Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > SR
SR Blade Helicopters (eFlite) SR
Old 04-24-2011, 05:25 AM   #41 (permalink)
Hey guys, bit of a newbie here. I get the idea that I should stick with plastic parts and not upgrade to aluminium because they are not worth the cost, and will just transfer the break point to the next part in line; however, if I go with a aluminium swash plate am I likely to risk breaking something else (because the swash plate is aluminium) in the next crash as a result?
Mick. is offline        Reply With Quote Quick reply to this message
Old 04-24-2011, 09:14 AM   #42 (permalink)
Not likely, the swash slides on the main and pivots, all the head stuff is more prone to breakage.
Danno
Blade 500x, Trex 500xt, just back after some time off. You don't ever really QUIT helis do you??
DKS_ONE is offline        Reply With Quote Quick reply to this message
Old 04-25-2011, 04:30 AM   #43 (permalink)
Thanks DKS_ONE,
I sort of figured that would be the case, I will upgrade to aluminium to eliminate the swash plate separation issue.
Old 08-06-2011, 12:10 PM   #44 (permalink)
I've had the sash on mine separate even after being glued, as i'm still a noob at flying heli's and only got her off the deck about 6" when it went nose down and tried to go at mack 2 forward. Lucky i was flying in a field with long grass and a ply landing board so no real damage, i dread to think what would have happened if it was in a hover and just went straight up. the replacement has the edges melted over with a soldering iron.
Jase
Jase is offline        Reply With Quote Quick reply to this message
Old 11-16-2011, 01:01 PM   #45 (permalink)
Anyone got instructions for the solder portion? Photos maybe? I'm not sure where you guys are making the brief soldering iron "touches".
Blackhawk Crew is offline        Reply With Quote Quick reply to this message
Old 11-19-2011, 10:35 AM   #46 (permalink)
Default Solder Iron and Glue to fix SR's Swash
Don't have pics, but, basically there is a tiny bit of material, from the inner swash, I'll call it a plastic flange, exposed on the under side. That little bit of material sticks out of the bearing. You can heat it up with a soldering iron to help keep the inner swash from pulling out of the bearing. That alone didn't help mine, but, gluing it did. I've got 418 flights on my original swash since I glued it. The aluminium replacement is still in my parts box, I'll use it if I ever need to replace the swash. Be careful when gluing so you don't seize up the bearing with glue, I used a very thin film of superglue, it's working better than new. I guess I'd have a new swash handy, incase you mess up the gluing and/or solder iron tricks, but, don't fly again till you get that swash fixed, my first swash plate seperation cost me a whole lot more time and parts money than the glue fix or upgrade did. Best of luck.......
My Fleet: MCX, MCX2, MCXT, MSR, CX3, SR, MQX, NanoQX, 200SRX.
Gadget1500 is offline        Reply With Quote Quick reply to this message
Old 12-07-2011, 11:07 AM   #47 (permalink)
I had the same problem ,bought one of the first ones out . Luckily mine seperated at the altitude of six inches as i was lifting off first flight ordered a new one and waited 3mo for it while factory rep said they didnt have a problem . In desperation i ca it back together,and it still works fine, second one still in pack.
depup is offline        Reply With Quote Quick reply to this message
Old 12-07-2011, 08:35 PM   #48 (permalink)
I am so glad that I found this forum. Been reading for a week and came across this thread yesterday. Today I picked up my new SR and a metal swash plate. I sure do not need to crash and burn because of a mechanical failure. Again, thanks all who have posted info to help the rest of use who are newbies and some that been around other helis.
HopSkipFlop is offline        Reply With Quote Quick reply to this message
Old 12-11-2011, 03:59 PM   #49 (permalink)
[delete]
Blade 130X, Blade Nano CPX
Edge 540T, Mini Funtana X, UMX Sbach 342 3D
Lunchbox is offline        Reply With Quote Quick reply to this message
Old 01-19-2012, 07:14 PM   #50 (permalink)
Default Flight 13 We have separation
On my 13th flight my bird went psycho on me. Stuck to the ground on lift off and if I over powered it to get off the ground and fly it was all over the place. Sure enough the swash had a split personality and lost it's mind. ( Thought it was me for a few ) Took the head off and popped the swash out and glued it up carefully. It's an easy fix and I suggest all SR owners do this if they do not have the newer flared swash design. I am not going to worry about going with an aluminum replacement at my skill level . I think the plastic is just fine for crashing with and that is precisely what I am prepared for. I may upgrade the swash down the road when I am better but for now I have some crashing to do. My SR flies like new again and once again the smile is on my face.
