Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > E-Sky Helicopters > HBFP V1/V2
HBFP V1/V2 E-Sky Honey Bee V1 & V2 Fixed Pitch
Old 01-02-2010, 08:03 AM   #21 (permalink)
Update for VL. Just test flown the hacked Bee with K2 esc and all is fine thanks.
I used the solderless method and the conversion was not without it's moments as at first the main motor wouldn't spool up (X380). Traced this to an internal break in the armature so binned it. I had a spare brand new X380 which when I came to fit it had been supplied with a 2.3mm bore pinion not 2.0mm. Xtreme quality control ??? So retrieved the binned motor and swapped over the pinion after which all now ok .
Great money saving hack thanks
Cheers, Bugster
Bugster is offline        Reply With Quote Quick reply to this message
Old 01-02-2010, 08:21 AM   #22 (permalink)
Great job Buggy!
Happy you solved one of the many flaws of the Xtreme Crap motor. If it was anyone else they would flog me blaming a faulty tutorial.
Every time I crash I wonder, why didnt I get into RC tanks.
Viet-Lama is offline        Reply With Quote Quick reply to this message
Old 01-02-2010, 12:28 PM   #23 (permalink)
OK I'll blame you
Cheers, Bugster
Old 01-03-2010, 07:29 AM   #24 (permalink)
Thanks , I feel much better now
Old 05-21-2010, 11:06 AM   #25 (permalink)
hey everyone bugster sent me over this way and i gotta thank you for this awsome hack VL, so i noticed in the tutorial you plug your motor into the external ESC. Will i have to change the connection from the ext. ESC to a jst to be able to run the stock motor (i have a V2). If so could you link me to any tutorials that might be available that would be awsome, also any splicing tutorials which i think you mentioned earlier in this thread you were going to make.
cheers
mkristian is offline        Reply With Quote Quick reply to this message
Old 05-25-2010, 12:19 AM   #26 (permalink)
You dont have to change the connection to a JST but it makes it quick and easy every time you want to change motors that use JST connections such as the X380 and stock motor. A lot of other companies make 370 / 380 motors and they also use the JST. If you dont have one you can simply splice the wires together and wrap them with electrical tape
I have a sticky on a solderless LBA connection which ive used that method on other connections which may help you
Old 05-25-2010, 02:33 AM   #27 (permalink)
Thanks for the kind words my friends.
I figured with all the new HoneyBees bought on Christmas I needed to get this tutorial finished.
I was actually going to do a mini "sub tutorial" on splicing the two battery leads without having to touch a knife or snippers, the only thing you need is heat shrink.
Ill add it another day if you guys want.
Hi VL,
Did you get this tutorial done in the end?
Just got a King2 ESC and motor on order today... For when my 4in1 goes pop from the CP3 motor I installed the other day...
nickcorr is offline        Reply With Quote Quick reply to this message
Old 06-10-2010, 12:50 AM   #28 (permalink)
Originally Posted by nickcorr View Post
Hi VL,
It did go pop....
King ESC now installed and back in the air!! Made up a little Y cable for the power connections from some JST connectors I had lying around.. Also soldered a JST onto the ESC so that it works with my HB motors..
Thanks for the help VL!!
Now have a HBFP V2 with CP3 main and tail motors...
Old 06-10-2010, 02:27 AM   #29 (permalink)
Very cool Nick and smart move pre ordering the ESC
My V2 4in1 went wacko yesterday and ended up catching on fire
Dropped in the King 2 ESC with King 2 motor that I created for this tutorial and all is good in the hood
Old 07-06-2010, 03:37 PM   #30 (permalink)
Hi VL
Great tut that you did there.
I have a question though.
I have a stock 4in1 that spins the tail motor as soon as the battery is plugged in.
Do you think this mod would fix my broken 4in1?
Be worth a go if it would
chilledbeer is offline        Reply With Quote Quick reply to this message
Old 07-07-2010, 01:34 AM   #31 (permalink)
The ESC replaces (bypasses) the 4in1s internal main motor ESC. Your tail motor runs off a different ESC so the tutorial will not help you. Sounds like maybe your pro pot is turned too far up causing the tail motor to spin early. Could be other factors as well, need more info.
Old 07-07-2010, 11:09 AM   #32 (permalink)
Thanks for the reply VL. I already replaced the 4in1 but kept the old one. Thought I might be able to resurrect it when I saw your tut.
Old 10-11-2010, 11:04 AM   #33 (permalink)
So doing brushless main motor would be the same method? I have 2 blown 4in1 would like to conver to brushless.
vtran is offline        Reply With Quote Quick reply to this message
Old 10-11-2010, 06:51 PM   #34 (permalink)
Yuppers.
Sent from my Laptop using "Hunt and Peck"
FLThreeFiveZero is offline        Reply With Quote Quick reply to this message
Old 11-11-2011, 04:51 AM   #35 (permalink)
I am very interested in this mod. Did you use the King 2 motor?
boykintom is offline        Reply With Quote Quick reply to this message
Old 05-01-2013, 02:53 AM   #36 (permalink)
hi vl, i have been follow your tutorial, at the first time my honey bee is awesome, but lately become bad. i follow the solderless system from you, now my honey bee at the fisrt time binding, servo movement went good, and i move the throtle up, and still oke. but if i throtle up into maximum or red led on the 4in1. the motor's die likes there is no power. and the 4in1 look red led blinking.
can you helo me? what did i miss? and what is the matter with my 4in1?
thanks
child is offline        Reply With Quote Quick reply to this message
Human Verification
