Mini Titan Setups - Page 2 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis
Thunder Tiger Electric Helis Mini Titan E325, Raptor E550 and E620 SE Helicopters
Old 11-18-2010, 09:58 PM   #21 (permalink)
- E325 V2 HELI
- FOX XPower XP3590 BL motor
- Hobbywing Platinum 40A
- ALIGN GP750 Gyro and DS520 rudder servo
- cyclic servos : Ino-Lab 202mg
- HAWK Carbon CF 325mm main blades
- TT Green 3D Ultra light paddle and tail blade(included)
- FUTABA FF9
- Korean brand 2.4Ghz TX/RX System
- TURNIGY Flightmax 2200mah 30C Lipo
- RHINO 2250 30C lipo
Everything can fly. I believe I can fly.
ALIGN T-REX 450 PRO V2 - Tarot DFC Head with ZYX-S
OUTRAGE FUSION 50 - 6S with 550 blades
cybernero is offline        Reply With Quote Quick reply to this message
Old 11-22-2010, 09:17 AM   #22 (permalink)
Mini titan v2
Upgrades
Carbon boom
Micro heli metal tail servo mounts
Align carbon tail blades
Electronics
Savox 0257 cyclic servos
Quark metal case gyro
Futaba BLS257 tail servo
Stock motor
Kontronik Koby 40A esc
Spektrum 6110e rx
Flight power 2200 30C packs
Danny.
600LE,610's,GP750,8900G,7100R,650 throttle,
700LE,outrage 9080's,7100R,Quark,8900,JR8917 throttle.
500ESP,510's,Futaba GY520/ds520.
Rave,Kontronik koby,Quark,bls257,hs65mg.Awesome.
lepton ex123 is offline        Reply With Quote Quick reply to this message
Old 02-28-2011, 04:08 PM   #23 (permalink)
Originally Posted by Bratwurstbratgerät View Post
My set up:
Mini Titan SE with stock head FBL conversion
-stock ESC / BLC40
-Scorpion HKII 2221-8 @ 12 teeth pinion
-Servos: Hitec HS-65HB / Savöx-SH1357(tail)
-Microbeast
-Tx/Rx: DX6i/AR6200
Blades: Main=GCT Jazz32mm / Tail=KBDD 61mm
Hello,
I've heard the Hitec HS-65HB are not a direct fit on the cyclic and that they need to be moded. What kind of mod did you have to do the make them fit?
Thx
arquitron is offline        Reply With Quote Quick reply to this message
Old 02-28-2011, 04:23 PM   #24 (permalink)
Its a really ease mod. The 65HB's are a little bit to big to fit the servo brackets. So all you need to do is take a little off of both sides of the bracket so you can slide servo in.
Danimal is offline        Reply With Quote Quick reply to this message
Old 03-06-2011, 10:00 AM   #25 (permalink)
My heli's newly built - it's only had about a dozen or so test flights/hovers around the house and has flown just great. Weather & work are the only things keeping us from the field ...
Mini Titan V1 - All plastic
HobbyWing Platinum 40A ESC with 3A switching BEC (awesome very slow start)
Exceed RC Alpha 400 3500 Kv motor (13T)
HobbyKing 6Ch DSM2 Rx
Futaba GY401
Hitec HSG-5084MG tail servo
Hitec HS-55 cyclic servos
Metal canopy mounts
Align wood main blades (some carbons ready to go too)
KBDD orange tail blades
Spectrum DX6i Tx
8x 1800-2200 20C-30C HobbyKing Lipos
2x Accucell-6 Chargers
Colored electrical tape on canopy & paddles
Custom LED Navigation Lights (work in progress)
Did I mention how great the V1 frame is? I mean it's got all of these openings, protrusions, hooks, slots, etc. all over the place. Gives you tons of options for wiring a heli and hanging other stuff on as well. That's all gone in the V2 isn't it ... ?
-John
The 180CFX doesn't have to be a handful ... http://tamingtheblade180cfx.blogspot.com
FR4-Pilot is online now        Reply With Quote Quick reply to this message
Old 03-09-2011, 10:44 AM   #26 (permalink)
Originally Posted by arquitron View Post
Hello,
Thx
If you want the links to be perfectly straight you will need to "shim them out a bit"
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 03-10-2011, 04:47 PM   #27 (permalink)
My set up is as follows
All metal align head and tail
Green paddles
11T pinion
Outlander extreme 40c 2200 battery
2221-6 scorpion motor
55 amp scorpion esc
GP750 gyro
Ds 520 on tail
Hitec HS65MG on cyclic
Spectrum Dx6i
Any carbon blades
Takes off like a gymnast on crack ! (only thanks to all the kind advise I've had on this forum)
Flying style sweaty hands 3d !
