Mini Titan Setups - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis
Thunder Tiger Electric Helis Mini Titan E325, Raptor E550 and E620 SE Helicopters
Old 09-12-2010, 08:31 PM   #1 (permalink)
Default Mini Titan Setups
I would like to start a new thread so we can show all of our current Mini Titan setups. I hope that this thread can get made into a sticky so people can have easy access to it. Please only post your current Mini Titan setups that you are currently flying and not what you want to build. I would also like to keep this neat and clean so if you have a question about a setup or would like to make a comment please start a new thread outside this one.
Thanks!!!
So I guess I will start it off!
- Mini Titan E325 Kit
- JGF500TH motor with a 13 tooth pinion
- C.C. Ice 50 Lite ESC running in fixed end points and at 98% throttle
- Upgraded head to all metal Thunder Tiger parts
- Protek 325mm carbon blades
- JR 258MG’s on the cyclic
- JR 3400G on tail
- Futaba 401 gyro
- KBDD tail blades and paddles
- AR7000 RX
- JR9503 TX
- Thunder Power Batteries
ProLite 15C 2100
G4 ProLite V2 20C 2600
G4 Pro Power 45C 2250
- Radio timer set for 4:30
- Flying Style
Mild 3d
Ripping the heli all around the field!
rmalt is offline        Reply With Quote Quick reply to this message
Old 09-12-2010, 09:18 PM   #2 (permalink)
Location: Gone. Too many assholes here and I am one less.
Mini Titan E325 Pro/SE Hybrid
Mods - High position tail rotor, gorilla landing gear, alloy servo mounts, canopy struts & bearing holder. All screws replaced with M2 socket head bolts.
Stock TT 2381 motor with 13T pinion
CC ICE 50 in Governor Rate mode at 2,400rpm - Normal for spoolups, IdleUp for all flight
Upgraded head to all-metal Thunder Tiger SE parts
Mavrikk E802320 335mm carbon blades
Hitec HS65MGs on cyclic
Ace C0915 on the tail
Perkins HL400 gyro
Flybarred with AH-1 Cobra black paddles
Stock Pro tail blades
AR6200 RX
DX6i TX
Heliguy 25C 2200 lipos
Timer set for 7.30
Flying style - sport/scale
B335 is offline        Reply With Quote Quick reply to this message
Old 09-13-2010, 01:50 AM   #3 (permalink)
Mine is bone stock except for the KBDD Paddle and the Align 450 CF Blades.
Still running the plastic head, frames, tail case, etc.!
Outstanding 450 sized elicopter!
I am editing as I neglected to state that my motor and ESC are stock, I am running an outboard BEC, DS 285 servos on cyclic, a 3500G on rudder, and a GY520.
Old 09-13-2010, 10:26 PM   #4 (permalink)
My mini titan is all stock, with the exception of upper metal mixing arms, and a metal head block.
I am running 3 HS5065MG's and a DS3500 with aGY401.
I have a Scorpion -8 motor and Align RCE BL70G ESC. With this setup, the only thing that gets warm is the battery pack.
One great helicopter; all the stability of a .30, with the low-cost of a 450. You can't go wrong!
Who dares, wins
edward85 is offline        Reply With Quote Quick reply to this message
Old 09-14-2010, 12:49 PM   #5 (permalink)
My current set-up:
Mini Titan e325 pro (plastic)
Scorpion 2221-8 13t pinion
Scorpion commander 45a
Hitec HS-65MG cyclic
JR DS290G tail
JR G3703D gyro
Metal upper mixing arms
Metal tail gear
Stealth CF main blades
KBDD paddles and 61mm tails
Spektrum AR6100e
Spektrum DX7
Rhino 20c 2150
Flat 90 throttle curve Idle 1 and 2
Normal 0-75-85-90-90 (only to spool up and take off)
Timer 4:30
Sport/Beginner 3d (Try a new move every time I fly.)
FlyAndFix is offline        Reply With Quote Quick reply to this message
Old 09-14-2010, 05:22 PM   #6 (permalink)
My set up:
Mini Titan SE with stock head FBL conversion
-stock ESC / BLC40
-Scorpion HKII 2221-8 @ 12 teeth pinion
-Servos: Hitec HS-65HB / Savöx-SH1357(tail)
-Microbeast
-Tx/Rx: DX6i/AR6200
Blades: Main=GCT Jazz32mm / Tail=KBDD 61mm
µBeasted MiniTitan SE
Bratwurstbratgerät is offline        Reply With Quote Quick reply to this message
Old 09-16-2010, 08:15 AM   #7 (permalink)
Hi mine is a325se but changing all the time,at presant
scorpian 2221-8 motor
ice 50 lite
3-savox 0257 servos
mini G gyro
jr 3500 tail sevo
stealth blades
spectrum 7000 receiver
also have 3G FBLsystem plus head,scorpian 6 jr 770 gyro plus looking at beastx all to play with,have used jr 770 on other heli and like it thou very hard on the tail and needs good setting up.
Many Thanks,
Marty.
