Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis
Thunder Tiger Electric Helis Mini Titan E325, Raptor E550 and E620 SE Helicopters
Old 04-29-2012, 01:26 PM   #41 (permalink)
My set up is
Thunder Tiger Mini Titian E325
Obl29/35-10H w/ 11t
Castle Creations Phoenix Ice 50 ESC
HS65HB x3
InoLabs D261 HB
Detrum GY48V
Spektrum DX6i
normal : Sport
Thro cur 0 50 80 90 100
Pitc cur 35 46.5 60 80 100
Mini Titian E325 / AH-1 Cobra
Obl29/37-10H w/11t
Exceed RC Volcano 40A ESC
HS65HB x3
InoLabs D261 HB
Detrum GY48V
Spektrum DX6i
normal : Scale/Sport
Thro cur 0 45 65 85 100
Pitc cur 35 42.5 50 75 100
NuiKai is offline        Reply With Quote Quick reply to this message
Old 05-25-2012, 02:23 PM   #42 (permalink)
Default my setup mini titan e325se
hello my mt is what I have so
SAVOX cicliclo servos
queued servo SAVOX
12t engine sprocket 3550
gyro zxy
normal gas curve 0/100/100/100/100
beautiful flies
jac_2011 is offline        Reply With Quote Quick reply to this message
Old 07-27-2012, 06:32 PM   #43 (permalink)
my mini titan
TT E325 V2 FBL
Savox sh 0257 mg cyclic servos
Savox sh 1257 mg tail servo
Stock motor and esc
Tt carbon main blades, kbdd tail blades
Carbon and aluminum parts that the kit didnt come with
Tarot zyx-s and spektrum dsmx satellite
Controlled by dx8
Just setup the fbl gyro but scared to fly it until i can havesomeone look it over
Any settings and advice will be appreciated
helifreekier is offline        Reply With Quote Quick reply to this message
Old 07-28-2012, 08:35 AM   #44 (permalink)
Originally Posted by helifreekier View Post
my mini titan
TT E325 V2 FBL
Stock motor and esc
Controlled by dx8
hello need help for the configuration of zxy
if so will try to help greetings
Old 07-28-2012, 04:20 PM   #45 (permalink)
Aloha Jac,
I just downloaded the new 3.5 version software that dr.M provided here http://www.0577mx.com/news_view.asp?clsid=15&id=268 and downloaded the fbl programming software, http://fbl.net.nz/ ,after that i started with a mild 3d preset and adjusted cyclic d gain to 10 as dr.m stated and just followed the rest of the setup... cant really let you know how she flies cause i havent dug out my balls from the hanger there is alot of info here https://www.helifreak.com/showthread...42434&page=129 and here http://www.rcgroups.com/forums/showt...12179&page=270 hope this helps as i know how stressful it can be for a first fbl gyro! Good luck
Old 07-31-2012, 08:47 AM   #46 (permalink)
Aloha Jac,
thanks greetings
Old 09-04-2012, 12:47 PM   #47 (permalink)
It seems like it's a work in progress constantly, but here's what I have right now.
v1 body
various metal head upgrades
CanoMod canopy
JR DS285 on cyclic
GY401 Gyro
Futaba S9650 tail servo
CC Ice 50 ESC
Scorpion HK 2221-8 motor
Thunder Power batteries
Walkera Devo 8S + RX802
P Max v2, G570, G500 speed, Oxy 3+, P380, XK K110, Open-TX
JWeber is online now        Reply With Quote Quick reply to this message
Old 09-04-2012, 01:25 PM   #48 (permalink)
Aloha Jac,
hi thanks my mtse 6S
Wonder flies
is a video
Battery is a torpedo with 6 elements
http://www.youtube.com/watch?feature...&v=NftwX8z06VM
Old 10-11-2012, 09:29 PM   #49 (permalink)
Well, it is nothing special, but. . .
Mini Titan e325 V1
Savox SH-0257MG X3
GY48V Gyro - DY-1017
Align DS425M
CopterX (CX-ESC-40A)
HobbyWing Switchable U-BEC 3A 5/6V V3
Turnigy Typhoon 2215H Brushless 450-Size Heli Motor 3550kv w/13T Pinion
325mm PRO 3D CF main blade
Thunder Tiger Rotor Spacer E325 V1/V2
I really like how it went together. No hitch save I had to file the mount for the rear cyclic servo a bit. It flies really smooth. It is trying to win my heart away from the Trex PRO.
Gaui Hurricane w/ 530mm blades & Robird G31
Walkera Super CP
Walkera Devo 10 w/ Deviation
SQRT(-2) is offline        Reply With Quote Quick reply to this message
Old 10-12-2012, 04:54 AM   #50 (permalink)
I fly mine with people with the t-rex. Most say if they had of seen my mini titan before buying they would of got a mini titan instead. I fly mine in up to 35km/hr winds and it flies like a dream.
Sent from my HTC One V using Tapatalk 2
B400(retired),Mini Titan V1(Retired),Radikal G20 (scrapped),Align T-Rex 500pro DFC,Synergy E5s
Digger1973 is offline        Reply With Quote Quick reply to this message
Old 03-14-2014, 03:16 AM   #51 (permalink)
I have a V1 purchased back in 2007.
