Old 02-03-2011, 05:17 AM   #81 (permalink)
http://www.horizonhobby.com/Content/DSMX.html
Can I add "Finally"
http://heli.dacsa.net
Old 02-03-2011, 07:17 AM   #82 (permalink)
Originally Posted by MrMel View Post
It's interesting that the DX7SE cannot be upgraded but the DX7 can.
HeliFreak Support
Graupner MZ-32
Old 02-03-2011, 11:40 AM   #83 (permalink)
ok I have my 700E built and ready to put electronics in, now I am too scared to fly it with the vbar and spectrum satellites. Should I just get a separate receiver???
jaync is offline        Reply With Quote Quick reply to this message
Old 02-03-2011, 11:46 AM   #84 (permalink)
No issue to run Satelites as long as you bind them in normal mode "spektrum satellites 1 or 2" option
Old 02-03-2011, 02:21 PM   #85 (permalink)
I didn't watch the video yet, but will the VBar (sats) remain compatible??
T-rex 700n VBar 5.3 Pro | T-rex 700e V3 VBar 5.3 Pro | JR DSX9 Limited
Team RCBits | Team Lynx
HiroboFreak is offline        Reply With Quote Quick reply to this message
Old 02-03-2011, 09:51 PM   #86 (permalink)
First thing that comes to mind with DSMX being so much more robust they say. I wonder when there are DSMX sats if that will solve the "High Res" problem so we can run it again???
futurase is offline        Reply With Quote Quick reply to this message
Old 03-01-2011, 06:39 PM   #87 (permalink)
Spektrum have changed the data protocol that is output from the DSMx sats so they currently do not work with VBAR.
I am sure Ulrich from the Vstabi team will release a firmware update in the near future which will address this issue.
I would say more than likely it will not be an issue with the DSMx sats as the latest DSM sats seem to work ok in Hi Res mode.
We would of course need to test it to be 100% certain.
Costas is offline        Reply With Quote Quick reply to this message
Old 03-09-2011, 01:24 PM   #88 (permalink)
I purchased 2 of the new DSMX satellites and bound them in high res using a JR 11X to my vbar. Is this OK or should I go back to low res?
I tested the heli briefly - 2 packs - and all seems normal
Minicopter Diabolo 800+ - Minicopter Triabolo - Srimok FAIFA
Jeti DS-16
tribe3 is offline        Reply With Quote Quick reply to this message
Old 03-17-2011, 10:29 PM   #89 (permalink)
I too have two DSMX sats coming via RH for my Mini Vbar.
I have been flying in Hires mode with my two year old DSM2 sats since getting my DX8 in early Feb.
The only problem I have had is that sometimes my Tx won't link to my Rx. The binding process goes OK it's just that sometimes the Tx and Rx won't link. To fix this I turn the Tx off/on and it links to the Rx fine (I know it's poor practice to have the Rx on with the Tx off but it seems to be the only way to overcome this problem for the time being).
Cheers,
Jayson
Regards, Jayson
Logo 800Xx Silverline, Pyro 850-40L, Kosmik 200, 14S, 157 & 256 @ 8v
Logo 400SE Silverline, Pyro 600-09, Jive 80+HV, 8S, 9660A+ 8900G @ 6v
Jays200 is offline        Reply With Quote Quick reply to this message
Old 04-07-2011, 05:19 AM   #90 (permalink)
No problems anymore. All DSMX'd up with faster linking times. All's good.
Regards, Jayson
Old 04-11-2011, 04:44 AM   #91 (permalink)
Hi,
and for you, there is no problem with SAT DSMX and JR X9303 ? In HiRes mode ? Or is this preferable to go in NO HiRes mode ?
Oli 69 is offline        Reply With Quote Quick reply to this message
Old 04-11-2011, 05:53 AM   #92 (permalink)
With the DSMX satellites you can go HiRes mode.
That said, there is no real benefit unless you run a radio with higher framerate (11ms)
Old 04-11-2011, 07:04 AM   #93 (permalink)
Merciiiiiiiiiii :-)
Old 06-27-2011, 01:43 PM   #94 (permalink)
Default Which satellite should I use to get 2048 with no external receiver?
Hi,
I had a crash with my 3G hardware after 3.0 firmware upgrade, and now I think it is time to try the V-BAR.
I have a JR 9303 with DSM2, I did not upgrade it to DSMX.
The heli is a Trex 600 HV (12S) with Align DS 620 servos, and Futaba BLS 251 on the tail.
I would like to use the Fullsize V-Bar, without a JR receiver, in a 2048 resolution.
Is this possible? Which satellite should I use, considering:
http://www.readyheli.com/SPM9645-Spe...r_p_38047.html
http://www.readyheli.com/JRPRR121-Re...e_p_34596.html
There is a need for upgrading the version to 5.1? Or the 5.0 express has the 2048 resolution?
I'm not a Pro pilot, only basic 3D flying.
Since I'm using 9303, I believe there is no benefit in running 2048 resolution, should I used the satellites I already have, (non DSMX) and stick to the 1024 resolution, and save some money?
Thanks a lot!
rgmorales is offline        Reply With Quote Quick reply to this message
Old 06-27-2011, 02:22 PM   #95 (permalink)
You cannot feel the resolution, it's marketing, frame rate is another story but resolution, nope.
So keep your existing satellites and go "Spektrum satellites 1 or 2 Digital center" in the VBar is my recommendation.
Old 06-30-2011, 09:42 PM   #96 (permalink)
What is the difference between spektrum DSM2 sat 1 or 2, and Spektrum DSM2 sat digital center?
snjbird is offline        Reply With Quote Quick reply to this message
Old 06-30-2011, 09:44 PM   #97 (permalink)
The "digital center" option requires little or no subtrim and little or no travel adjust changes. I think the "digital" refers to digital servos.
HeliFreak Support
Graupner MZ-32
Old 06-30-2011, 09:49 PM   #98 (permalink)
OK, and using/ binding with that and my 9303/DSM2 sat will yield low res, and keep me out of this issue? But binding in Spektrum DSM2 1 or 2 sat would get me the same resolution 1024, but I might need more sub trim, and travel adjust to "zero" my transmitter settings?
PS thanks Alan
Old 06-30-2011, 09:51 PM   #99 (permalink)
PS thanks Alan
Yes, and yes.
HeliFreak Support
Graupner MZ-32
Old 06-30-2011, 09:55 PM   #100 (permalink)
Is the digital just the new freshness, how did I miss this? Did it come with 5.1?
