Old 01-29-2010, 10:59 AM   #1 (permalink)
Arrow Crash cost comparison part II
OK... I added more helis. Every crash is different.. but these are some common parts that need replacing. All parts are stock. From Helidirect or Amain Hobbies.
WITH MAIN BLADES
WITHOUT MAIN BLADES
Old 01-29-2010, 11:13 AM   #2 (permalink)
I would change the 450 pro main blades to the wood 325 pro @ $12.50. Then it gives a better comparison to the Blade 400 which you have priced with wood blades.
Interesting comparison.
dhc8guru is offline        Reply With Quote Quick reply to this message
Old 01-29-2010, 11:13 AM   #3 (permalink)
I know.. many ways to save money.. but I just went straight stock to keep things fair.
Old 01-29-2010, 11:19 AM   #4 (permalink)
interesting that the trex 600 costs less to fix than the 500,then I suppose the belt drive 500 would be less than the esp
henry
msh protos,trex 500esp
henryd123 is offline        Reply With Quote Quick reply to this message
Old 01-29-2010, 11:20 AM   #5 (permalink)
I know. Crazy.
Old 01-29-2010, 11:24 AM   #6 (permalink)
I still say this would paint a better picture if you used more scienceness about it.
Main blades isnt really a good variable because of the range. It doesn't make a good independent variable nor dependent. Same with tail blades.
First what needs to be agreed upon are the standard crash parts that are proprietary to a model (meaning not blades as you can go anywhere for quite the selection of the same exact thing).
Wurger is offline        Reply With Quote Quick reply to this message
Old 01-29-2010, 11:27 AM   #7 (permalink)
Opps.. I need to fix the 600. Forgot the TT gears etc
Old 01-29-2010, 11:34 AM   #8 (permalink)
How come none of these comparisons ever include the main bearings and grip bearings? I generally always see most of them getting trashed in a crash.
I wish my 600n's crashes cost as much as the 600esp in the spreadsheet. I generally see double the cost. I wonder if it's cause the Align main blades are almost 2x the listed in the sheet.
kidphc is offline        Reply With Quote Quick reply to this message
Old 01-29-2010, 11:35 AM   #9 (permalink)
Because bearings are dirt cheap! Just add $6 for every heli if you want to replace all 8 or so shaft bearings.
Old 01-29-2010, 11:37 AM   #10 (permalink)
Also people dont usually go to the heli maker for the bearings .. just like with blades the aftermarket selection is usually used and varies quite a bit.
Old 01-29-2010, 11:41 AM   #11 (permalink)
I get these... AWESOME bearings. Dirt cheap!
http://www.helidirect.com/advanced_s...abec-3&x=0&y=0
Old 01-29-2010, 11:41 AM   #12 (permalink)
I like my 450SE, /w gorrila gear and CF boom. What a tank. Main blades, main and feathering shaft, maybe the gear, one hour and back together.
Steel Butcher is offline        Reply With Quote Quick reply to this message
Old 01-29-2010, 11:51 AM   #13 (permalink)
I guess I'm just lazy
Thanks for the correction on the spreadsheet. It looks a lot closer to my normal crash as far as price.
Old 01-29-2010, 12:05 PM   #14 (permalink)
Of course the one thing that surely quantifies real crash costs isn't part of th comparison. Larger models generally crash less depending upon your flying style.
Jerry Moore, AMA #878954,TARANIS OpenTX- Pantera 600 FB - Pantera .60 FB - Takes a licking and keeps on kicking! KISSAM = Keep It Simple Stupid: Affordable, Maintainable -
Visit Early and often - http://open-txu.org
Jermo is offline        Reply With Quote Quick reply to this message
Old 01-29-2010, 12:05 PM   #15 (permalink)
Align 250 added!
Old 01-29-2010, 01:34 PM   #16 (permalink)
any other requests to add to the list?
Old 01-29-2010, 02:04 PM   #17 (permalink)
Cool thread slyster. The Pro crash cost is similar to what I experienced. I agree that the main shaft and main blade grip bearings are another essential crash replacement. The bearing prices are not that much different though between all the helis, so you could just add roughly the same amount to each one.
This will definitely give a ballpark figure on crash costs for each model, but different models hold up in crashes differently and the parts will be different.
Nice work
8S Trex 500 ESP
ken22golf is offline        Reply With Quote Quick reply to this message
Old 01-29-2010, 02:23 PM   #18 (permalink)
A factor I need to add in is the cost of parts I break during assembly
TowPilot is offline        Reply With Quote Quick reply to this message
Old 01-29-2010, 02:42 PM   #19 (permalink)
Mmmmm, look how that B400 stands out for its low repair cost!! Even cheaper if you get the parts from Heliproz South .
http://www.ronlund.com/Merchant2/mer..._Code=BLADE400
Lloyd Robinson
Fusion 550, Protos 500, Blade 400, Simple T-copter
fishboy77 is offline        Reply With Quote Quick reply to this message
Old 01-29-2010, 04:15 PM   #20 (permalink)
Seems the blades are the main cost difference on all the birds, the parts aren't much more than the others really. Makes me want to find cheap blades for a 600 and get one of those or the outrage 550!
phoenix sim,msr,cx2, blade SR, blade 400-dx7 soon to add trex 500
lifeflight is offline        Reply With Quote Quick reply to this message
