Old 12-06-2010, 05:54 PM   #121 (permalink)
these video's are great. I will be setting up a mini-v 5.0 this month, your videos just made my life allot easier.
Atom 500
Atom 6HV
src053 is offline        Reply With Quote Quick reply to this message
Old 01-16-2011, 05:56 PM   #122 (permalink)
Thanks Mr Mel! I followed your videos while setting up a new mini 5 on my T500 and it flew like a champ first flight. A little bit of tweaking and it flies unbeleivably well. I'm getting close to ten seconds, hands off, IN THE WIND!
Without these videos we would all be lost!
Thanks again.
Ken
Lipper is offline        Reply With Quote Quick reply to this message
Old 02-04-2011, 09:01 AM   #123 (permalink)
Added episode 9 and 10 to the first post.
http://heli.dacsa.net
Old 02-04-2011, 10:19 AM   #124 (permalink)
You might want to group them with the 5.0 videos instead of the General and 4.0 videos.
HeliFreak Support
Graupner MZ-32
Old 02-04-2011, 10:21 AM   #125 (permalink)
Can you edit the post, was trying to do that on my ipad and it did not go well
Old 02-04-2011, 10:25 AM   #126 (permalink)
My pleasure. Done.
HeliFreak Support
Graupner MZ-32
Old 02-09-2011, 03:57 AM   #127 (permalink)
How do we connect Align governer to VBar? should I change the connectors on the cable coming from the magnets?
Angler is offline        Reply With Quote Quick reply to this message
Old 02-09-2011, 06:15 AM   #128 (permalink)
You mean align SENSOR for v5.1 governor? Then yes you need to swap + and - cable to follow the label on the vbar
Old 02-15-2011, 01:13 AM   #129 (permalink)
Added the Governor videos (Wiring, Nitro, Electric and settings)
Old 02-16-2011, 08:23 AM   #130 (permalink)
Thanks MrMel for your great work as always
I have upgraded and gov configured my 2 nitro birds already thanks to you, will test fly in a few hours.
One thing worth noting that I didn't see in the vids is that when you configure throttle servo (or ESC endpoints I guess) using the collective channel in the setup II make sure you have a linear pitch curve in the mode you're using in your transmitter. I have less pitch in negative in normal mode to avoid sucking dirt into the heli while spooling up and I had trouble setting enpoints for my throttle servo until I figured that out.
Also I'm using an analog servo for throttle on one of the birds and on the bench at least it's working ok.
As a last note the 8FG you use in the vids has a gov mode where you can set directly RPM instead of %. I couldn't get it to match target RPM as seen in the Vbar. Any idea? That would be neat to input RPM directly into the tx without having to hook up the heli to the PC
Ben
Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251
DX8, RF6
HeliBenj is offline        Reply With Quote Quick reply to this message
Old 02-16-2011, 08:55 AM   #131 (permalink)
It's ONLY for programming/setup you need the linear pitch curve, after your done you can have whatever pitch curve you want.
Not sure that analogue servo is supported though, need to check that.
No, you cannot get Futaba range to match VBar, it's impossible as it's working as it does.
Old 02-18-2011, 04:33 AM   #132 (permalink)
Hi Fredrik,
I'm quite curious which ESC's are suitable for the governor of the v5.1.
Did you test also test with different types ? Are there any differences in performance ? which are suitable and which would you recommend ?
I would need a new one for a new 90 size heli (compass 7hv) and it would be nice if I can buy a suitable one straight away.
thanks
sebastien
666yeti666 is offline        Reply With Quote Quick reply to this message
Old 02-18-2011, 04:37 AM   #133 (permalink)
https://www.helifreak.com/showthread.php?t=279669
Old 02-21-2011, 04:36 PM   #134 (permalink)
Added;
Episode 14 - Step by Step setting up Governor with separate RX
Episode 15 - Step by Step setting up Governor with Spektrum Satellites/Futaba SBus
Episode -- Throttle trim issue, highlighting an issue with throttle trim and which workarounds are available.
Old 02-23-2011, 02:11 PM   #135 (permalink)
Added one important thing of the Governor, I was uninformed how the throttle curves was interacting with the governor, which I highlight in Episode 17 here;
[ame]http://www.youtube.com/watch?v=12uTmerWuMg[/ame]
Old 04-02-2011, 01:46 PM   #136 (permalink)
Default TX Setup
I'm starting from scratch again since getting a HobbyWing 120... While watching the videos again.. and setting my TX throttle ATV's to 100/100. I noticed you mentioned while in the Tx tab to make sure to get -100 to +100 on the throttle throws.. To get this, I have to set my throttle endpoints at 98/110. Is this what I should be doing or leave it at 100/100 and while in the Gov 2 tab make the adj there? Thanks
Grant
GrantL is offline        Reply With Quote Quick reply to this message
Old 04-02-2011, 01:51 PM   #137 (permalink)
Check your throttle ZERO (midstick) most likely you need some there, so your endpoints become like 104/104 instead.
Old 04-02-2011, 02:07 PM   #138 (permalink)
Nope.. The only way I can get -100 - +100 on the Tx Tab and Gov 1 tab at the "Preset channel from Rx" is with 98/110. zero is at midstick also.. Any other thoughts?
Grant
Old 04-02-2011, 02:09 PM   #139 (permalink)
Throttle trim enabled in the radio perhaps, verify that Monitor in the radio is actually 100/100 range.
But if that's Ok, leave it be at those numbers.
Old 04-02-2011, 02:16 PM   #140 (permalink)
I've checked all the settings twice plus .. Checked my throttle curve, 0,25,50,75,100, stick follows those settings.. Thanks for the help..
Grant
