Old 05-31-2010, 10:34 AM   #201 (permalink)
The Capi
Its just alittle beefier, we had a few crack from engine vibrations. I ended up replacing mine because the new ones just look so cool. I believe the item is still considered an optional upgrade and thus won't be supplied in new kits.
Old 05-31-2010, 10:49 AM   #202 (permalink)
dam u guys now i have to buy this upgrade! lol im looking at mine now can i can see how it can help with the more surface area
burton8012 is offline        Reply With Quote Quick reply to this message
Old 05-31-2010, 10:58 AM   #203 (permalink)
I have it on mine, it's holding up great so far!
One other thing... that servo wire you have penetrating the left frame in the cutout... Clyde Fox suggested that I put a small piece of shrink on the wire at that point. I did so and it's working out great! I know you mentioned wrap, but that's a spot that might chaffe really quickly no matter how you sand the frame. Just a thought.
Scott
KBDD Team Pilot ):>
Old 05-31-2010, 11:03 AM   #204 (permalink)
Team Taco VP
Scott
Yes thanks. I did fix that already. While doing the final go over I did not like the looks of that wire in the frame. Even though I sanded all the edges of the frame including in the openings so it did have any sharp edges, I agree it did look like a chafe point. I fixed it by splitting a little fuel tube length wise and tie wrapped it around the wire.
Good point! If anyone needs a picture of what we are talking about let me know and I will take one.
Bob
Old 05-31-2010, 12:23 PM   #205 (permalink)
Cool, Bob...
I'm using a different engine than you, a YS-56 is what I have, but one thing that happened on the first flight on mine was chaffing on the tank. I rounded the frames really good for the tank mount, yet it chaffed. I caught it quick and put some split fuel line between the frame and the contact points, and it's working out just fine. I'm thinking that at times the YS-56 may over pressurize the tank just slightly. I don't know if it will happen with your engine, though. The Outrage folks havent mentioned it as an area of concern though, so your mileage may vary. LOL! I had to write that. ;0
Scott
KBDD Team Pilot ):>
Old 05-31-2010, 12:26 PM   #206 (permalink)
ohh crap good thing u guys brought this out i just looked at my tank and in the middle of the tank on both side i see the frame eating into my tank.. i think it can be saved just gotta look closer
Old 05-31-2010, 10:05 PM   #207 (permalink)
Team Taco VP
Yes because of the large positive pressure the YS uses with the check valve the tank expands a LOT... Had the same problem on a few helis like this design with that pressure system.
Alas my maiden flight did not go well today. Because I had an early KME engine I got 30 seconds of hover and the con rod bushing let go on the crank journal and.... done... KME is bringing me a new one tomorrow since he lives right near me. Awesome...
Anyway maiden will again be attempted this coming weekend
Bob
Old 05-31-2010, 10:10 PM   #208 (permalink)
The Capi
You pulled an Austin ! (aka Team Tail in).
Old 05-31-2010, 10:15 PM   #209 (permalink)
Team Taco VP
Huh?
Bob
Old 05-31-2010, 10:18 PM   #210 (permalink)
I thought it was something perculiar to that engine. It's nice to have confirmation, now. Thanks, Bob.
Sorry about your engine. It's cool that KME is taking care of you, though.
Hope your back is getting better, sir.
Scott
KBDD Team Pilot ):>
Old 05-31-2010, 10:19 PM   #211 (permalink)
The Capi
He killed like 3 engines on his Velocity in a matter of about 2-3 weeks.
Old 05-31-2010, 10:29 PM   #212 (permalink)
Team Taco VP
Well I have never in 30+ years of RC ever blew up an engine... I wore them out.. TRUTH..... But this one must have had some problem from the get go as seriosuly... It was smoking way too rich and lasted about 30 seconds then BAM.... shut down. When I went to restart it I could hear something was not right. Pulled it apart when I got home and the bushing on the con rod was gone and the rod where it connects to the crank journal was egg shaped. Beauty is after tearing it down all parts look pretty good! All I need is a new con rod!
So thats the tip guys... when something ain't right DO NOT try to keep running it especially an engine. Tear it down and see whats up! Otherwise its MORE COST in parts!
Bob
Old 05-31-2010, 10:34 PM   #213 (permalink)
Team Taco VP
Also FYI... just my opinion but Outrage needs to make the washout pins a little longer. Twice while the heli was powered off the swash dropped and dislocated the washout pins. When that happens when you power up the next time, the servo strain is like leaving your blades in the blade holder! If the pins were like 2mm longer the swash could drop to the frame, bottom out, and the washout would not come out of the pins. Just an observation since it happened to me twice today.
Many of the newer servos today have no force when powered off and the swash can drop all the way PAST your radio settings. This is not new to this heli or others! That is why I found the problem so fast. BUT because of the outrage design and unlike other helis, making the pins a little longer would prevent that yet not interfere with the swash plat at full pitch.
Just some 3 cent input from me to Outrage
Bob
Old 05-31-2010, 10:37 PM   #214 (permalink)
The Capi
I might be crazy but i think the 2nd+ generation kits have longer pins.
Old 05-31-2010, 10:40 PM   #215 (permalink)
Hey now HFG! That isnt fair. Everyone makes it sound like I leaned them out to destruction or something... and love to exaggerate the situation. It was 2 times and both were just bad luck.
NR57 - Despite there being thread lock, the nut that holds the throttle arm on, backed out... and it rolled to 100% throttle until the tank had not a single drop of fuel in it.
YS56 - The hose on the tank blew up (its that high class dubro silicon stuff) on the pressure release and shot fuel all over the damn thing .. I landed once I noticed there was no smoke coming from the pipe but had to wait for a planker to dead stick in as well.
By the way.. I beat that damn poll with this weekend's fun fly(LOL!)
https://www.helifreak.com/showthread.php?t=206921
-Austin
H
elifreak Special Bacon Awareness Committee
Wurger is offline        Reply With Quote Quick reply to this message
Old 05-31-2010, 11:25 PM   #216 (permalink)
bob i have a message from our buddy .. YOU SPIN ME RIGHT ROUND!
Old 06-01-2010, 11:51 AM   #217 (permalink)
Smile Maiden flight
Bob,
Maiden flight, maiden flight. PLEASE !
Eduardo
GOBLIN 500 / T-REX 450 V2 SPORT - HITEC AURORA 9
Eduardo is offline        Reply With Quote Quick reply to this message
Old 06-01-2010, 12:20 PM   #218 (permalink)
Team Taco VP
I tried... read my post about 4 up. Had engine troubles....
Bob
Old 06-01-2010, 09:31 PM   #219 (permalink)
Hey BOB hows about a rebuild video?????
I only crash when i get to excited, and try something new, or when something technical goes wrong (hey, that's my fault to, i do the setup and pre-check....)
dxtarl is offline        Reply With Quote Quick reply to this message
Old 06-01-2010, 11:46 PM   #220 (permalink)
Team Taco VP
Funny you should ask! I am going to do one. KME engine is different than most but I am going to do something! Jerome from KME just stopped by and dropped of the parts I need. Turned out I had a problem crank shaft and he knew instantly the problem. My desire is to get this engine going to do the maiden on this ASAP but ater.... now that I have 2 engines... a rebuild video is EXACTLY what I was thinking
Bob
