Old 02-23-2010, 06:49 AM   #1 (permalink)
Default Videos: MrMel's VBar 101 instruction videos
Hello everyone!
I have started to make a VBar 101 series where I will try to cover the gap between the official videos, the manual and all questions here on the forum.
It will be a deeper dive into the VBar world, to make sure you get the best out of your VBar.
This will include setup both if you using a preset and if you are setting up from scratch, to try to learn you how to do it correctly.
I will make a dedicated page for these videos later, but for now you have to go into my profile on YT
http://www.youtube.com/user/FredrikMelin72
I put up a page on my site with links to all videos here;
http://heli.dacsa.net/MrMelSite/VBar101.htm
Please feel free to comment.
Code:
Version 5.0
  Episode 1 - What's new in V5
  Episode 2 - Event Log
  Episode 3 - Spectrum Analyzer
  Episode 4 - Part 1 - Setting up a new helicopter.
  Episode 4 - Part 2 - Setting up a new helicopter.
  Episode 5 - Advanced Tail Tweaking
  Episode 6 - Main Rotor Tweaking
  Episode 7 - Control Panel overview
  Episode 8 - Sneak peak on the Full sized Blueline
  Episode 9 - Sneak peak of the v5.1 Pro with Governor
  Episode 10 - General concept of running external governor on electrics
  Episode 10  - Wiring the governor
  Episode 13 - Finalizing governor setup (main screen)
  Episode 14 - Step by Step setting up Governor with separate RX
  Episode 15 - Step by Step setting up Governor with Spektrum Satellites/Futaba SBus
  Episode -- Throttle trim issue, highlighting an issue with throttle trim and which workarounds are available.
  Episode 16 - REPLACED BY EP20 Governor on Electrics
  Episode 17 - Governor: Importance of the throttle curves
  Episode 18 - Covering upgrade to 5.2
  Episode 19 - Connect phase sensor to Mini VBar
  Episode 20 - Governor on electrics - Remake
  Episode 21 - Bankswitching on VBar 5.2
Generic & Version 4.0
 Episode 1 - Regular VBar (generic)
 Episode 1 - Mini VBar (generic)
 Episode 2 - Sensor alignment (generic)
 Episode 3 - Preventing vibrations (generic)
 Episode 4 - Physical ports (generic)
 Episode 5 - Power distribution (specially AR7100R etc) (generic)
 Episode 6 - Mounting on a helicopter (generic)
 Episode 7 - Connecting ESC and PC (generic)
 Episode 8 - Presets and why they are used.
 Episode 9 - TX Calibration including binding of satellites
 Episode 10 - Rudder adjustments including those not using presets.
 Episode 11 - (Part 1) - Swashplate servo setup
 Episode 11 - (Part 2) - Swashplate servo Expert panel
 Episode 12 - Level Swash
 Episode 13 - Main screen - Main rotor
 Episode 14 - (Part 1) - Main screen - Tail rotor Standard parameters
 Episode 14 - (Part 2) - Main screen - Tail rotor Expert parameters
 Episode 15 - Bankswitching (generic)
 Episode 16 - Live view and autotrim view
 Episode 17 - Finalizing the setup (pitch range, swash driver alignment, including how to see it at the field)
 Episode 18 - Tail Precompensation direction
 Episode 19 - Installing driver signing/certify them on 64-bit system
 Episode 20 - (Part 1) - Deeper dive into the Geometry of a FBL helicopter. (generic)
 Episode 20 - (Part 2) - Deeper dive into the Geometry of a FBL helicopter. (generic)
 Episode 21 - Autotrim, How to set it up, and how to do it. (generic)
 Episode 22 - Optimizer, how it works. (generic)
 Episode 23 - Tail Tweaking & Understanding PID - Part 1
 Episode 23 - Tail Tweaking & Understanding PID - Part 2
Old 02-23-2010, 07:45 AM   #2 (permalink)
I saw the shout-out you got from Ready Heli on Facebook. I'll definitely have to check them out.
HeliFreak Support
Graupner MZ-32
Old 02-23-2010, 07:49 AM   #3 (permalink)
Excellent!! Just watched the first one and now I'm going back to watch the rest! Thanks again MrMel
aliboy is offline        Reply With Quote Quick reply to this message
Old 02-23-2010, 07:56 AM   #4 (permalink)
Awesome stuff MrMel ...
Thanks!
Cheers Tim
Mikado L400 6s - 9650, BLS251, Kontronik 60LV V-stabi
Mikado L500se 6s - BLS451, BLS251, Kontronik 100LV V-stabi
krayzejava is offline        Reply With Quote Quick reply to this message
Old 02-23-2010, 08:07 AM   #5 (permalink)
If you'd like to download them and watch them locally, this website works really well:
http://keepvid.com/
HeliFreak Support
Graupner MZ-32
Old 02-23-2010, 08:40 AM   #6 (permalink)
MrMel, you are the gift that keeps on giving!!! Thank you for your tireless support and generosity.
SpeedVision is offline        Reply With Quote Quick reply to this message
Old 02-23-2010, 09:17 AM   #7 (permalink)
Nice Fredrik!
Mikado Model Helicopters
Edge Blades
Big Fil is offline        Reply With Quote Quick reply to this message
Old 02-23-2010, 10:52 AM   #8 (permalink)
Thank you
Slyster is online now        Reply With Quote Quick reply to this message
Old 02-23-2010, 12:28 PM   #9 (permalink)
Sticky! Awesome work MrMel!
- Michalis |OXY Heli|XNova Motors|
...let the flying be second nature!
acidla is online now        Reply With Quote Quick reply to this message
Old 02-23-2010, 12:42 PM   #10 (permalink)
Nice work Mel.
Stick it, or I will
ChrisH is offline        Reply With Quote Quick reply to this message
Old 02-23-2010, 12:45 PM   #11 (permalink)
Done
Episode 11 part 1 & 2 is up (Swashplate servo setup)
Old 02-23-2010, 12:46 PM   #12 (permalink)
Awesome! I think this is the most stickied forum
Old 02-23-2010, 12:47 PM   #13 (permalink)
Yeah, I need to summorize all into one or two posts I think..
Old 02-23-2010, 12:50 PM   #14 (permalink)
PERHAPS around 5-10 of those stickies could be rewritten and merged into one READ ME FIRST sticky?
I don't like seeing so many. Really should be only 4 or 5 max (IMO)
Old 02-23-2010, 12:52 PM   #15 (permalink)
How about unsticking many stickys.. but link all of them in a new super sticky?
Old 02-23-2010, 12:52 PM   #16 (permalink)
Doing it now..
Old 02-23-2010, 01:41 PM   #17 (permalink)
Default Re: Videos: MrMel's VBar 101 instruction videos
Looks great
Old 02-23-2010, 06:30 PM   #18 (permalink)
Very nice Fredrik, they are looking real great.
Old 02-23-2010, 10:48 PM   #19 (permalink)
Thanks Mr Mel, Great Video Guide you have done for Vbar setup
Alan_Chow is offline        Reply With Quote Quick reply to this message
Old 02-24-2010, 12:32 AM   #20 (permalink)
Thanks, I am downloading them now
stuartmp74 is offline        Reply With Quote Quick reply to this message
