Mikado V-BAR Mikado V-Stabi/V-BAR Flybarless System Software and Hardware Support |
#1 (permalink) |
![]() Edited since the playing field has changed:
If you run DSM2 satellites - Run Spektrum Satellites 1 or 2 Digital Center in the VBar (will be 22ms/1024) If you run DSMX satellites with a DSM2 radio - Run Spektrum Satellites 1 or 2 High Resolution in the Vbar (will be 11 or 22ms/2048) (or you can same as DSM2 satellites) If you run DSMX satellites with a DSMX radio (DX8) - Run Spektrum DSMX satellites 1 or 2 in the VBar (11ms/2048 with DX8) Last edited by MrMel; 04-01-2011 at 03:49 PM.. |
#2 (permalink) |
![]() Does the setup default to lowres mode? I'm running a 9303, but I'm not sure what mode I'm running. I don't remember specifically enabling a highres more...
Thanks -David
Trex500 sk360 | Logo400 vbar | Logo500 vbar | logo 600se vbar | Synergy N9 sk360 | E-Aurora vbar | Mini Protos beastX | mcpX |
#3 (permalink) |
![]() Do you have any idea how this may affect the Total-G FBL unit. Can you further explain the 9303 bug?
#4 (permalink) |
![]() That's a little more info here http://www.vstabi.info/forum/read.php?26,51050
"It's not just a hobby... it's a lifestyle" - Pete ϟ MINNESOTA! Goblin 500 + 700 / SK540 / Jives / DX8 / Quantum / RJX servos / 306b / Deep cycles |
#5 (permalink) |
![]() The problem has also been evident with Hi-Res modes and the JR 11x with my own setups. I believe the transmission protocal between the JR series radios for 2048 resolution is the same.
-- KDE Direct, Inc. -- |
#6 (permalink) |
![]() How do I switch back to LowRes? There doesn't appear to be any instructions on vstabi.
vbar T700E v2 DFC head, Pyro 700-45L, Jive 120HV, BLS451/BLS251, Edge 693/115 vbar CF Protos Scorp 3026-880kv, Ice lite 75, 9650/BLS251, SAB 430/KBDD 82 |
#7 (permalink) |
![]() Join Date: Apr 2005
![]() Download latest version, in the Bind screen (Receiver) there is Spektrum Satellites, that's lowres (other is specified as hires)
#8 (permalink) |
![]() Got it. Thanks!
#9 (permalink) |
![]() After 20 hours straight testing, this has been expanded to all Spektrum users.
I have edited the first post and added the official word from www.vstabi.info |
#10 (permalink) |
![]() Is it safe to run hires mode if you're only using one satellite?
#11 (permalink) |
![]() No not at all, thats even worse than running 2
#12 (permalink) |
![]() But, for a different reason. Shadowing is an issue with a single satellite, especially when CF frames are involved.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Protos Max Evo 700 (Brain 2), Protos Max V2 770 (iKON 2), Synergy 516 (Brain 2), Oxy 2 (Falcon 12) Graupner MZ-32 Experience is something you gain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
#13 (permalink) |
![]() That too, but for the same reason as above, when you hit this "bad data transmission" using one satellite could mean 99% packet loss (managed that in a test)
#14 (permalink) |
![]() I though you had said that it only came into play with two satellites. This story just keeps getting curiouser and curiouser.
#15 (permalink) | |
![]() Quote:
Lets say it happens 1% of the time with two satellites, it might happen 10% of the time with one satellite (just relative numbers from my testing, does not mean you will see it 1% in your environment) |
#16 (permalink) |
![]() is it a VBAR internal receiver thing or a Spektrum thing?
I'm using the full size VBAR and a seperate Spektrum reciever. I suppose I'm fine, but confirmation would be nice :-) |
#17 (permalink) |
![]() Depends on what receiver and how many total receivers (internal plus satellites)
#18 (permalink) |
![]() Spektrum DX8
AR8000 receiver one satelite Black full-sized VBAR (no internal receiver) |
#19 (permalink) |
![]() Happened with my 12X today. Periodic brief uncommanded control inputs. Usually goes away if I reboot the Heli.
Switched to lo res and issue gone.
Robbie |
