Old 10-28-2010, 04:42 PM   #1 (permalink)
Default cc25 settings
hi i really need some good 3d settings for my cc25 for jr fest any help would be great thanks!
i run scorpion 3900kv
16t
Trex 450 Pro-Radix Paddles-Edge tail blades- Radix Blades- ICE 50-12t- Hitec HS-65MG
Trex 250 SE-Scorpion HK-2206-3900-Castle 25A-Jr 3500g-GY520
Outrage Fusion 50 FBL-V-Bar 5.1
SkinnyMcGee is offline        Reply With Quote Quick reply to this message
Old 10-28-2010, 05:02 PM   #2 (permalink)
Hex55: 85
Brake Strength: 0
Brake Delay: .6 sec (Delayed) (*)
Brake Ramp: Immediate (*)
Cutoff Type: Soft Cutoff
Motor Start Power: 59
Direction: Forward (*)
PWM Rate: 12 Khz (*)
Vehicle Type: Helicopter
Throttle Type: Governor Mode
Throttle Response: 5
Governor Gain: 32
Initial Spool-Up Rate: 5
Head Speed Change Rate: 13
Auto Rotate Enabled: False
Governor Mode Type: Fixed
Vehicle Setup - Battery Type: LiPo
Vehicle Setup - Number of Cells: 3
Vehicle Setup - Battery Voltage: 11.10
Vehicle Setup - Gear Ratio: 8.0000
Vehicle Setup - Pinion: 15
Vehicle Setup - Spur: 120
Vehicle Setup - Motor Kv: 3900
Vehicle Setup - Motor Number of Poles: 6
Desired Head Speed 1: 3750
Desired Head Speed 2: 4000
Desired Head Speed 3: 4250
Current Limiting: Insensitive
Cutoff Voltage: Auto Li-Po (*)
Motor Timing: 5
Power-On Beep: Enabled (*)
Auto-Lipo Volts/Cell: 3.2 Volts/Cell
these good?
Old 10-28-2010, 05:46 PM   #3 (permalink)
Hiya,
One thing..... set the PWM to 8khz for the scorp motor
RIP
BEAM E4 ~ds760+S9257~HS-5065~2221-8~ CC45~Eagletree+GPS
250SE~CC25+Scorpion 3900~HS-65HB~Quark~DS290~All metal ugrades~KDE
Cadjocky is offline        Reply With Quote Quick reply to this message
