Old 01-07-2010, 01:11 PM   #1 (permalink)
Default Rhino Gear Steel Motor Pinions?
does anyone use these motor pinions? i have just placed an order for a set of these and just want to know if these are reliable pinions.
thanks
Trex 550E - Mini Vbar
Goblin 630C - Vbar
JR X9503
lildjloop is offline        Reply With Quote Quick reply to this message
Old 01-07-2010, 01:20 PM   #2 (permalink)
I have the Rhino pinion on my 500. Works good for me. No problems yet. Seems quiter, too, but that may be just my imagination.
T-Rex 450 SE V1, HS65MG, 9650, 325 CF, AR6100, 2200 FlightMax, 430XL/BL35X, GY401 ...SOLD
T-Rex 500ESP...SOLD
DX7...Still for sale
M.A.A.C. 78596 www.helicalgary.com
Ex President - Calgary RC Heli Club
helijack is offline        Reply With Quote Quick reply to this message
Old 01-07-2010, 01:21 PM   #3 (permalink)
Love the Rhino pinions! Have them in all my helis... they last forever.. and reallly run quiet.. you will notice a difference immediately.
Old 01-07-2010, 01:23 PM   #4 (permalink)
are u running this pinion on the stock motor? if so what tooth are u running? im new to the 500 and im trying to get some ideas on what to run here.
thanks
Goblin 630C - Vbar
JR X9503
Old 01-07-2010, 01:46 PM   #5 (permalink)
rhine=good=buy
500 stock motor=13T
trex 450pro
trex 500 1400/bl60g, 15t, 6s, gp750/9257, 9650mg's,TT
trex 600E 600xl/bl75g, 6s, 10t, 750/9256, hs5625mg's, TT
trex 600N OS50hyp, hitori, mgp, 9451'sgy520/9256, TT
trex 700N 91sz, hitori, g600, 610's, 611/9256, TT
outhouse is offline        Reply With Quote Quick reply to this message
Old 01-07-2010, 01:47 PM   #6 (permalink)
rhino pinion all the way for me, the stock pinions look flimsy next to a rhino !!
i used a 13T on a stock motor/esc setup with flybar and 100% throttle, 6s 3000mah 30-40C lipo.
then i mounted a 1600Kv scorpion + 75A esc with flybar and 95% throttle same lipo as above.
now i went flybarless on the same setup and it seems that i need less throttle so i'm flying 85% throttle and i'm thinking of using a 12T pinion to go to 95 or 100% throttle(rhino pinion offcourse).
SAB Goblin 630 12s Vbar
mCP-X + 130X + mCP-X brushless
DSX9
www.rs-modelstore.be follow us on facebook !
flybar-les is offline        Reply With Quote Quick reply to this message
Old 01-07-2010, 02:44 PM   #7 (permalink)
if i had a stock 500 pinion I would wear it out first if possible. nothing wrong with the stock 500 pinions. if i needed a gear change then ya pop a rhine in from helidirect there pretty cheap there
if I had a brass pinion like on my old 450's then its great upgrade.
trex 450pro
Old 01-07-2010, 03:14 PM   #8 (permalink)
Loved 'em on the 450... quieter indeed (than my worn stock pinion) last long time, no issues.
PRÔTOS 500 Plastic, Logo 550SX/600SX, PRÔTOS Max2 up and flying!
Team MSH USA, Team Cyclone, Team Xnova
trickybit is offline        Reply With Quote Quick reply to this message
Old 01-07-2010, 04:45 PM   #9 (permalink)
Is there a rhino pinion that fits the stock blade 400 motor? The one with the step in the shaft.
Woody_99 is offline        Reply With Quote Quick reply to this message
Old 01-07-2010, 06:12 PM   #10 (permalink)
Yes.. I used it on my old B400. I don't recall the shaft diameter though...
http://www.helidirect.com/advanced_s...2b174e&x=0&y=0
Old 01-07-2010, 06:39 PM   #11 (permalink)
How did you deal with the step on the motor shaft? Did you use the pinion that fit the larger or smaller section?
Otherwise, I can't tell from the description on any of the Rhino gears that they are stepped.
Old 01-07-2010, 06:46 PM   #12 (permalink)
No.. any pinion with a grub screw works.. the flat is just for the grub screw.
Old 01-07-2010, 08:23 PM   #13 (permalink)
On the Eflite motor shaft, the portion near the motor is a larger diameter than the diameter towards the end. The Eflite pinions have the same step in them.
I know what you mean about the set screw, but that's different than what I'm talking about.
Old 01-08-2010, 09:51 AM   #14 (permalink)
Hmmm... that different than my old B400's motor.. I just looked at it... the pinion on mine is the same diameter the whole way.. with just one little flat spot in the middle. I guess they changed the design.
Old 01-08-2010, 11:31 AM   #15 (permalink)
I have the rino on my copterx. no problems, and less noise.
helifuel is offline        Reply With Quote Quick reply to this message
Old 01-08-2010, 01:00 PM   #16 (permalink)
Rhino +1
The come in 3mm and 3.17mm from what I have seen and I have the complete set from 11t ~13T (2 of each )
Carl
Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544
Starcruiser is offline        Reply With Quote Quick reply to this message
Old 01-08-2010, 01:07 PM   #17 (permalink)
Originally Posted by Starcruiser View Post
The come in 3mm and 3.17mm from what I have seen ...
That would mean they would not work on the new 3.5mm Align 430SP and 450M motors.
I use the Align hardened steel pinions on my 430SP, and just recently a pinion tooth broke off. However, I had flown that pinion on a motor with a broken bearing for a month. So that pinion got literally hammered millions of times, before it finally gave.
Tail boom is offline        Reply With Quote Quick reply to this message
Old 01-12-2010, 08:41 AM   #18 (permalink)
look here I am not seeing a 3.5 for a 450 class motor, Align must be trying to specialize their parts.
http://www.helidirect.com/motor-pini...c-1_78_513.hdx
Carl
Old 01-12-2010, 11:18 AM   #19 (permalink)
i`d like to know which rhino gear you used on the stock blade 400`s 420 motor as well.
i bought every rhino gear, even the one`s that use to be in the blade400 part`s listings, none had the step down from the 3.17 to 2.3 that the 420 motor`s shaft has.
as far as are the gear`s good? so far so good, i`ve been running them about 6 month`s now.
are the quiter? havent noticed any difference in the sound, and i fly indoor`s every day.
now i have noticed ALOT of main gear dust all over the inside of the frame.
i use the proper 0.5 mod pinion`s.
Crashs come easy Patience does`nt
retired the 3 year old blade400
fast400 is offline        Reply With Quote Quick reply to this message
