Old 02-12-2012, 04:24 PM   #201 (permalink)
I'm looking for spare 500 parts for a back up air frame I'm building. Please let me know what you've got. Looking for frames, v-bar head parts, swash, main shaft etc new or used.
Metal4130 is offline        Reply With Quote Quick reply to this message
Old 02-13-2012, 12:55 AM   #202 (permalink)
Hi,
Got the wrong motor plate in my 500SE kit.
Anyone has a spare 25mm motor mount?
Thanks.
ziper_it is offline        Reply With Quote Quick reply to this message
Old 02-13-2012, 05:03 PM   #203 (permalink)
I have a set of 400 tail booms (MIK04181), a set of carbon tail boom braces (MIK04178) and mod .5 main gear. They are new. Bought them accidentally. I'd trade for any spares in for a 400se, preferably new.
agagescu is offline        Reply With Quote Quick reply to this message
Old 02-14-2012, 10:03 PM   #204 (permalink)
I have a less than 50 flights Jive 100lv with heatsink (thermal taped on so it can be removed if need be), and a Hyperion 4025-1100. They were in my 500se but I swapped everything into a 6003d and I would like to go HV on it so Im looking to trade plus cash for a 80hv and a motor in the 5-600kv range.
Nikon D4/Sony Fs700/Cinestar 8/8FG super/Dx8
Twister773 is offline        Reply With Quote Quick reply to this message
Old 02-17-2012, 05:47 PM   #205 (permalink)
Looking for Logo 500 main shaft, auto rotation hub, drive belt and belt drive pulley. New or good used condition is okay.
MIK4070
MIK4067
MIK4075
MIK4059
Old 02-23-2012, 08:59 PM   #206 (permalink)
Look to buy M2389 - Pin (Magnet) Holder
bluewave1016 is offline        Reply With Quote Quick reply to this message
Old 03-15-2012, 12:23 PM   #207 (permalink)
Default MOD .5 and mod.7 pinions
I have a collection of mod .5 pinion
20T
19T X2
16T
17T
13T
all 5mm shaft
Also herringbone mod.7 5mm shaft
13T
15T stripped screw
I think I also have an extra mod 1 H 12T 6mm shaft new
would trade for some L600 parts
DIABOLO - Spirit
goblin 500 Sport-- Spirit
joliecoeur13 is offline        Reply With Quote Quick reply to this message
Old 03-15-2012, 12:31 PM   #208 (permalink)
I have an extra set NIP MIK0915 Main Blade Holder 14mm if anyone is in need.
Logo 600se
Redlight11 is offline        Reply With Quote Quick reply to this message
Old 03-15-2012, 06:21 PM   #209 (permalink)
Default 500 parts
Sold
killermolly is offline        Reply With Quote Quick reply to this message
Old 03-18-2012, 10:36 PM   #210 (permalink)
Default need oneway for 500/600
I have like 4 oneway but they are all for L400 so looking for a good oneway for LOGO500/600 , need to be new or very low use on it ...
DIABOLO - Spirit
Old 03-20-2012, 05:14 AM   #211 (permalink)
I got two complete 500SE tails after upgrading to 600 and 600SE.
TRCHK
BorgeBorge is offline        Reply With Quote Quick reply to this message
Old 03-30-2012, 07:55 PM   #212 (permalink)
Default 500+ conversion for 600SE conversion
I have for trade all parts to convert your 600 3D/SE to a 500+
500+ you ask. Using a Raptor 30 belt and cutting your 600 boom you get a length between a 5003D and a 500SE.
Looks like this
My parts are
600 Boom cut to length for R30 belt
Raptor 30 Belt, same material as 6003D/SE belt
Tail Rod
Boom Struts cut to 1" less than 500SE
Fusuno Jolly Bee Canopy
500 Skid Tubes
Edge 553mm FBL's
Mikado Version Scorpion 4025-1100. Has 25 and 30mm spacing, 4mm bolts, 5mm shaft.
Mod.7 Main Gear and 5mm 15 and 16 tooth pinions.
All above has only 5 flights then I switched back to 600 to use my 10S packs since my 6S packs are BackOrder till early April.
Would trade all but motor form above.
Looking for 600SE:
Boom CF/Alloy
Belt
Tail rod
Boom Supports
White Struts and Tubes
Edge 693 FBL's and 105 tails
M1 6mm 11 tooth pinion
Would trade motor for 2nd set of blades or sell for $100 with trade.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 04-17-2012, 02:11 AM   #213 (permalink)
Default wtb Quick UK Swash plate for Logo 600/500
Lmk what you have. Thanks
timeoutdan is offline        Reply With Quote Quick reply to this message
Old 04-18-2012, 01:44 PM   #214 (permalink)
Question the Logo 500SE and the Logo 600 do they have the same carbon tail case, and vertical fin? Also the Canopy size is it the same too?
Angelo
esmoglo is offline        Reply With Quote Quick reply to this message
Old 04-18-2012, 01:48 PM   #215 (permalink)
Canopy and tail case are different, the vertical fin is the same I think.
Align Trex 700 V3 DFC HV Vbar Pro - Vcontol Touch Mikado Logo 200 SAB Kraken 580 Vbar Neo Align Trex 500X Vbar Neo
Raydee is offline        Reply With Quote Quick reply to this message
Old 04-18-2012, 01:53 PM   #216 (permalink)
Cool thanks
Angelo
Old 04-18-2012, 02:39 PM   #217 (permalink)
Actually the vertical fin is different as the case because the boom is 25mm on the L600 as opposed to 20mm on the L500se ...
DIABOLO - Spirit
Old 04-19-2012, 02:46 PM   #218 (permalink)
Default Frame Hex Bolts ...
Want to buy two or three Logo 500/600 Frame Hex bolts , MIK 4099
- Logo 600, Warp 360 -
Bootjack1 is offline        Reply With Quote Quick reply to this message
Old 04-23-2012, 07:27 PM   #219 (permalink)
Default xera 4035/3y 400kv for sale
just posted this in the for sale forums, thought you guys might be interested..
https://www.helifreak.com/showthread.php?t=409260
Logo 550sx Fat Boom
14SG
yachtheli is offline        Reply With Quote Quick reply to this message
Old 05-07-2012, 08:17 PM   #220 (permalink)
Looking for 12 teeth mod 1 herringbone pinion. I have an 11 teeth that I can trade.
Thanks.
dxflyer is offline        Reply With Quote Quick reply to this message