Currently running:
hobbyking carbon blades (mains and tails)
original plastic tail box/grips etc.
NTM rotordrive 1700kv motor
turnigy tgy-306g cyclic servos
jr 3400g tail servo
flybarless head (cant remember where i got it from but it fits lol and has survived full pitch climbouts unlike the metal TT head that kept snapping feathering shafts)
align 3gx v4.0
turnigy nanotech 1300ma lipos
about 6.5 minutes sport flying with absolutely insane climbouts
Nige69 is offline        Reply With Quote Quick reply to this message
Old 03-14-2014, 12:01 PM   #52 (permalink)
I've significantly updated mine since I last posted:
e325S
Cyclic HiTec 5065MG
Tail MKS DS95i
Scorpion HK 2221-8 w/ 13 t pinion
Ikon FBL
Castle Edge Lite 50 ESC
RJX mains
KBDD 450 Pro tails
Using the Ikon Gov at 2800, 2900 and 2950
FrSky Taranis TX/RX
Old 03-16-2014, 07:06 PM   #53 (permalink)
Come to think of it, mine has changes a lot since 2012 when I posted...
Originally Posted by airbasher View Post
Mini Titan e325 Pro
Metal Head block - only real must have upgrade
Metal D-joint on tail - eliminated slop from plastic one wearing
KBDD 59mm tail blades - good visibility, work well, want to try 61mm Pro
KBDD Flybar paddles (front hole) - These rock! more agile AND more stable
Scorpion -10, 14t 3s - very efficient and quiet, 4s coming shortly after packs die
Maverikk 325mm G5 Pro VST - best blades so far, smooth, good pop and sound
Hs-65HBs on cyclic - nothing fancy, they get the job done
JR 3500G on tail - great servo, very fast, good center, worked well on my Protos
GY401 gyro - trickle down from Raptor but it will get job done til FBL
Futaba 8FG/7ch tx - Best value radio out there
Gorilla Gear - indestructible and high visibility
Align 35X ESC - work horse, will need SBEC for 4s tho and demanding servos
Blue Lipo 2200 3s - can't beat the price, don't hold voltage well after awhile but balance
Canomod Canopy - great color scheme, some trimming to fit but very nice
This is my best setup so far, a great flying machine. Smooth, quiet, very stable for a 450, flies like a much bigger bird, similar to my Raptor but sharper and quicker if desired.
Now
TT FBL head - now with the sport plastic guides. The links chewed through the original metal
Robird G31 fbl unit
Castle Ice 50 lite
Scorpion -10 3000kv now on 4s
Sky and Gens Ace 1800mah 4s packs
Lynx 325mm main blades (fav so far still the Maverikk G5 flybar blades)
Revolution 59mm carbon tails. Ehh, not any better really but CY not avail at the time
Still same Hitec H-65hb cyclic and jr 3500g tail.
Had this now for what almost 5 years. Has been a great little heli
The knack of flying lies in learning to throw yourself at the ground, and miss. Clearly, it is this second part, the missing, that presents the difficulties.
Team Compass Pilot
Scott Bowersox is offline        Reply With Quote Quick reply to this message
Old 10-12-2014, 11:46 PM   #54 (permalink)
Default My build...
Last post on this thread was back in march... wow. People are no longer buying/ building Mini Titans, I guess...
Here's my setup, for whatever it's worth.
E325 V2
Custom CanoMod fiberglass canopies (dragon, komodo, monster, red mask)
FBL metal head
Revolution 325mm FBL blades
Stock motor, ESC
Hitec HS-5065MG on cyclic
Futaba BLS257MG on tail
GT5.1 gyro
Torque-tube setup
CF boom
CF-reinforced tail rod (no guides)
100%-metal tail assembly
Fluorescent orange 65mm tail blades
Futaba 8J TX
Futaba RX
Armattan Chameleon 5" FPV Alien 5" FPV Loki X3 FPV QAV-R FPV QAV250 FPV ZMR 250 FPV Mini Titan V2 FBL DRL * HotProps Phoenix 5
seattleite09 is offline        Reply With Quote Quick reply to this message
Old 10-12-2014, 11:49 PM   #55 (permalink)
Stock motor, stock ESC, JR 285 MG's on cyclic, 3400G on the rudder, TT all metal FBL head, Robird FBL unit. KBDD Main and 61mm ProTail Blades!
This is a very early Mini-Titan and it just keeps going and going!
KBDD-Team Captain/Compass Team Manager/Experience R/C/ Western Robotics Field Representative
Old 10-13-2014, 01:21 AM   #56 (permalink)
I have a few, it's just that none of them are setup yet. :-/
KnifeEdge51 is offline        Reply With Quote Quick reply to this message
Old 10-20-2014, 06:54 PM   #57 (permalink)
E325 V2
FBL metal head
Stock motor, ESC
GT5.1 gyro
Torque-tube setup
CF boom
Futaba 8J TX
Futaba RX
Just pulled mine off the shelf and ordered some items last night to finish the build after a couple seasons of sitting
Nighthawk117 is offline        Reply With Quote Quick reply to this message
Human Verification
