Show Off Your Wiring! - Page 17 - HeliFreak
Old 04-07-2012, 01:38 PM   #321 (permalink)
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
SYMAWD is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 07:32 PM   #322 (permalink)
Originally Posted by SYMAWD View Post
whats your cyclic ball's position on all three?.......
All begins (Jun 2011).......
Next project:
MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad
cpmboy is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 08:17 PM   #323 (permalink)
It's the second to last hole on my EXI servos. I just put them where the linkages would be straight.
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
Old 04-08-2012, 01:44 AM   #324 (permalink)
thx....
Next project:
Old 04-22-2012, 09:03 PM   #325 (permalink)
Originally Posted by kgd1 View Post
Here is my 450 PROv2
Where did you get that landing gear? It looks great
Trex 500 FB - Trex 450 Pro V2 3GX - Mcpx
ChopperNoob is offline        Reply With Quote Quick reply to this message
Old 04-23-2012, 09:23 PM   #326 (permalink)
Thanks! Here you go:Metal Carbon Landing Skid
|GAUI X5|450 proV2 6s|GAUI X3|REPTILE X260| ALIEN X 500|
kgd1 is offline        Reply With Quote Quick reply to this message
Old 04-24-2012, 10:03 AM   #327 (permalink)
wats your pitch range?...I would like to move mine to the 2nd hole frm the center and get it straigh but I dunno if by doing that my pitch range will be reduced.....now -+14
Next project:
Old 04-24-2012, 03:21 PM   #328 (permalink)
I think it was around +/- 12
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
Old 05-10-2012, 04:58 PM   #329 (permalink)
Default My T-rex 450pro V2 3GX Just After Build
Here are a few shots of my wiring. I tried hard to make it clean.
Name:	450 Wiring 1.jpg
ID:	315523   Click image for larger version
Name:	450 Wiring 2.jpg
ID:	315524   Click image for larger version
Name:	450 Wiring 3.jpg
ID:	315525   Click image for larger version
Name:	450 Wiring 4.jpg
Joe K (wild about helicopters ),
Align T-rex 450 pro v2 AR7200/BeastX DFC Head
Spektrum DX6i / Spektrum ar6210 receiver,
Blade MCPX w/Lectron Pro, Blade MCX Fun Fly
joe_kowalski is offline        Reply With Quote Quick reply to this message
Old 05-15-2012, 10:15 PM   #330 (permalink)
450 pro v1 6s / HKII 2221-2010 /16t / ice 50 @ 3400 gov
mbeall is offline        Reply With Quote Quick reply to this message
Old 05-17-2012, 04:46 PM   #331 (permalink)
Here is my Trex 450 Sport V2. Wiring was very interesting due to the numerous complications caused by the new super narrow frame.
Setup:
- Align Trex 450 Sport V2
- Stock Align DS410M Cyclic and DS420 Tail servos
- Castle Creations Phoenix 35 governed at 3200 rpm (which I believe is inaccurate and closer to 3400)
- Stock Align 450MX motor
- Hyperion 2200mah 11.1v 35c Li-Po
- Spektrum AR7200BX flybarless
- Align 450 DFC head
- KBDD Orange dampers (these are a must as the stock DFC dampers are too short)
- Edge 323mm Flybarless blades (had the tails on there too, but I cracked one on an awkward landing
ID:	317457   Click image for larger version
ID:	317458   Click image for larger version
ID:	317459   Click image for larger version
Corinator is offline        Reply With Quote Quick reply to this message
Old 05-21-2012, 12:45 AM   #332 (permalink)
That's probably one of the cleanest 450's I've ever seen. I see the elevator servo lead, how did you route the others? Nice work.
Vinny ///M3 is offline        Reply With Quote Quick reply to this message
Old 05-22-2012, 03:40 AM   #333 (permalink)
Thanks for the compliment, I am very anal about my wiring and helicopter setup as you can probably tell.
The Aileron, Pitch, and ESC servo lead are run along the upper frame halves along the zip ties holes. The Elevator is joined in with the Aileron and ESC leads where it is then routed between the tail block and upper frame halve. The hardest part is getting the wires past the tail servo chassis mount. I figured people would ask how I routed the wiring as it is so hard to see. That is why I took the picture with the lower frame halve off. I can take more detailed photos of certain areas if you'd like to see something in particular.
Old 05-22-2012, 03:43 PM   #334 (permalink)
Default we have the same wiring
same wiring set up but tyring to figure it out how to post picture but i did not use mesh wire to my sport v2 so you have a rc shop can i ask a question my nimh battery is dying can i hook up my lipo battery 2200 mah 28c to my tx it is optic 6
laurence is offline        Reply With Quote Quick reply to this message
Old 06-02-2012, 01:34 PM   #335 (permalink)
Default Wire covering
Where do I get the wiring sleeves/protection I see in all the pictures?
cigarboo is offline        Reply With Quote Quick reply to this message
Old 06-05-2012, 01:13 AM   #336 (permalink)
The wire braiding I use is this stuff: http://www.amazon.com/gp/product/B00...ls_o00_s00_i00.
Well worth the money. The 1/8 is the tightest fit you can put on a standard servo lead. In order to install you need to remove the pins from the servo connector. It is time consuming but well worth the effort.
Old 06-26-2012, 03:43 AM   #337 (permalink)
Here a few of my align 450 pro v2 pics after fitting a castle ice 50 ESC under the battery tray.
It's tough as hell to do but not impossible. Even with the stock battery tray
Plenty of clearance around the motor too.
Mike Martin, MSH BRAIN USA Team Manager
MSH USA FLIGHT TEAM,
CYCLONE BLADES, XNOVA MOTORS,
JETI USA
www.MSHUSA.com, www.MSheli.com
mamartin is offline        Reply With Quote Quick reply to this message
Old 06-26-2012, 03:57 AM   #338 (permalink)
Heres a few more
JETI USA
Old 06-28-2012, 04:20 AM   #339 (permalink)
This is a 450 Pro I built and setup for a customer. Box stock setup with the 3gx flies surprisingly well, I just don't like the feel of a non-governed setup.
ID:	327684   Click image for larger version
ID:	327685   Click image for larger version
Trex 250 Pro DFC MSH Brain - Trex 450 Sport V2 DFC MSH Brain - Trex 600 ESP DFC MSH Brain - Trex 700E DFC HV
Feel free to check out my YouTube channel for flight videos http://www.youtube.com/corinator
Old 07-03-2012, 10:03 AM   #340 (permalink)
Hey fellas, well I crashed my 450pro, and as I had to replace the frames I dicided to go with some fununo neon green ones . Plus I tidied up my wiring haha
Regards
ID:	328935   Click image for larger version
ID:	328936   Click image for larger version
Daz450 is offline        Reply With Quote Quick reply to this message
Insurance
Human Verification
