Old 10-10-2009, 03:20 PM   #21 (permalink)
Originally Posted by ollie2893 View Post
Well, let's think: you have a clock-wise rotor whose thrust force is opposed by a counter-clockwise torque vector. If you increase collective thrust you increase counter-clockwise torque ... and your tail should be expected to kick out to the right. That's what you would expect to happen if the tail is "loose", ie the gyro gain is too low.
So opposite recommendation: increase your gyro gain until your tail begins to oscillate around center (swinging left to right). Then back off a notch or two...
I can try it, please check out post above about gyro placement also.
SwePilot is offline        Reply With Quote Quick reply to this message
Old 10-10-2009, 05:56 PM   #22 (permalink)
Gyro placement is not really an issue, with two exceptions:
(1) on an EP helicopter the gyro, like the Rx, is exposed to EMI from the motor, BEC, ESC... Everything on these birds pulses like mad. So you should try to keep the gyro as far away from this as you can. (Easier said than done. Also, I have seen plenty of pictures on HF of birds with all sorts of high freq componentry right under the Rx. I would not do it. But these things seem to fly somehow.)
(2) different gyros bed differently; every manufacturer has their own preferred foamy pad. In my experience, mainly gathered in the NP domain, pay up for the original part. On EP people seem a little more relaxed (fewer vibes)...
ollie2893 is offline        Reply With Quote Quick reply to this message
Old 10-10-2009, 11:58 PM   #23 (permalink)
I use the original foam pad and its isolated.
But hey, the torque tube shaft aint 100% straight, I can feel a some wobbel by just spinning the tail rotor by hand and holding the torque tube.
This gotta be it right?
Old 10-11-2009, 03:18 AM   #24 (permalink)
Chances are that you fitted the end bearings too tightly whereby squashing the tube itself, which responds by buckling (slightly) which leads to a wobble. At high rotational speeds, this wobble will "snap" from side to side every so often, and that will prompt a disruption. Which is indeed quite likely the source of your travails...
Old 10-11-2009, 04:07 AM   #25 (permalink)
Might be so, I have also wrecked 3 pair of tail blades
Old 10-11-2009, 04:59 AM   #26 (permalink)
Hm ... not sure how a wobbling TT would have contributed to that though...
Old 10-11-2009, 07:15 AM   #27 (permalink)
Can you advice how to fit the bearings and exacty which bearings when i reassemble, Iam ordering a new TT shaft.
Thanks!
Old 10-11-2009, 08:10 AM   #28 (permalink)
Sorry, my friend, I fly a belt. I only read about this problem on some other thread. Just make sure that the assembly is not too tight; that the tube does not end up being pushed together by the tail and front pinions. I guess you have some slop in the tail drive assembly, no? That thing, rather bizarrely, has no fixation points. So just make the mesh on both ends sit a little looser...
Old 10-11-2009, 04:35 PM   #29 (permalink)
Possible remedy: bought 2x torque tubes, new bearings, castle creations ICE 75A ESC.......
Old 10-12-2009, 03:43 AM   #30 (permalink)
The poor plastic tail servo mounts moves back and forth when the servo works.
I ordered aluminum units. Could be a reason two.
Old 10-12-2009, 04:35 AM   #31 (permalink)
Yes, that's awful BUT ... in my experience, this is indicative of the tail pitch assembly being stiff! Forget about the servo and try to push the control rod by hand. Does it move willingly? If you are flying the standard push rod, there's a good chance that it rubs against the guides. I have never been a fan of these assemblies. I prefer to fly the guide-less carbon pushrod (a la Quick UK for Raptor 50). TT and servo wobbles will all be contributors to the twitch...
Old 10-12-2009, 04:42 AM   #32 (permalink)
Its very smooth actually!
Can you link me to those items?
Old 10-12-2009, 05:22 AM   #33 (permalink)
This doesn't compute. Where does the torque come from that bends the plastic tail servo holder?
Do a Find for "RT24" on here: http://www.modelhelicopters.co.uk/ac...aptor3050.html. It's pretty much the bottom of the page. The complete kit even comes with a flash new alu servo holder, like you wanted.
Old 10-12-2009, 05:24 AM   #34 (permalink)
PS: Being the cheap-skate that I am, I obviously ordered only RT241+RT242
Old 10-12-2009, 05:29 AM   #35 (permalink)
Thanks for the link.
No its more that the servo isnt attached good to the plastic, not the plastic itself, but anyways alu = good.
Old 10-12-2009, 05:54 AM   #36 (permalink)
I have had a similar problem on my new 600ESP - adjusting the gyro gain made no difference. I found a bad lower main bearing - the inner race of the bearing had been spinning on the main shaft causing bad scoring of the shaft, the bearing and also causing inteference that I believe the gyro must have been pickin up (I don't know this for sure beccause I am waiting for the new parts).
When I built the heli I was satisfied that I had tightened up eberything nice and straight but maybe I was a bit off causing this to happen?
Looking at the scorong on the inside of the bearing and the main shaft it must have got pretty hot and made a lot of noise.
Fingers crossed this was my problem!..........and maybe yours...?
T-Rex 550E V2 / DS-610 / GY401 / 620 / CC ICE 100
T-Rex 600 ESP / DS-610 / GY401 / 9254 / CC ICE 100
T-Rex 700E F3C / DS-610 / GY520 / 650 /CC ICE 2 HV 120
jonp is offline        Reply With Quote Quick reply to this message
Old 10-12-2009, 06:04 AM   #37 (permalink)
jonp: was it the lower main axle bearing?
Old 10-12-2009, 08:15 AM   #38 (permalink)
Yes, the lower bearing.
Looking closely at the bearing - I removed the dust seals - the bearings 'look' OK, but something is wrong to cause the inner to turn on the shaft.
Old 10-12-2009, 08:52 AM   #39 (permalink)
Here is a picture for you!
Name:	600 shaft.jpg
Old 10-12-2009, 08:57 AM   #40 (permalink)
Very interesting, I will disassemble mine today!
Thanks alot.
