these connectors are driving me crazy... hxt 4mm.! - HeliFreak
Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Old 10-07-2010, 08:22 PM   #1 (permalink)
Default these connectors are driving me crazy... hxt 4mm.!
how do you guys solder and insert the plastic cover on the connector..!
i bought 2 packs for these to install on my 6s batteries and i damaged almost a complete packl ( set of 10 ) just trying to connect the thing to one battery..!
https://www.helifreak.com/attachment...1&d=1286500861
hadi10 is offline        Reply With Quote Quick reply to this message
Old 10-07-2010, 11:42 PM   #2 (permalink)
Working with one wire at a time so you're sure the 2 will not come in contact with each other. Sorry for stating the obvious but I don't know your experience level and safety first. Select which wire +/- is going in to which side of the connector then slide the wire up through the plastic cover from the back side, solder the correct male/female connector onto the wire end. Now heat the the plastic cover with a hair dryer etc to soften the plastic. You'll find it easier, the softer you get it, up to a point. Now push the connector down into the cover until it snaps in. Repeat for the other side. Heating the plastic cover softens the locking ring inside so it doesn't get damaged while pushing the connector into the cover. Hope that helps.
MÔke
Tarot 450 Pro, Typhoon 2215/HW 40A Pro, 3xHS65HB, Quark/DS520, KBDD paddles/tail DX6I/AR6200
SAR1 is offline        Reply With Quote Quick reply to this message
Old 10-08-2010, 03:32 AM   #3 (permalink)
ill give it a try and let you know
Old 10-11-2010, 09:47 AM   #4 (permalink)
if they are like mine you need to thread the wires tru the plastic plug first, then solder your wires on one by one then you pull them backwards into the plug firmly i usually use a blunt object to push them in you will here a firm click! hey presto there you have it a completed plug
hope that helps
scc28 is offline        Reply With Quote Quick reply to this message
Old 10-11-2010, 02:59 PM   #5 (permalink)
They take a lot of practice !! - key is to make sure solder doesn't overflow from the joint onto the the circular bevel on the metal which snicks in to the plastic cover. You also have to put the plastic covers on first, solder, then use a spare metal connector to push it home into plastic cover while still warm.
John
Mercuriell is online now        Reply With Quote Quick reply to this message
Old 10-14-2010, 12:42 PM   #6 (permalink)
Hi,
If you do get some solder on the side of the connector - use a file to file it off before inserting into the connector.
dyuen888 is offline        Reply With Quote Quick reply to this message
Old 10-20-2010, 04:03 PM   #7 (permalink)
damn this thing sucks..!
finally i was able to insert the connector into the plastic tab..!
but now i have another problem.. on my 5800 mah turnigy packs the wires are 8 awg , i cannot pass them throught he plastic tab first and after soldering push them back into the tab.
any ideas ?
Old 10-22-2010, 06:15 AM   #8 (permalink)
yeah, Deans
pitchp is offline        Reply With Quote Quick reply to this message
Old 10-22-2010, 11:03 AM   #9 (permalink)
Originally Posted by pitchp View Post
yeah, Deans
any other ideas ?
Old 10-23-2010, 09:00 PM   #10 (permalink)
Dont even bother with the plastic covers if they are giving you that much trouble. Throw them away and just use heat shrink.
lanman123 is offline        Reply With Quote Quick reply to this message
Old 10-23-2010, 09:40 PM   #11 (permalink)
actually i can put them in now.. they just have to be heated or the plastic cover should be slightly heated.. that was the step that i skipped.
now the problem is how to solder an 8 gauge wire to the connector
Old 11-09-2010, 01:29 PM   #12 (permalink)
wrong...you should not heat the plastic at all...soldering wires to these connectors is pretty easy, watch finless vids about soldering bullets they are the same, only you have to insert the wires into the plastic sleeves first, solder and snap the bullets into place....as a rule if the wires cannot easily pass thru the plastic sleeves use the next larger connector..
GAUI EP200 V2 EX,RD631, GAUI18AMP ESC, MDS60HB, GP750+TGY1800a, TURNIGY 1000maH 30C, GAUI-5600KV 15T.
ALIGN 450 SPORT,ALIGN35AMP ESC, 450M@14T, GP780+MKS8910, 410M, RHINO 2350mah 25C, TIG CF MAIN, 5A BEC
kid_spl85 is offline        Reply With Quote Quick reply to this message
Old 11-09-2010, 04:04 PM   #13 (permalink)
there is no larger than 4mm i think
Old 11-20-2010, 07:51 PM   #14 (permalink)
ec5 connectors are 5mm and will work fine. They are eflight so your hobby shop should be able to order them or else you can get them cheap from hobbyking.
Volcano is offline        Reply With Quote Quick reply to this message
Human Verification
