Old 01-30-2012, 01:14 PM   #21 (permalink)
Just wondering, can the control panel tweak every parameter accessible on the pc software?
Or is it just for basic tweaking?
Shape 9.0, Trex 700 DFC pro** MKS Cyclics & Rudder Servos all round. Kontronik Pyro 750 Drives, Kontronik ESCs
Futaba SBus Rx, Futaba 8FG** transmission
seemore74 is offline        Reply With Quote Quick reply to this message
Old 01-30-2012, 01:18 PM   #22 (permalink)
Control panel can tweak all parameters, but not same logic functions as PC, i.e. you cannot install a new heli with it.
Android app on the other hand can do a new setup.
http://heli.dacsa.net
Old 01-30-2012, 01:41 PM   #23 (permalink)
thanks Mel
Old 02-12-2012, 03:27 PM   #24 (permalink)
Just updated my MiniV to 5.2 Pro & i was looking for the Swash Ring feature but can't seem to see it, is it on the mini or is it only on the full size?
Old 02-12-2012, 03:35 PM   #25 (permalink)
It's there, Swash step in Setup, then the little doctors hat.
Old 02-12-2012, 03:58 PM   #26 (permalink)
Thanks Mr Mel
Old 02-16-2012, 02:07 PM   #27 (permalink)
Yet another one, on the CGY750 you can mix out swash ball movements (interactions) by using Pit-Ail or Pit-Elev ect., can this be achieved in any way on the MiniV?
My reason for asking this is because swash ball movement is quite evident on my Faifa with cyber head & MiniV though out most of the swash travel.
Old 02-16-2012, 02:16 PM   #28 (permalink)
Yes and no, you can re-do the geometry totally in the Swash step, you do not have mixing like in something else as Vbar works in another way (which gives a huge benefit for other reasons), but using the expert swash setup you should be able to dial it away by measuring your exact setup.
If not, then its rather a geometry issue on the helicopter.
Old 02-16-2012, 03:01 PM   #29 (permalink)
Thanks for the uick response Mel I know that you have a Faifa but is it on the vbar & if so have you experienced this? If it is a geometry issue then i am stumped on means to correct this on the Faifa as there isnt much options on mechanical adjustments.
Old 02-16-2012, 03:02 PM   #30 (permalink)
I flew my Faifa stock with some modifications to the head
Make sure the elevator lever does not hit the frame, if an older model it will, I had to dremel the frame where it hit.
(fixed in later versions)
Old 02-16-2012, 03:08 PM   #31 (permalink)
I shall look into this, thanks.
Old 02-23-2012, 01:09 PM   #32 (permalink)
Ok, first flights were very impressive for how simple the setup is, GREAT!
The thing I have noticed is that in a bit of wind the Heli slightly dolphins when flying fast in a straight line, has anyone experienced this & if so how can I remedy this?
Old 02-23-2012, 01:11 PM   #33 (permalink)
Try lowering your cyclic gyro gain.
HeliFreak Support
Graupner MZ-32
Old 03-05-2012, 05:14 PM   #34 (permalink)
Default V-bar reviewed
Hey everyone!
See this video after updated to version 5.2...incredible how great it was the flight!! : Bacon
[ame]http://www.youtube.com/watch?v=n_micvnFO2g[/ame]
See ya!
Joao Figueira
rockefile is offline        Reply With Quote Quick reply to this message
Old 03-05-2012, 08:11 PM   #35 (permalink)
Where's the vid?
~Cliffman~ is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 03:24 AM   #36 (permalink)
Hi, here it is... [ame]http://www.youtube.com/watch?v=n_micvnFO2g[/ame]
Old 04-22-2012, 04:50 AM   #37 (permalink)
Can anyone tell me if there is a cyclic ring (limiter) feature on the Vbar mini 5.0pro & if there is, where to find it?
Old 04-22-2012, 03:29 PM   #38 (permalink)
Yes: Swash setup tab, click on the blue doctor's hat.
HeliFreak Support
Graupner MZ-32
Old 09-12-2012, 02:40 PM   #39 (permalink)
Default RUDDER FAILURE TODAY!
Can anyone tell me if the flagged up voltage drop warning in the log would explain my rudder failure today on my SHAPE 700 & if so what could be the cause of this? My setup is Helijive 120 running internal bec at 6V (with slave wires in), BLS251 tail servo with step down. Prior to this i did notice a few times before today my tail would make a slight kick in flight & this I noticed the very same day I enabled the autorotion bailout.
Old 09-12-2012, 02:45 PM   #40 (permalink)
Please start an own thread next time.
- Are you using buffer pack? 6v on a Jive needs buffer pack.
- I would rather guess static on that heli...