NEAGRON is offline        Reply With Quote Quick reply to this message
Old 09-16-2010, 02:33 PM   #8 (permalink)
Default My mini titan
Hi All,
Here is what I'm flying at the moment - part substitutions mainly driven by me crashing a lot.. many upgrade opportunities!.
M325 Pro RTF
ACE BLC40
Flightmax 2200MaH 25c LiPo
JGF 500TH with 13t pinion
Hitec HS65MG Cyclic servos
Sportsmoto 325mm CF main blades, tail blades, flybar paddles
Futaba GY520 gyro
Futaba S9257 tail servo
Futaba R617FS FASST receiver
Sonix CNC head and tail assembly
Nasty looking cheapo Hobbyking fibreglass canopy
Futaba 7C transmitter
All I need now is some decent flying skills
Cheers,
Alex
AlexM is offline        Reply With Quote Quick reply to this message
Old 09-16-2010, 11:18 PM   #9 (permalink)
Thanks!!!
- JR 3400G on tail
- Futaba 401 gyro
- AR7000 RX
- JR9503 TX
ProLite 15C 2100
- Flying Style
Mild 3d
My Mini Titan started out life as a V1 back in 06. Over the last 4 years I've tried several different setups and upgrades. Not that the Mini Titan needs a bunch of changes. Its a grate heli right out of the box. I've had 6 bad crashes and I'm still using the original frame and front tail housing. So far this is my favorite setup on the V1.
Mini Titan E325 Kit
Scorpion- HK-2221-6 V2 (4400 KV)
11 Tooth pinion
Castle Creations- Phoenix Ice 50
Hitec- HS65MG Cyclic
Futaba- 520 Gyro
Futaba- S9257 Tail
Thunder Power- 325 main blades
KDBB- paddles and tail blades
Kasama head- (Grips, Flybar Control arms, Flybar Seesaw, Main Hub,Upper mixing arms.)
MicroHeli- Swash, Washout, Lower Mixing Arms.
MicroHeli- Front Tail shaft Gear and pulley set.
Thunder Tiger- CNC tail.
Danimal is offline        Reply With Quote Quick reply to this message
Old 09-21-2010, 03:10 PM   #10 (permalink)
Default mini titan 6s
mini titan se v1
- scorpion 2221-1630, 10T, 2800 rpm,
- 6s 1350 mAh
- 325 mm rotortech carbon blade
- kbdd paddles
- G5 61 mm tail blades
- cc ice lite 75A
- hs 65mg
- ds760 / s9257
- msh protos 4 mm carbon tail road
- ar6100 / dx7
- mild 3d
atom 6hv, logo600
nessie is offline        Reply With Quote Quick reply to this message
Old 10-04-2010, 02:31 AM   #11 (permalink)
Mini Titan E325
stock motor
stock ESC
GY401
hs65mg
S9650
main-325 Radix Blades
tail - Black KBDD
stock paddles
AR6200
DX6i
Metal TT mixing arms
SE battery tray
Outrage 2200mah - 25C with BC6 charger
flying style- Figure 8 etc...
8:20
Quah is offline        Reply With Quote Quick reply to this message
Old 11-05-2010, 03:51 PM   #12 (permalink)
My current set-up:
JR DS290G tail
JR G3703D gyro
Metal tail gear
Metal rotor hub
Metal washout block
Spektrum AR6100e
Spektrum DX7
Rhino 20c 2150
Timer 4:30
KBDD Team Pilot
Last edited by FlyAndFix; 11-05-2010 at 08:14 PM.. Reason: Bold is the change in set-up
Old 11-10-2010, 05:37 PM   #13 (permalink)
My set up
E325 kit
Sonix FBL head
Sonix tail
Torque tube
Motor Scorpion HK-2221-8 V2
C C Phoenix ice 50
13t pinion
Hitec hs65mg cyclic
Align ds520 tail
1 Piece battery tray
Radix main blades
Radix tail blades
Gyrobot 900 gyro
Align 500 landing gear
Spektrum Ar 6200
DX7
Heliguy 2200 batt's
Fly using Govner @ 90%
Flying style = Crap
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 11-12-2010, 08:30 AM   #14 (permalink)
Great info in this thread.
Getting ready to build a mini titan and I need all the help I can get. LOL!
