Like Tree1Likes
Old 09-28-2011, 10:06 AM   #21 (permalink)
Originally Posted by Zaaaguy72 View Post
Dont worry about what the cyclic rates are when you are not in program mode, just go fly it and see what you think. Make sure to run the cyclic optimizer on your first flight, then turn it off afterwards. To increase or decrease the cyclic rates after initial setup, increase or decrease the Agility Slider on the main menu of the vbar software.
I'm sorry but I'm a newb at this.
what is cyclic optimizer? and how do i use it?
carlocivicsi is offline        Reply With Quote Quick reply to this message
Old 09-28-2011, 10:08 AM   #22 (permalink)
Did you watch the videos?
http://heli.dacsa.net/MrMelSite/VBar101.htm
Here's the one on the optimizer.
[ame]http://www.youtube.com/watch?v=3pkuEcrtFOI[/ame]
Old 09-28-2011, 10:34 AM   #23 (permalink)
saw the video. but express software don't have optimizers right? i not home to check right now.
Old 09-28-2011, 10:44 AM   #24 (permalink)
You dont have to, but do yourself a favor and upgrade to Pro. You get better setup options and an overall better flying heli when running 5.2 pro.
Team HeliProz
Zaaaguy72 is offline        Reply With Quote Quick reply to this message
Old 12-18-2011, 02:51 PM   #25 (permalink)
I found phasing issues with just a normal roll. First I rolled it inverted, and everything seemed fine. After going through with the roll, I ended up with the tail some degrees off. I never noticed this before, probably because I wasn't really looking for it.
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote Quick reply to this message
Old 09-09-2012, 01:06 AM   #26 (permalink)
Originally Posted by nyc863 View Post
3. Hover above ground effect tail in and get it sitting at a spot (you can do this in a steady wind), then smoothly rotate 90 degrees to the right without any other input. Does the heli start un-commanded forward flight? If so you need some swash rotation. On a heli with rear elevator servo and front cyclic servos, using the control panel, go to "swash rotation" and rotate the swash 2 degrees by turning the control wheel in the direction the heli moved. Eg, if it moves right, turn it right so it indicates 2 degrees. No need for reboot, just remove the panel and take off again and do the same thing. Is it worse, or better or even reversed? Remembering where you are from 0 (now +2 degrees), either add or subtract more. Within ~5 degrees you should find you can piro on the spot from a stable hover to any compass position without any un-commanded flight. Getting this right is the difference between a great flying machine ("like a sim!") and a sloppy one. The auto-trim flight also does this adjustment but do you ever have a real windless day? I prefer to do it manually. If phasing isn't right a slow piro while hover will nod the heli (and if you stop at the nod it will start forward or reverse flight). Even if mechanically phasing looks perfect, can you spot a 3 degree error? I can't.
sorry for the stupid question.
you say to rotate the heli 90 degrees to the right and then check for forward flight. the forward flight could only be to the right since i turned the heli 90 to the right. so, why do you say to rotate the swash "in the direction the heli moved"? it can only have moved to the right, isn`t it?
then a few lines ahead you say "will start forward or reverse flight?. now i understood that a fter turning the heli 90 to the right and stopping it, the heli will nod and will either move forward or backwards. now it makes sense to me. if it moves forward i should add some degrees so the swash turns right and if it moves backwards i have to add degrees for the swash to turn left?
thanks
ReadyToCrash is offline        Reply With Quote Quick reply to this message
Old 09-09-2012, 01:10 AM   #27 (permalink)
what makes a heli slowly rotates ccw as it tic-tocs (elevator tic-tocs)? little tail gain? pre-comp? i can`t make the tail wag no matter how much gain i add to it. what could be the cause for this? thanks.
Old 09-09-2012, 01:32 AM   #28 (permalink)
Ready2.... If it only moves a little left (nose) during the stops then I'd say increase pre-comp. if it's slowly rotating the whole time then it seems it would do it in all flight and not just tic tocs
McCollister911 is offline        Reply With Quote Quick reply to this message
