Old 04-02-2011, 03:19 PM   #141 (permalink)
Yes, throttle curve, but you need to look at the Monitor, that's whats going out.
For sample Hover trim etc can interfere, you do not see it in the throttle curve page unless you have a specific "OUT:" in that one.
Just to point that out.
http://heli.dacsa.net
Old 04-02-2011, 03:33 PM   #142 (permalink)
What value can I put on the readout on the Tx Tab and Gov 1 tab at the "Preset channel from Rx (Channel 4)" with 98/110 set in my TX? Those are reading -100/+100..
Grant
GrantL is offline        Reply With Quote Quick reply to this message
Old 04-28-2011, 10:30 PM   #143 (permalink)
Default 5.1 governor
Mr Mel, I set up my (separate) governor as you suggested in episode 14 and it is working well. My question though is that in normal mode when spooling up everything is good until I get to half throttle the engine dies out and I am not able to fly until I switch to Idle 1 or 2. Once I do that everything is good but I would like to fly around in normal mode. Is there a way to disable the governor in normal mode or be able to spool up to half throttle and then go to a goverened head speed past half throttle?
Thanks for the great videos.
drvohs is offline        Reply With Quote Quick reply to this message
Old 04-29-2011, 06:20 AM   #144 (permalink)
With separate receiver? (with Spektrum or Futaba SBus you can utilize bankswitching to get full range throttle on normal)
But on separate receiver is a bit tricker, you can you up to 49% throttle in normal mode, then you need to make a bigger jump so the requested RPM is Ok.
Old 05-25-2011, 02:50 PM   #145 (permalink)
Default nitro governor
Yes, what I meant was separate receiver. Its been a long time since I worked on this because I got frustrated and started just using throttle curves on the transmitter which works OK because I have a new engine and wanted to break it in by running it very rich.
I have an 8 channel Futaba R6008 receiver with a futaba 10C trans. OS50 hyper engine. I went through your Episode #14 lots of times and think that I have set my system up as you describe. The extra connector from TX Channel 3 (throttle) to aux in the Vbar etc.
I went back and set up normal mode as you described in previous post with a throttle curve up to 49% and then a flat curve at 80% and my idle up curves also flat. I also tried some other combinations of 0% up to 50% and different flat curves in normal mode.
My problem is that when in normal mode as I ramp up the speed as it approaches 50% the engine will cut out completely or if I speed the the throttle input through the dead spot the engine will race violently for a few seconds until the governor starts to work. Both Idle up curves work fine.
I have had some success by easing up the throttle in normal mode to just before it starts to cut off and switching to an idle up mode. Normal mode under 50% is not enough for me to hover. (because of the pitch curves)
I started with the run up setting at 30 as you recommended, lowered to 15, then to 3 but that doesn't help so its back to 15.
Since I have an 8 channel RX, isn't there a way that I can use a separate unused channel for the governor controlled by a switch?
I'm starting to feel like an idioit since nobody else has a problem with this. Nobody else in my club is using the Vbar governor for a nitro. (small club)
Other than that the Vbar works great and the governor was really nice to use in the idle up functions when I used it.
Thanks for all your great work.
Jim
Old 05-30-2011, 05:20 PM   #146 (permalink)
Hi, i have a big problem with vbar 5.0 and Trex 600E. Please help. The problem is that on normal mode (1650 RPM) the heli is rock solid... i love it, but in the very moment that i switched on idle1 (1800 RPM) the heli went crazy and very fast rushed to the right. I almost crash it and it was a pure luck to handle it. When switched Norm again everything was ok again. Mechanicaly everything is ok... the vbar setup is ok too... please tell me what could it be the problem... defective sensor may be?
7878 is offline        Reply With Quote Quick reply to this message
Old 05-30-2011, 05:24 PM   #147 (permalink)
Vibrations most likely
Start a new thread here in the forum, where you post your setup file and Event log.
Old 05-30-2011, 05:54 PM   #148 (permalink)
Mr Mel, Have I asked a really stupid question on 5/25 or do my answers lie in a diffreent part of this forum?
Jim
Old 05-31-2011, 01:33 PM   #149 (permalink)
Start a new thread for separate issues please, only way to keep track.
Old 05-31-2011, 02:57 PM   #150 (permalink)
Will do! Thank you Mr. Mel.
Old 08-24-2011, 02:56 PM   #151 (permalink)
Great videos, helpful. Chapeau!
Tom
Tom (j-log.eu)
dl7uae is offline        Reply With Quote Quick reply to this message
Old 08-30-2011, 04:50 PM   #152 (permalink)
Under the tail tab. What do I pick for the servo that comes with the trex 700e the ds650??
Thanks.
carlocivicsi is offline        Reply With Quote Quick reply to this message
Old 08-30-2011, 05:37 PM   #153 (permalink)
Thanks.
The DS650 is a standard pulse width servo, so the option with the DS8900G is the correct one.
HeliFreak Support
Graupner MZ-32
Old 08-31-2011, 09:27 AM   #154 (permalink)
Got my 1st Vbar a few days ago and watched ALL the videos, I would not have purchased the unit if it was not for the vids and the support on here.
Its a bit intimidating going from one system to another and having to learn everything
Big Thanks to MrMel and others who go out of there way to help
fnity3632 is offline        Reply With Quote Quick reply to this message
Old 09-01-2011, 11:09 AM   #155 (permalink)
I'm going to be purchasing a mini vbar for my new 600e pro but i have some newbie questions.
how do i control the gyro gain with the radio? i have a dx8
and how do i know when I'm in a rate or heading hold? with align a light would turn red for rate and green for heading hold.
and since programming the vbar is all with the computer what would the settings with ccpm and pitch curves be with the dx8 when setting up a new heli?
thanks.
Old 09-01-2011, 11:10 AM   #156 (permalink)
One post is enough, answered in the other.
Old 09-01-2011, 11:28 AM   #157 (permalink)
sorry sometimes i don't get an answer. thanks for yours.
you think i should get a full size vbar for a new trex 600e pro? or a mini would be ok? it came with the 3gx but I've read reports that they are reseting in mid air.
what channel on the dx8 will b used for gain?
thanks.
Old 09-01-2011, 11:49 AM   #158 (permalink)
sorry but,,i thought of another question since I'm new at this. I'm looking at a mini vbar picture and i just want to know where the throttle cable from the esc goes in the mini vbar (new blue line). I'm going to be using dsmx satellites.
and also where do i plug in the 6A External BEC?
thank you so much.
Old 09-01-2011, 12:18 PM   #159 (permalink)
Have you tried watching the videos and downloading(reading) the manual for the Vbar
Old 09-01-2011, 12:24 PM   #160 (permalink)
Yes I have and this r things that a newbie like me with vbar had to ask and I still don't know the answer.
Thanks. Mayb u can help me out. I just ordered the mini for my 600e pro. Any noe need a new unopen 3gx unit?
