Old 03-25-2011, 04:12 PM   #101 (permalink)
Originally Posted by maarset View Post
Ended up getting a 5mm 15T from RH. Is there such a animal as a 15T herringbone 6mm?
Looks like it got discontinued as I tried to search it. I did get one from them Early Feb when I bought my 500SE.
MIK4315 MIK4315 Mikado 15 Tooth Herringbone Pinion, M0.7, dia. 6mm $19.99
It also looks like they changed the PDF recommended setups to 16T, it used to be 15T.http://www.readyheli.com/assets/imag...ggested%2Bkits
mCPX BL
NovaCX12 is offline        Reply With Quote Quick reply to this message
Old 03-25-2011, 04:43 PM   #102 (permalink)
CRAZY! I thought the logo 500 performed well on a 15T. But a 16T. crazy. I've snapped 5mm pinions on a Century Swift and a Compass knight 600E and I have a 6mm motor shaft for my 4025-890 so I thought it might be a good idea to go 6mm on my logo 500.
maarset is offline        Reply With Quote Quick reply to this message
Old 03-25-2011, 08:21 PM   #103 (permalink)
Have a new 30 mm motor Plate and 30mm counter bearing to swap. Looking for stock Tail grips w/bearing, CF tail parts
- Logo 600, Warp 360 -
Bootjack1 is offline        Reply With Quote Quick reply to this message
Old 03-30-2011, 07:13 AM   #104 (permalink)
Default 600SE
Looking for 600 SE parts, mainly boom, belt, push rod and tail supports. Wiling to pay a reasonable price. I don't have any spares to trade.
novalovr66 is offline        Reply With Quote Quick reply to this message
Old 04-22-2011, 03:42 PM   #105 (permalink)
Pinion Swap
I have a m1 11T (NIP) I'd like to swap for a 13T M1.
1 - Diabolo 1 stuffed with, well, see below
2 - Diabolo 2 stuffed with testosterone, jittery sweat, and rippling flanks
OverTemp is offline        Reply With Quote Quick reply to this message
Old 04-26-2011, 07:53 PM   #106 (permalink)
Anyone have a new MIK2490 Vertical Fin RH seems to be out of stock. If you do, give me a PM, thanks!
mCPX BL
Old 05-02-2011, 04:57 PM   #107 (permalink)
Looking to de-SE my 600se.
Edge 693mm fbl blades
600se belt
Control rod
-for-
Edge 603mm or 623mm fbl blades
L600 belt
L600 boom
L600 control rod
...or something like that...
I have other parts in my cache if there is something else you might need. Unfortunately I don't have a 600se boom at the moment for trade and my boom supports were epoxied with the links aligned for use with the Q-UK boom clamp. I would be willing to trade my supports and clamp for the stock L600 supports.
prototype3a is offline        Reply With Quote Quick reply to this message
Old 05-02-2011, 05:41 PM   #108 (permalink)
pm sent. the only thing is I have 640 blades instead of 623....
ClubCRASH is offline        Reply With Quote Quick reply to this message
Old 05-24-2011, 05:31 PM   #109 (permalink)
I will be converting my 600se back to a 600 once I am back from vacation in a week or so. I'm interested in getting rid of the SE conversion kit. I've only put about 5 flights on this conversion kit. PM me guys! Not parting out!
sgrim80 is offline        Reply With Quote Quick reply to this message
Old 05-24-2011, 06:32 PM   #110 (permalink)
Default Conversion
I sent you a PM. You wanting to sell the SE kit or trade for the 600 parts? Willing to trade my 600 parts for your SE parts. Let me know!
Old 05-24-2011, 06:38 PM   #111 (permalink)
I now have a full SE conversion kit (including Edge 693mm blades and Q-UK clamp) that needs a good home.
Old 05-28-2011, 01:58 AM   #112 (permalink)
Default Logo 500 Flybar'd Head
If anyone's looking for a ARF Logo 500 flybar head I just posted mine in the FS section. Also, if anyone has a blue & yellow L500 canopy they'd like to trade for an L50 orange/checkerboard Fusuno canopy let me know.
Dave
Old 06-02-2011, 11:42 PM   #113 (permalink)
I am trying to find the same pinion as I am "stuck" with no good solution to 8S, 890 Kv Motor with 6mm shaft.
RH says the MIK4315 is discontnued.
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
Old 06-06-2011, 09:13 PM   #114 (permalink)
Default Counter Bearing and Motor Plate
I have a Mikado Counterbearing-for-5mm-Motor-Shaft-Logo-500 600-25mm-motor and a Mikado 30mm motor plate for Mikado logo 600. will swap for any Logo 400 or 600 part of similar value.
mightyq is offline        Reply With Quote Quick reply to this message
Old 06-16-2011, 01:30 AM   #115 (permalink)
Default Pinion Swap
Nvmd!
Last edited by gravydrive; 06-20-2011 at 01:41 PM.. Reason: Don't need it anymore!
gravydrive is offline        Reply With Quote Quick reply to this message
Old 06-17-2011, 01:01 AM   #116 (permalink)
RC.
I have a Logo 30mm motor mount. I would like to sell or trade for a Logo 25mm motor mount.
RC. is offline        Reply With Quote Quick reply to this message
Old 06-20-2011, 09:16 AM   #117 (permalink)
Hello, anyone have an extra one of these? Broke mines being stupid.
http://www.readyheli.com/MIK4179-Car...0_p_35386.html
Thanks!
mCPX BL
Old 06-22-2011, 12:22 AM   #118 (permalink)
Thanks!
Just in case you can't find the Mikado part, it might be easier to get the same diameter CF rod at your LHS, then cut it to the same length. Then just find some threaded rods & ball links and epoxy into the ends. You could be back in the air tomorrow...
Tapatalk on iPhone
ElectricSheep is offline        Reply With Quote Quick reply to this message
Old 06-26-2011, 09:49 AM   #119 (permalink)
Decided to just list my stretch "kit" in for sale.
https://www.helifreak.com/showthread.php?t=317569
Old 07-05-2011, 04:53 AM   #120 (permalink)
Default 600 Canopy Swap
Looking to trade my MIK4372 Airbrushed Logo 600 Fiberglass Canopy - Ice Blue (New, Never mounted) for a MIK4420 Airbrushed Logo 600 Fiberglass Canopy - Ice Yellow.
If interested, hit me up.
Steve
$teve is offline        Reply With Quote Quick reply to this message