John
thehatguy is offline        Reply With Quote Quick reply to this message
Old 11-13-2010, 10:09 PM   #15 (permalink)
Mini Titan E325 (plastic)
Only upgrade is SE battery tray
Align 430XL 11T pinion
Castle Phoenix 45A esc
Dimension Eng. SportBEC bec
JR DS285MG cyclic
JR DS3500G tail
Spartan Quark gyro
Align 325 Pro wooden blades
Stock paddles / tail blades
Spektrum AR6200
Spektrum DX7
Turnigy 35C 2200mah
TC: 0-70-70 (Normal), 85 flat (ST1), 100 flat (ST2)
Timer 6:00
Flying style: Hovering, circuits, figure 8s, etc
Align T-Rex 250SE, 2S A123 | Blade nCP X | MA Furion 450 (unbuilt) | Spektrum DX7
vigor1 is offline        Reply With Quote Quick reply to this message
Old 11-14-2010, 11:04 PM   #16 (permalink)
E325 plastic KIT
Motor: Stock OBL 29/35-10H
Motor Pinion: 15T
ESC: Stock ACE 40Amp ACE8041-H (default settings)
Reciever: Futaba R617FS
Gyro: Futaba GY520 (AVCS Mode, setup as per Futaba manual)
Tail Servo: Futaba 9257
Cyclic Servos: Futaba S3107
Battery: Revoeletrix 2S 2100Mah (Add 3oz lead for CG)
Main Rotor Blades: Align 335 Pro
Flybar Paddles: Stock
Tail Rotor blades: Stock
Radio: Futaba T7C
PC: 40_57.5_75_87.5_100 (hovering at mid stick)
TC: 0_50_77_80_83
Flying Style: NOOB
Michael
blokkies is offline        Reply With Quote Quick reply to this message
Old 11-16-2010, 02:43 PM   #17 (permalink)
-E325 Plastic Kit
-Kasama Metal Head
-Gorilla Skids
-Motor: Scorpion 2221-8
-Motor Pinion: 13T
-ESC: Castle Phoenix 45
-RX: Spectrum 6110e
-Gyro: Futaba GY401
-Tail Servo: Futaba 9257
-Cyclic Servos: JR DS285 MG
-Batteries: TP 3s 2600mAh Pro Lite V2 & Pro Power 2250mAh (Will be replaced with Hyperion G3 VX 3s 2200's)
-Main Rotor Blades: Align 325 Pro Woodies & Radix CF
-Flybar Paddles: TT SE greens
-Tail Rotor blades: Stock
-Radio: Spektrum DX7
-Pitch Curve: 0-25-50-75-100 (all flight modes)
-Idle-N: 0-75-80-80-80
-Idle-1: 90-INH-85-INH-90
-Idle-2 100-INH-95-INH-100
-AILE Expo: 5%
-ELEV Expo 5%
-RUDD Expo 10%
Headspeed appx 2800-2900
Flt Time: 5:30 (DX7 timer set)
Flt Style: Circuits, flips, rolls, loops, tic-tocks, inverted nose-in
Logo 700 / Logo 600 / Logo 500 / Oxy 2 FE / Blade 180CFX / mCPxBL / nano CPS / V-Bar NEO / V-Bar Control / uBrain / DX7
Old 11-16-2010, 07:04 PM   #18 (permalink)
E325 Plastic Kit V1
Stock Motor - OBL29/35-10H with 11T pinion
Stock ESC - Ace 40 amp
CNC Heli Upper Mixing Arms
Cyclic Servos - Hitec HS65MG
Rudder Servo - Futaba S9257
Gyro - Futaba GY401
Rx - Futaba R617FS
Transmitter - Futaba 9C
Main Rotor Blades - Align 325 Pro Woodies
Tail Rotor Blades - Stock
Flybar Paddles - Stock White
Batteries - GForce 3S 30C 2200 mah
Charger - Hitec X4
Throttle Curve normal - 0-45-75-80-100
Throttle Curve idle 1&2 - 85% Flat
Aile Expo - +25
Elev Expo - +25
Rudder Expo - +50
Just purchased a CNC Heli all metal head.
Flight Time - 7 min.
Flying style - Hovering and some forward flight
(2) E-Flite mCP X ver 1 & 2
(2) TT E325 Mini Titans / TT Raptor 60 N - Futaba 9C
T-rex 500E Pro, Futaba 8FG
Lynbird is offline        Reply With Quote Quick reply to this message
Old 11-16-2010, 09:35 PM   #19 (permalink)
Lets Talk Mini Titan Components
Here are some good threads of FAQ'S about Mini Titan components
Once again please keep this thread clean! If you have any questions post them in the main Thunder Tiger Electric Helis section! Thanks!
ESC'S and Batteries
https://www.helifreak.com/showthread.php?t=255809
Gyro and Tail Servo's
https://www.helifreak.com/showthread.php?t=256268
Cyclic Servos
https://www.helifreak.com/showthread.php?t=256267
Is the Super Combo Really Super? You Decide!!!
https://www.helifreak.com/showthread.php?t=254578
Understanding Belt Tension
https://www.helifreak.com/showthread.php?t=194733
Motor? I don't even know her!!
https://www.helifreak.com/showthread.php?t=255666
Mini Titan FBL'S
https://www.helifreak.com/showthread.php?t=242837
Making your Mini Titan 6 Cell "BEEFCAKE"
https://www.helifreak.com/showthread.php?t=248708
Pulse XT 60 Saito 100
~KBDD Team Pilot~
Old 11-17-2010, 04:33 PM   #20 (permalink)
- E325 Plastic Kit
- CNC upper mixing arms
- Turnigy 2836-3700 motor
- Thunder Power THPE40SGB4 esc
- Spartan Quark gyro
- DS285 cyclic servos
- Outrage OS7654T tail servo
- cheap CF main blades
- stock paddles and tail blades
- AR6200/DX6i rx/tx
Freddd is offline        Reply With Quote Quick reply to this message
Insurance
Human Verification
