Old 10-02-2011, 10:07 AM   #161 (permalink)
i set everything up in the vbar software. i was told to adjust the dual rates on the radio to achieve the 9 or 10 degrees cyclic since i have the express software. but when i adjust the dual rates like shown in the video a get a slow respond to the movements of the sticks.
i have no idea how to fix this.
here is the link:
[ame]http://www.youtube.com/watch?v=XmVPf8Gj_ms[/ame]
carlocivicsi is offline        Reply With Quote Quick reply to this message
Old 10-02-2011, 10:20 AM   #162 (permalink)
No need to cross post in many threads.
I have answered n the other thread.
http://heli.dacsa.net
Old 10-07-2011, 04:14 PM   #163 (permalink)
Default Throttle Trim issue video
Does this video still apply to the 5.2.4 firmware?
Grant
GrantL is offline        Reply With Quote Quick reply to this message
Old 10-07-2011, 04:24 PM   #164 (permalink)
Yes
Old 01-10-2012, 01:37 AM   #165 (permalink)
I could have swore I seen a nitro gov setup video a lil while back. Do you have a vid for it or are working on another?
Thanks!
Cra-Z-1 is offline        Reply With Quote Quick reply to this message
Old 01-10-2012, 03:00 AM   #166 (permalink)
Episode 14 or 15 depending on setup, plus throttle trim issue episode.
Old 01-11-2012, 01:42 AM   #167 (permalink)
Thanks! Guess I was looking for the word "Nitro" explicitly in the title.
New Nitro Vid would be the bomb!
{Hint...Hint}....lol
Old 04-20-2012, 01:07 PM   #168 (permalink)
trying to set up a logo 600 w/ hyperion phase sensor coming from using the castle gov previously. i've watched all the videos several times. but, when i go in to the software i'm getting stuck at the very first step.
first: my setup...i'm running a black sensor/no sats vbar with a full AR7000 RX with all the patch cables upgraded to 5.2pro. so, per the video, i've run the sensor to the sensor port, and the throttle cable from ESC to channel 4 of the vbar (as all other ports are taken, and it was easier than pulling out the red wire of the cable)
in the video, mrmel states to go to the setup tx tab and verify +/- 100. But, initially neither my bank switch or throttle bars moved at all.
looking back at the video again, i never saw the instruction to do so. but, i never patched the throttle channel of the RX to the vbar. so, i ran a patch cable from the RX throttle to AUX of the vbar, because that's where the software had the green arrow pointing in to the vbar labeled "headspeed".
but, now when i go back to the setup tx tab, my throttle stick controls the bank switch/gyro gain bar. but, still nothing is controlling the throttle.
still scratching my head, i went to the gov1 menu and selected electric, and reset (per the video). but, when i try to select 'preset channel from rx' the only choice is 'aux input' rather than all the choices available in the video (mrmel says i should choose ch. 3)
any ideas what i'm doing wrong?
˙ʇı ʞɐǝɹq 'ǝʞoɹq ʇ,uıɐ ʇı ɟı
cudaboy_71 is offline        Reply With Quote Quick reply to this message
Old 04-20-2012, 01:12 PM   #169 (permalink)
You need patch cable from RX throttle to AUX as you have figured out.
Then set AUX to control governor in Governor 1 page.
In main screen make sure you have disabled bank switching and/or aux - gain
now your throttle controls the governor.
Old 04-20-2012, 01:24 PM   #170 (permalink)
thanks fredrik,
either i'm confused, or something is wrong (probably former)
#1 not sure how to disable bank switching on the main screen. it is just set to bank 0. i've never used bank switching, so i'm not sure if that means disabled, or if there is a switch somewhere.
#2 in gov 1 screen i have no choices in the pull-down menu. AUX INPUT is the only option in that pulldown menu. the next menu i have set for channel 4.
