Go Back   HeliFreak > R/C Simulators Support > Phoenix Flight Sim
Phoenix Flight Sim Phoenix Flight Sim
Old 12-07-2014, 03:12 PM   #221 (permalink)
Originally Posted by dwahid View Post
I've had the Phoenix sim for several years and gave not been able to set it up correctly with a spektrum dx9. The problem is I'm always in idol up mode no matter what I try to do. I have calibrated several times and I'm not able to solve this. Can anyone please pm instructions or provide me with a contact number that I can call to sort this. I've tried tro call horizon hobby several times with no help.
You need to turn the governor off on models you want to use normal curve.
Even though the original post was for Phoenix 3, it still holds today.
Originally Posted by TheBum View Post
Now you can go to work on the sim model. Try to select a "3D" or "intermediate" variant of the model because a lot of the setup will already be done for you. The following are the important things to make sure are set up in the sim (not in the radio):
  • The throttle, pitch, aileron, and elevator curves should be set up to be linear and expos should be turned off:
    System>Your controls, click on your TX, click on Edit, and click on the button in the Curve column
  • The idle-up and throttle hold functions should be turned off and remain off:
    System>Your controls, click on your TX, click on Edit, and select "Unmapped" in the Input column next to Throttle Hold and Idle Up
  • The collective pitch range should be set up to be symmetrical around zero pitch and to suited to your tastes (e.g. +11 and -11):
    Model>Edit, click on Detailed if running Phoenix 3, click on Main Rotor, and edit the Minimum pitch, Mid pitch (set to 0.0), and Maximum pitch
  • Optionally, if you want to use the throttle curves with no governing, turn off the governor:
    Uncheck the "Rotor governor enabled" option. Location of option:
    Phoenix 2.x: Model>Edit, click on Main Rotor.
    Phoenix 3: Model>Edit, click on Detailed, open the Rotor governor menu.
Old 04-12-2015, 12:44 PM   #222 (permalink)
Default swash type calibration issues
So im trying to calibrate my dx6i to phoenix 5. Ive combed the forum, and unless ive missed it(which is possible) i havnt seen someone with this problem yet. After i do the full circle rotation of both sticks i get three bars moving with the left stick. It says if that happens then the swash setting isnt on 1servo90, yet mine is on 1 servo 90. ive tried multiple times starting from scratch with the same results each time. Im sure its just a simple setting that ive missed, im so new im not putting anything out of the question.
loneranger6886 is offline        Reply With Quote Quick reply to this message
Old 04-12-2015, 06:00 PM   #223 (permalink)
Under System > Your Transmitter there should be a "Calibrate" button.
If you have a transmitter calibrate model (you should), you can then calibrate all channels. I use a + pattern on the sticks instead of a circle. (There are reasons behind this due to how transmitter gimbal potentiometers are interpreted).
All channels should then go from bottom to top.
Once you have calibrated, go back to your regular sim model in your transmitter.
Old 08-08-2015, 09:06 PM   #224 (permalink)
How do u get idle up and throttle to work on 9503?
crazy Jim is offline        Reply With Quote Quick reply to this message
Old 01-05-2016, 04:02 PM   #225 (permalink)
how do you hookup the with the Vbar Vcontrol with the wireless and without the wireless?
Following Jesus !!!!! My Lord, He Never changes!
1#SAB RAW Scorpion Tribunus V2 300A ,
NEO-Vcontrol Touch,The only Way to Fly!
2#SAB Kraken 700 Scorpion Tribunus V2 200A
Helicrazy2 is offline        Reply With Quote Quick reply to this message
Old 02-17-2016, 01:55 PM   #226 (permalink)
+1
Jim Hansen is offline        Reply With Quote Quick reply to this message
Old 05-14-2016, 07:56 PM   #227 (permalink)
Wink
can get lift off on my helicopter, please help. I set it up as they said and it wont work. Im using a Spektrum DXe
promtber is offline        Reply With Quote Quick reply to this message
Old 05-14-2016, 10:18 PM   #228 (permalink)
Reverse pitch channel in Phoenix, sounds like you're full negative.
HAL9KPCM is offline        Reply With Quote Quick reply to this message
Old 07-19-2020, 08:12 PM   #229 (permalink)
Default Phoenix USB interface
I keep getting a mesage that my USB interface in not being detected by Phoenix. I'm using a Spektrum WS2000 USB. Will this sim work with a Spektrum wireless USB or must I use the wired USB for Phoenix?
Zip Collins is offline        Reply With Quote Quick reply to this message
Old 08-19-2020, 07:22 AM   #230 (permalink)
Default phoenix dongle
Does the dongle for Realflight work for Phoenix
Papa Jim is offline        Reply With Quote Quick reply to this message
