Old 09-21-2009, 06:28 AM   #1 (permalink)
Default Logo 400 - Mini-VBar - Mounting - READ THIS!
If you are going to mount the Mini Vbar on the Logo 400, the obvious spot behind the main shaft need modding for it to fly good.
Since the frames arent very stiff and isnt connected, its really isnt a good place.
I did the following from top to bottom:
- MiniVbar
- Futaba gyro tape or stock tape.
- 3mm fiberglass plate, sized as the whole area up there on the L400
- Layer of silicon double-sided tape (very thin 1mm, effect are like epoxy almost), so that or epoxying it will work, harder to get the frames apart if you epoxy it though.
It made TOTAL difference.
I knew my mini didnt fly well because I just removed a full size VBar from it which flew fine, but for anyone that havent tried the Logo 400 Vbar before, it can be tricky.
Without the 3mm plate it just felt "slipperish", not locked in, and it introduced drifting from time to time.
dont think it matters if you use Fiberglass, 2 or 3mm or CF or even alu, trick is to get a plate covering both frames, and it should be rigid.
http://heli.dacsa.net
Old 09-22-2009, 11:02 PM   #2 (permalink)
Any pics please.
Logo 500-610Blades:BLS252/V-BAR-9254/Z50A-600 -Jive80HV/ NanoTech 10S4000mAh + Quadrotor
History: Lama V3, ESKY CP2,,BeltCP, T450V2, Gl500, HDX500, Hurrican 550, T600E, T450Pro, Logo500SE, ... more to come
caotri is offline        Reply With Quote Quick reply to this message
Old 09-23-2009, 12:04 PM   #3 (permalink)
But of course, dont mind the cable mess, Im testing the powerbus for another thread
ID:	116603   Click image for larger version
Old 09-28-2009, 10:43 AM   #4 (permalink)
This was a great mod MrMel. I did it to my Logo 400 yesterday and it flys GREAT now, much more locked in!
I will post pics of my mod once I get a few taken. I used a piece of CF as well.
Thanks MrMel!
Currently Flying!
Logo 400 V-Bar: Hacker A40-12S, Jive80, 9650s, BSL241, 6s1p 3300 Lipo
Lepton EX Installed in Airwolf: Hacker A30-12XL, CC80, 3102s, 401/9257, 6s1p 3300 A123
Retired Helis - Blade CX, Blade CPP, TRex450SE,
cybinary is offline        Reply With Quote Quick reply to this message
Old 10-03-2009, 11:31 PM   #5 (permalink)
Here is my mounting plate made by customheliparts.com. It is cut and rounded at the corners nicely. The material is G10 ~1.8mm thick. I believe he will make more of these if the one I have is proven to be successful. I will be testing this new plate tomorrow.
ID:	118235   Click image for larger version
ID:	118236   Click image for larger version
Long Nguyen
Long Nguyen is offline        Reply With Quote Quick reply to this message
Old 10-05-2009, 02:16 AM   #6 (permalink)
that looks nice and tidy Long!
Mikado Heli
Scorpion Motors
Western Robotics RC,
Youth Generation Electronics
Old 11-16-2009, 07:42 AM   #7 (permalink)
rjg
What tape are you guys using under the plates? I see a reference to silicone double sided tape, but I am not familiar with where to get it?
Did anybody end up making pre fab plates for these? I looked on the CustomHeliParts site and wasn't able to find them.
Thanks!
Robert
rjg is offline        Reply With Quote Quick reply to this message
Old 11-16-2009, 08:27 AM   #8 (permalink)
The tape I'm refering to is this;
http://www3.towerhobbies.com/cgi-bin...?&I=LXMRA9&P=7
But any thin, "stiff" tape will do, I recon I would have used regular 3M as you can buy on the hardware store if I hadnt used this one.
Old 11-16-2009, 09:11 AM   #9 (permalink)
rjg
That is what I was wondering about. I have some very thin and stiff 3M tape that should work.
Thank you for the response!
-Robert
Robert
Old 11-27-2009, 09:59 AM   #10 (permalink)
Hi
I use the Jive ESC, with an extra cable power BEC. So which channel should I plug the BEC cable in the Mini V-bar: RX C or RX A. Thanks
Henseleit TDR V-Bar Pyro 700-52 BLS451/251 TP
Logo 500SE V-bar Pyro 600-11 BLS451/251 T
shadowmastervn is offline        Reply With Quote Quick reply to this message
Old 11-27-2009, 10:00 AM   #11 (permalink)
RX-C
Old 12-11-2009, 12:46 PM   #12 (permalink)
For those that want custom made, its not available
http://www.readyheli.com/Custom_Heli...p/chp-l404.htm