Old 04-20-2012, 01:28 PM   #171 (permalink)
1. Correct, select Bank 0
2. Correct, AUX is only free channel which is what you want.
Old 04-20-2012, 01:29 PM   #172 (permalink)
i want to be clear. following those instructions, my throttle stick now shows movement on both bars in gov1 menu. so, that's hopeful.
my only concern now is that back in the setup tx menu, i still show my stick movement on bank/gyro gain and not on TX. but, adjusting the endpoints of the throttle channel did give me +/-100 on the TX menu AND in the top bar of GOV1 menu.
this sounds like the right commands are being sent. it just troubles me that they are happening on the wrong channel labels. this is OK?
Old 04-20-2012, 01:31 PM   #173 (permalink)
Does not matter, both are right.
AUX is moving in main screen since cable is actually connected in AUX = Correct
Governor is moving since you have selected AUX = Correct
So both is correct...
Old 04-20-2012, 01:35 PM   #174 (permalink)
thank you very much mrmel. back to the videos :-D
Old 04-20-2012, 02:12 PM   #175 (permalink)
so many issues. i'm about to call it a day and grab a beer
ok, so i've moved on to the very next step...calibrating low throttle.
i'm using a CC 110HV flashed to 3.2.6.
set it to airplane mode whatever those stock settings are
--as far as throttle response i tried high/8 first, then custom/10. but, neither is working
problem is i just can't get the throttle to come on instantly until i get to -64, which is very nearly the far right of the scale. you advised 'close to 100 or the resolution is wrong. and that i should reset the ESC'. but, i don't know what setting in the ESC to adjust to change the resolution.
any suggestions?
Old 04-20-2012, 03:05 PM   #176 (permalink)
Cant do anything about it with that firmware the endpoints in CC is fixed, so fit that means 64 its 64, however, that sounds like you do not have 5.2.5 and not looking at my latest video...
[ame]http://www.youtube.com/watch?v=OMWJzsnKbBI[/ame]
Old 04-20-2012, 04:19 PM   #177 (permalink)
i was running 5.2.3. upgraded to 5.2.5 but no change. and, that's the video i'm following.
i set my RPM to 2150, ratio to 8.8333 (106t/12t), and poles to 5 (hyperion sensor on 4035-560 10 pole motor)
set my idle1 curve to 100% flat across. then, trying to calibrate per the video i still don't get instant-on until -64.
unless i did something wrong above, i guess i live with -64 and move on? is this a bad idea? sounds like performance may be questionable.
Old 05-21-2012, 01:24 PM   #178 (permalink)
Default Tail gyro gain setting for 5.2 pro on in TX?
Mr Mel,
Regarding Tail Gyro gain on Vbar. On the free standard software, we use the Gyro Gain on the TX to control the value and %, say 35-80 and the software will show that change as your changing the % in the TX. When we go to using the Pro 5.2 software, we now use the software instead. I noticed this also because when I changed the gain in my TX, the gain in the software wouldn't change. So my question is what's the right setting in the TX for gain? The software says about 80-90 for a 90 size heli which is were I have it. What do I do with the gain in the TX? I have it at 35% (from the free software setting). Do I "inhibit" it? I would think we would be able to control the gain setting still from the TX?
Thanks,
Clay
fstclyz is offline        Reply With Quote Quick reply to this message
Old 05-21-2012, 05:45 PM   #179 (permalink)
Helo Fredrick.
Here in the UK you will have heard of the BMFA, they do a lot for the model world.
You may have heard of the RCHA (Radio controlled helicopter association)
The RCHA is actively trying to include families and in particular introduce children to the hobby. We now have two very big meetings a year, this summer is a 4 day family event and again we'll be trying for some more world records.
The reason for contacting you is your video series. I have just put together the Eagle Website (where the RCHA meets are) see www.eaglerc.co.uk.
Would you mind if I added (via embeding) some of your videos on the Eagle Website ? We are putting together a beginners section and your videos would fit in perfectly.
Hope to hear from you soon.
Mark
mslater is offline        Reply With Quote Quick reply to this message
Old 05-23-2012, 12:29 AM   #180 (permalink)
No problem