,SR ,mCPx, Trex 450 Pro, Sport, and SE V2, Pair of Trex 600esp's.DX7 & Dx6i. My head is set up proper. I have seen all of the videos.
TDubya is offline        Reply With Quote Quick reply to this message
Old 04-03-2012, 09:53 AM   #51 (permalink)
Just glued mine because of this thread. My original swash has at least fifty flights on it and 4 or 5 crashes too, so im pretty surprised i haven't had mine separate in flight yet.
BeefKopter is offline        Reply With Quote Quick reply to this message
Old 04-08-2012, 06:45 PM   #52 (permalink)
Default Glued Swash for 2012?
Is this still an issue, i notice the sticky is from 2010, so just wondering has anyone lately had this happen, or has the issue been fixed at the factory?
LeatherHelmet is offline        Reply With Quote Quick reply to this message
Old 04-09-2012, 11:08 AM   #53 (permalink)
Hi,
The issue has not been fixed. I have been teaching some people how to fly their SR's and they have all had the swash separation problem. They have been replaced with the Micro Heli CNC Swash.
B450 BNF Basic & Futaba 8UAS 2.4
2 Bld SR's 1 w/ MH Upgrades, 1 Nite Fly, MCPx V2 Walkera V100D08 rtf Composite-Arf 2.3m Extra 330l w/ DA85 H9 Tango w/ O.S. 55AX, Top Flite Flite Streak and Nobler Control Line, Fly Zone DR1 RTF. new owner of a DX8
R_C Addict is offline        Reply With Quote Quick reply to this message
Old 05-13-2012, 11:02 PM   #54 (permalink)
Thumbs down DING-BAT DESIGNERS
Originally Posted by R_C Addict View Post
Hi,
I am totally disgusted with Horizon Hobby by now. After living through four (4) of the MSR pieces of junk, I was sure that Horizon would NEVER AGAIN market a swashplate like that...
"JUST CLAMP EVERYTHING BACK TOGETHER AFTER EACH FLIGHT AND YOU WILL BE FINE YOU STUPID CUSTOMERS--WE HAVE EVEN INCLUDED A LITTLE PIECE OF RED PLASTIC TO AID YOU IN YOUR 'FIELD REPAIRS' TO THIS LITTLE JUNKER--DO NOT WHINE--JUST FEEL LUCKY--WE COULD HAVE SENT THE BOX WITHOUT THE LITTLE PLASTIC PIECE."
So...what happens down the road? Well--the BLADE SR, OF COURSE--DESIGNED AND MANUFACTURED TO FLY APART RIGHT OUT OF THE BOX.
I am so dam disgusted, and in shocked disbelief, I feel like biting the wall. I bought two of the SR units--both used but in great condition. I would not try to fly either one of these birds without CNC swashplates--I have them installed now and I am still thinking about a brushless tail motor.
I wonder if there are any class actions being planned--how would that be?
STASHMO is offline        Reply With Quote Quick reply to this message
Old 05-14-2012, 06:54 AM   #55 (permalink)
The correct question is how could that be? Horizon's legal team has written off liability of operation onto the consumer in it's instruction manual and on the box. You sue HH for liability of a part that hasn't caused any deaths or injuries during operation, you cannot prove your competency as a pilot since there is no certification for this hobby to state your case as an expert and if you hit HH you might as well hit up Align, MH, and so on down the road for any other issues that could be blamed on pilot error. Did I mention that since the swashplate is replaced with an upgrade in our minds, that voids any responsibility for warranty by HH unless there is an upgrade that they sell? The product as designed is how all the warranty and liability legalese is written. I'm no attorney but in my opinion, if HH gets hit others will too and you might as well kiss the low cost of operation of any R/C heli as you see it now and most likely any of our R/C hobbies!
Maybe I should ask, is there an AMA number you have? That is valid for approved fields only. Your liability is yours if you take your R/C plane off of an approved field which means that the AMA insurance you carry is void unless the flight area is approved. No matter what damages occur while you are operating the model aircraft, the liability still falls on you, not anyone else.
My point is in all this ridiculous stuff above is that this is a hobby and you need take personal responsibility for your own actions since you probably have crashed your choppers before and since you bought an unknown modified used SR or two, there is nothing you can do to go after a hobby manufacturer on items that are outside of their control.
If you don't like what you got, use your feet to go get something else and sell off your current stuff for parts to someone else that might be able to use it. No offense meant but why don't you try a different heli?
OXY Heli and Lynx Heli Innovations Team Pilot
SilentDRC.net -The Order of Brushless Witnesses
GSPI is offline        Reply With Quote Quick reply to this message
