Go Back   HeliFreak > R/C Helicopter Support > 450 Class Electric Helicopters > 450 Aftermarket Upgrades
450 Aftermarket Upgrades 450 Aftermarket Upgrades
Old 09-23-2010, 11:37 AM   #21 (permalink)
Originally Posted by desmogod View Post
I'll try it tomorrow and let you know how I go.
How did it go?
HEIM JOINT is offline        Reply With Quote Quick reply to this message
Old 09-24-2010, 09:23 PM   #22 (permalink)
It was so tight in there I ended up making the bore oval. Much like you said and in your video
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
Old 09-25-2010, 09:14 AM   #23 (permalink)
If you try it again put a tail shaft in the slide shaft while you are loosening or tightening it. That will keep it from completely crushing the wrench flat end. If the slide shaft is tight on the tail shaft after that, roll a small piece of 320 or 400 silicon carbide sand paper into a slightly tapered cylinder where the small end will just fit into the wrench flat end of the slide shaft. twist the sand paper in the bore removing a small amount of material untill you get it to slide freely again.
Old 09-30-2010, 04:29 PM   #24 (permalink)
This is great work! I have spent my time in machine shops and appreciate what you have done here! I am running a Sonix B400 tail on my frankenhili and have 5 differant combinations of CF blades that I can run, so the question is which one of your chinese weights will work for me. And being the bargain hunter that I am is there any discount for a couple of sets. LOL. If this works I will link this into the Eflite section and post you up there as most of the guys are running aftermarket tail assemblies that I am talking to. Thanks Bro!
Old 10-01-2010, 06:10 AM   #25 (permalink)
If the tail blade bolt is 2mm my Trex450 SEV2 weights will probably work. I will PM you the purchase info.
Old 10-01-2010, 02:48 PM   #26 (permalink)
I will meaure it when I get home. Now that I think about it I am pretty positive it is a 2mm bolt since I just machined out my ultralight 450 size titanium skids out of china for a CX3 build that I am working on with a 2mm tap and I can see the bolts in my mind because I just pulled them out yesterday replacing the rear CF blades with another pair. The pitch was a .4 if I remember correctly.
Old 10-18-2010, 09:50 AM   #27 (permalink)
I was wondering what the difference in required force is between the stock pro tail and one with your chinese weights added as well?
On the video there was an order of magnitude reduction in the force required to move the slider, I assume the difference is less dramatic on a tail with integrated weights?
jagsta is offline        Reply With Quote Quick reply to this message
Old 10-18-2010, 10:07 AM   #28 (permalink)
This is a video I did on the T250 on the Weighted grips versus the stock grips with my weights. Same thing would apply to the 450
[ame]http://www.youtube.com/watch?v=wVhit93JrWE[/ame]
Old 10-18-2010, 10:18 AM   #29 (permalink)
Awesome, thanks for that, a very clear demonstration that the align pro grips are not doing that much! I think i'll be investing in some of your weights, i've just shelled out on a fast but low torque tail servo for my 450...
Old 10-19-2010, 06:02 PM   #30 (permalink)
I am not peved . It is not my idea to begin with. I learned about the whole topic on HF to begin with. All I did was design and test weights to give the optimum reduction in tennis raquet effect that you could just use as a blade bolt and nut. What I have heard is that the stock tail blade grips with my original weights performed better than the new weighted grips by themselves. So as a service to my fellow HF members I designed a weight for the pro/sport tail that gives the same tuning as the original setup. If the weighted grips were so good why do they still need a chinese weight that is about 90% the weight of the original?
As for price I machine most of these on a manual machine in small batches(20-60 sets). Not a screw machine in china. Yes these could be a lot cheaper if I had 10000 run on a screw machine. But since I only sell few hundred a year that wouldnt be a great idea.
Most guys are greatfull that I bother to make them at all.
HJ
Just ordered a set for all 3 of my helis, Yesterday. Now just waiting to get them and then give them a try. I knew I had seen somewhere on a thread that someone made them. As far as the price is concerned I think they are a bargain for a quality product,Made in the good old USA. Unless you own a metal lathe and have the skill to use it, Which most people don't have either, and don't want to stick a bunch of washers and then guess if you are right or not, More then likely NOT. Then a few bucks compared to the total cost of the heli is not much. And they are highly recommended from all of my friends. Thanks for helping us out Heim Joint
Thomas60 is offline        Reply With Quote Quick reply to this message
Old 10-19-2010, 06:06 PM   #31 (permalink)
Add me to the list of highly satisfied customers bro! And when I get my 600 setup I am ordering more. If I were any happier I would buy a set and tongue pierce myself! LOL
Old 12-19-2010, 11:15 PM   #32 (permalink)
Default Need some weights
I was wondering how I can get my hands on a set of those weights and spacers for the Trex 250? Thanks for you time.
wolfmandan62976 is offline        Reply With Quote Quick reply to this message
Old 12-20-2010, 05:19 AM   #33 (permalink)
I will snd you a PM with the info.
Old 12-25-2010, 04:48 AM   #34 (permalink)
hello,
I would also be interested by 2 sets of your Trex 450SEV2 chinese weights (including shipping to Germany)
milliotseb is offline        Reply With Quote Quick reply to this message
Old 01-07-2011, 03:28 PM   #35 (permalink)
Excellent video on testing the effect of the Chinese weights. I will PM you to get a set for my 450 Sport.
Thanks for the good work producing these.
keithhoak is offline        Reply With Quote Quick reply to this message
Old 03-02-2011, 01:46 PM   #36 (permalink)
Heim
Please PM me with your info...Thanks
KIMK is offline        Reply With Quote Quick reply to this message
Old 03-09-2011, 11:55 PM   #37 (permalink)
Please PM me the info to order a set of these.
MÔke
Tarot 450 Pro, Typhoon 2215/HW 40A Pro, 3xHS65HB, Quark/DS520, KBDD paddles/tail DX6I/AR6200
SAR1 is offline        Reply With Quote Quick reply to this message
Old 03-16-2011, 04:03 PM   #38 (permalink)
Sent a PM!
This is the heli I have -> http://www.xheli.com/blueray-450.html
It's a v2 clone, just wanna make sure i get the right weights.
jmdanna is offline        Reply With Quote Quick reply to this message
Old 03-28-2011, 05:36 PM   #39 (permalink)
Default WOW
I will be sending you a message about getting some of these..
philatc is offline        Reply With Quote Quick reply to this message
Old 04-26-2011, 03:06 PM   #40 (permalink)
Dose this work better than the previous 450 mod that uses the steal ball links for the weights? I can see that it involves less work with your mod but are the results better or the same? If the results are better I might have to get a set for my SE V2.
John A is offline        Reply With Quote Quick reply to this message
