Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Old 06-30-2007, 01:41 PM   #21 (permalink)
I'm also not keen about flying over salt water marsh,
Water's bad enough, but salt water of any kind & my heli would stay in the Truck!! I see on a daily basis what effects salt can cause, No place for Heli's!!
and one more thing, "Don't be Afraid!"
jontherooster is offline        Reply With Quote Quick reply to this message
Old 10-29-2008, 09:19 PM   #22 (permalink)
PaulH & All
Many thanks for the info guys! I recently bought a G23 ( which I guess I messed-up by buying it!) and I plan on putting it in a older X-Cell 60. I too look forward to some operational tips and any information on Gassers!!
Thanks!!
Brian
Brian (ViperDraggs) Jones
Every Person is my Teacher So I May Learn From Them
Thanks to all the Military People.
ViperDrags44 is offline        Reply With Quote Quick reply to this message
Old 01-18-2010, 12:33 PM   #23 (permalink)
Default Nitro or Gas engine
hi
as its a FAQ i wanted to know if you wanna buy kit for gas heli like raptor 30 size how u know the engine is gas or nitro ,reason i wanna get a gas heli but looking on many web sites they dont mention about what engine it is gas or nitro ?????????
mastmalang70 is offline        Reply With Quote Quick reply to this message
Old 01-18-2010, 01:09 PM   #24 (permalink)
Most GASOLINE powered heli's will state a gas engine or petrol engine.
There is nothing in a 30 size that is gasoline powered.
Chris D. Bergen
Bergen R/C Helicopters
cbergen is offline        Reply With Quote Quick reply to this message
Old 02-07-2010, 12:48 AM   #25 (permalink)
If it has an engine it's probably a nitro, unless it says GAS, GASSER, PETROL.
i.e. if you can't tell, it's nitro.
-Aaron
Aaron29 is offline        Reply With Quote Quick reply to this message
Old 02-23-2011, 07:53 PM   #26 (permalink)
hi i am wondering what to use in my spectra g. i was looking at a zenoah 231which delivers approx 2.2 hp or using a hanson 260 puh pro heli engine whick will deliver 4 hp with a tuned pipe. im trying to figure uot do i need all that extra power or not since this heli will be my trainer.
bull1965 is offline        Reply With Quote Quick reply to this message
Old 02-23-2011, 11:54 PM   #27 (permalink)
Default Too much power
Bull1965,
As long as you're not adding too much weight, a little extra power is NEVER a bad thing. I've done R/C for around 20 years now and many times have been saved by having extra 'punch' out power. You may not use it right away, but you will one day so you might as well have it available.
Ken.
baseclass is offline        Reply With Quote Quick reply to this message
Old 03-22-2011, 03:43 PM   #28 (permalink)
Anyone looking for a way to calculate their oil/gas mixture, there's a cup I used during my motocross racing days. It's called "Ratio Rite". It cost like $5 and you should be able to find one at any Honda/Yamaha/Kawasaki dealer that sells dirt bikes, or easily online.
It has lines on it to show you how much oil to use for different ratios per gallon. Makes it super simple.
rockinar is offline        Reply With Quote Quick reply to this message
Old 03-22-2011, 06:42 PM   #29 (permalink)
Quick and easy formula to remember.
Just divide units per galon or liter by the desired ratio.
Example: let's say you want to mix a 40:1 ratio
40:1 would be 128 divided by 40 equals 3.2oz oil per galon
40:1 would be 1000 divided by 40 equals 25ml oil per liter
25:1 would be 128 divided by 25 equal 5.12oz oil per galon
25:1 would be 1000 divided by 25 equals 40ml oil per liter
Sure the ratio right mixers work great but if your without one you can figure out any ratio out. If you want to mix half galon or liter just use 64oz or 500ml divided by the desired ratio.
I may not be good at much but when it comes to RC Helicopters....Well im not much good at them either.
Trex 450 Pro/Trex 600ESP, FBL Skookum 720
Trex 700G Helibug Gasser, FBL Skookum 720
Greatsteaks is offline        Reply With Quote Quick reply to this message
Old 03-30-2011, 03:52 PM   #30 (permalink)
40:1 = 3.2oz per gal.
kopterkat is offline        Reply With Quote Quick reply to this message
Old 03-30-2011, 04:48 PM   #31 (permalink)
That's what i wrote.
Lol, after I just edited it. Thanks for picking that up!
Old 04-09-2011, 05:40 AM   #32 (permalink)
My g270rc wont hower with the curve blow.
N (1550): 0, 20, 22.5, 25, 100
After i set the curve 0, 25, 50, 75, 100 it's like normal.
It looks like the carb response goes linear. Any ideas?
Suat
Trex 700 Gasser
FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX290TT | SG | RJX Gas muffler (modded)
Trex 600 Gasser FBL | HeliXHeli conv. | OS GT15HZ | iKon | Homemade onboard generator
Azalin is offline        Reply With Quote Quick reply to this message
Old 04-09-2011, 07:07 AM   #33 (permalink)
When you say it won't hover what do you mean? What does it do?
Old 04-09-2011, 07:45 AM   #34 (permalink)
With this curve:
The main rotor starts to turn in the 3/4 throttle position. In the mid stick (2/4) no turns. And the heli is hovering almost in the full throttle. Nothing more.
The needles
H 1.75 turns
L 1.5 turns
Almost finishing the break in.
Suat
Trex 700 Gasser
Old 04-09-2011, 08:18 AM   #35 (permalink)
I think you need to adjust your linkage and endpoints. Take the aircleaner off and watch the butterfly for full movement from 0 to full throttle.
Old 04-09-2011, 08:57 AM   #36 (permalink)
I did. The butterfly opens perfectly normal from 0 to 100. In 0 throttle, the butterfly is almost close. In full throttle, it is full open. Like my nitro. Is this wrong?
Suat
Trex 700 Gasser
Old 04-09-2011, 10:01 AM   #37 (permalink)
Suat
Trex 700 Gasser
Old 04-09-2011, 10:10 AM   #38 (permalink)
Throttle curve 0,25,50,75,100
Suat
Trex 700 Gasser
Old 04-09-2011, 07:02 PM   #39 (permalink)
Maybe you wore out your clutch liner?
Old 04-09-2011, 07:06 PM   #40 (permalink)
Originally Posted by Azalyn View Post
With this curve:
The needles
H 1.75 turns
L 1.5 turns
What does " N(1550)" mean? I assume the "N" means normal mode but what does the 1550 mean? Head rpm set in the governor? If your governor is on and set to 1550 rpm the throttle curve set in your tx does nothing and the governor controlls your servo. If that's the case check your clutch.
Human Verification
