) to install this upgrade and at same time flipping the 450 pro grip?....waiting to install mine.
All begins (Jun 2011).......
Next project:
MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad
cpmboy is offline        Reply With Quote Quick reply to this message
Old 04-01-2017, 10:56 PM   #44 (permalink)
Default tail binding issue solution for stock or upgrade tails
I have been focusing on eliminating all the o-rings and brass bushing entirely on my heli. I have yet to fly my heli, but I guarantee it is solid and smooth. All you need is a reliable set of vernier calipers and get measurements of your ID and OD from bushings, then go to fasteddy to get a bearing to fit your needs. Whether it's factory or aftermarket, BUSHINGS SUCK.
http://www.fasteddybearings.com
PS, it hasn't flown because I haven't received new Tx yet is all.
RabbitDFFD is offline        Reply With Quote Quick reply to this message