xrated is offline        Reply With Quote Quick reply to this message
Old 05-11-2011, 06:21 AM   #28 (permalink)
Mini Titan SE
Stock motor: TT OBL29/37-10H
Stock ESC: ACE BLC-40
Cyclic servos: Hitec HS-56HB
Rudder servo: Hitec HSG-5084MG
Gyro: Logitech LTG-2100T
Main Blades: RJX Fiber Glass Main Blades HA325FRP
Tail Blades: HS1047T Trex 450 3K Carbon Tail Rotor Blade
Battery: Turnigy nano-tech 2200mah 3S 25~50C Lipo Pack
Pinion: 13T
Transmitter: Hitec Eclipse 7 with Spectra 2.4GHz Transmitter Module
Receiver: Optima 7
Levus is offline        Reply With Quote Quick reply to this message
Old 05-14-2011, 08:14 PM   #29 (permalink)
My setup as follows <---- Changing all the time
Mini Titian V1
Stock Motor - OBL 26/35-10H
ESC - Eflight
Cyclic Servos - Elight EFLRS75
Gyro - wk-007
Tail servo - park zone DSV130M
Main Blades - stock woodies
Tail Blades - stock
Pinion - 13T
Radio - Turnigy 9x v2
Lipo - Turnigy 5800mah 2s
Type of flying - figure 8's as I'm still in the learning point
allan1353 is offline        Reply With Quote Quick reply to this message
Old 08-28-2011, 07:25 PM   #30 (permalink)
Here's my setup;
Mini Titan v1 kit
Torque Tube conversion
motor: stock
ESC; stock
cyclic servos: futaba S3114
tail servo: Tower Pro MG-90
gyro:gy401
cnc upgrades: upper mixing arms, lower mixing arms, swash, washout base, tail pitch lever, body post, servo trays
Canomod canopy
main blades: Thunder Power 325mm carbon blades
batt: Sky Lipo 2200mah 20c 3s
type of flying: simple forwards flight (figure 8s, circles, piros, etc). I'm almost at the point where I'm going to start looping and really sport flying
maxmax77 is offline        Reply With Quote Quick reply to this message
Old 08-28-2011, 07:42 PM   #31 (permalink)
Default Titan V2
Belt Version
Stock Motor
Stock ESC
HS 5065MG X3 (Used spacers)
Gyro JR G3703D
Tail Servo JR 3717HV
Voltz 45C 2200
TT Carbon Main Blades
Stock Tail Blades (Plastic)
Stock Canopy
Spectrum AR6110E
DX7
Some 3D, more mild flying
"Just Fly It"
Synergy E5 Ikon 7s
AMA 819728 IRCHA 2259
Lzfalcon is offline        Reply With Quote Quick reply to this message
Old 09-29-2011, 09:37 AM   #32 (permalink)
Default My Flybarless Mini-Titan v2 (RJX head / beastx)
This my FBL setup ( < go here for my complete build thread > ) :
  • RJX 450 FB head
  • Scorpion 2221-8, 13T pinion
  • CC ICE 50 ESC
  • Cyclic servo : MKS DS470 :
  • Tail servo : MKS DS8910+
  • Custom tail link pushrod
  • Carbon tail boom
  • Microbeast FBL module
  • Rx : Futaba 6 channels RX
  • Edge FBL blades
  • I am on 3S Lipo
Regards
Tom
Tomeor is offline        Reply With Quote Quick reply to this message
Old 09-29-2011, 10:34 PM   #33 (permalink)
Mini Titan E325 V1 - All plastic
Cyclic Servos – Hitec HS 56HB (No modification required, direct fit)
Tail Servo – JR DS290G
JR G2703D Gyro
CC Ice Lite 50A ESC
Scorpion HK2221-8
11T Pinion
Stock Tail Blade
Align wooden Pro blades with spacer
Pitch Curve (-5 to +11)
Throttle Curve – Set RPM Gov
HeadSpeed 2300 and 2400
Spectrum DX8
2200 20c Tunigy and Zippy Lipos
Timer: 8 Minutes
Flying Style – Circuits, Figure 8s, Sports and maybe mild 3D one day
[ame]http://www.youtube.com/watch?v=a05oBqHyVSA[/ame]
Mini Titan E325 V1 - All plastic with Cobra Fuselage
Cyclic Servos – Hitec HS 65HB (Requires modification to servo mounts and spacers needed)
JR G2703D Gyro
CC Ice Lite 50A ESC
Scorpion HK2221-8
11T Pinion
Stock Tail Blade
Spectrum DX8
Timer: 8 minutes
[ame]http://www.youtube.com/watch?v=aSoGWGh4Yto&feature=related[/ame]
cputini is offline        Reply With Quote Quick reply to this message
Old 11-19-2011, 08:59 PM   #34 (permalink)
Mini Titian V1
Stock canopy, Pro-Line "assault" in red on order
Stock ESC
Cyclic Servos - JR DS285
Gyro - Logictech LTG-2100T
Tail servo - JR DS3400G
Paddles- stock (KBDD {orange} on order)
Tail Blades - stock (KBDD 61mm Pro's {orange} on order
Pinion - 13T
Radio - JR 11X DSMX/AR6200RX
Lipo - Turnigy Nano-Tech 2200
Type of flying - cruising
Jonathan Ott is offline        Reply With Quote Quick reply to this message
Old 11-22-2011, 12:54 PM   #35 (permalink)
I didn't post mine, so here we go:
V1 plastic frame
Metal rotor hub + mixing levers upgrade
Metal tail shaft + tail pulley upgrade
Generic carbon blades (at the moment)
Turnigy Plush 40A ESC
DimensionEngineering SportBEC
Turnigy H2223-3700 motor
HXT900 cyclic servos
Assan GA-250 gyro
MKS DS8910 AVCS 760µs tail servo
Powered by Rhino 2250 packs mostly (25/30/40C)
fakyrr is offline        Reply With Quote Quick reply to this message
Old 11-26-2011, 03:47 PM   #36 (permalink)
Originally Posted by Jonathan Ott View Post
Mini Titian V1
Stock ESC
Pinion - 13T
I got my new ProLine Assault canopy and KBDD paddles and tail rotor blades installed today. Added a few decals I had in the sticker bag and it looks pretty good. I also ordered 2 sets of generic CF blades off e-Bay for $18 shipped. Here's a pic of the blades:
I'll get pics of it up when the blades come in.
Love these Mini Titans!!!!
Jon
Chaos 600E
Old 12-03-2011, 12:15 PM   #37 (permalink)
Mini TT, V1
SE, swash, tail pitch control, main hub, tail drive gear
Stock motor
Stock esc
13 tooth pinion
Helimax 315 wood blades
Carbon tail fin
HS-56 cyclic
401 gyro
9257 tail
Zippy 2200mAh w/canopy
Zippy 3000 w/o canopy
Elgyn is offline        Reply With Quote Quick reply to this message
Old 12-30-2011, 06:20 PM   #38 (permalink)
thats nothing!
turnigy typhoon motor (11$)
hk gy401b (11$)
hxt900's (2$ ea)
turnigy dlux 40 (20$ AND I LOVE IT)
some digital mg tail servo (9$)
zippy flightmax 2200 (8$) and turnigy nano tech 50c (16$)
thunderpower blades just got em today (39$)
futaba 7c 72mhz
does good 3d (havent tried TP blades yet)
total paid was 160$ and its a great setup. only upgrade was metal tail pinion belt thing.
i dont need expo because my sick is always in the corner
mrfourtysevenman is offline        Reply With Quote Quick reply to this message
Old 04-03-2012, 06:33 PM   #39 (permalink)
Mini Titan e325 Pro
Metal Head block - only real must have upgrade
Metal D-joint on tail - eliminated slop from plastic one wearing
KBDD 59mm tail blades - good visibility, work well, want to try 61mm Pro
KBDD Flybar paddles (front hole) - These rock! more agile AND more stable
Scorpion -10, 14t 3s - very efficient and quiet, 4s coming shortly after packs die
Maverikk 325mm G5 Pro VST - best blades so far, smooth, good pop and sound
Hs-65HBs on cyclic - nothing fancy, they get the job done
JR 3500G on tail - great servo, very fast, good center, worked well on my Protos
GY401 gyro - trickle down from Raptor but it will get job done til FBL
Futaba 8FG/7ch tx - Best value radio out there
Gorilla Gear - indestructible and high visibility
Align 35X ESC - work horse, will need SBEC for 4s tho and demanding servos
Blue Lipo 2200 3s - can't beat the price, don't hold voltage well after awhile but balance
Canomod Canopy - great color scheme, some trimming to fit but very nice
This is my best setup so far, a great flying machine. Smooth, quiet, very stable for a 450, flies like a much bigger bird, similar to my Raptor but sharper and quicker if desired.
The knack of flying lies in learning to throw yourself at the ground, and miss. Clearly, it is this second part, the missing, that presents the difficulties.
Team Compass Pilot
Scott Bowersox is offline        Reply With Quote Quick reply to this message
Old 04-04-2012, 07:34 AM   #40 (permalink)
I just had to do a "budget" build on a heli this spring, so I purchased the kit on the forums here(assembled but never flown) and salvaged most of the parts on my Mini Titan from another heli and my parts box. Will be upgrading some things on it as I go.. Especially the ESC since I'd prefer to run a governed headspeed.
Mini Titan V2
ZYX flybarless Controller
Mini Titan Flybarless Head
Scorpion 2221-6 3595kv motor
Eflite 35A ESC ungoverned(until the HK Helidrive 45A comes off backorder)
Hitec HSG-5084MG on rudder
Hitec HS-5065MG on cyclic
Pro 3d CF blades
Stock Tail Blades
Gens Ace 2200Mah 3s 25c
EC3 connectors
Spektrum AR6115E receiver
Spektrum Dx6i
Beam Tail Control Rod
William
Synergy N5C, 130x, Mini Protos 6s
wbefield is offline        Reply With Quote Quick reply to this message
Human Verification
