What parts are needed to conver a 425 into a 550 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 11-09-2010, 12:42 AM   #1 (permalink)
Default What parts are needed to conver a 425 into a 550
Im very curious......
OSCAR WILDE: A little sincerity is a dangerous thing, and a great deal of it is absolutely fatal.
| Gaui Hurricane 550 | Gaui 200 v2 SE | Phoenix Sim | Team ACME |
MicroMan is offline        Reply With Quote Quick reply to this message
Old 11-09-2010, 01:42 AM   #2 (permalink)
The cheapest way would be to get the Long tail boom conversion kit. # G-204663.
It comes with the boom, tail control rod and 575XL belt. You would also need the larger 550 size fly bar paddles and tail blades, and of course, main blades. That is about it for parts, although you would need to change gearing for a lower head speed or buy a lower kv motor depending on what you are using now.
I don't need the latest and greatest. I just need more time to fly what I have.
Align 450 Sport V2, Gaui 200, Gaui 425 x 2, "HeadHunter 500, Gaui 550, all Flybar'd
Jerrymac is offline        Reply With Quote Quick reply to this message
Old 11-09-2010, 06:02 AM   #3 (permalink)
The Trex 600 landing gear is a nice addition also along with a 550 canopy...just adds to the size and flies different. A Castle Ice 75 for additional tunning options if desired.
Trex 500ESP - Gaui 425 - Gaui 550 - MCP-x
Robertwav1 is offline        Reply With Quote Quick reply to this message
Old 01-10-2011, 05:29 AM   #4 (permalink)
Hi
Just to make sure are these the missing parts (In addition to Long tail boom conversion kit) ?
1. H550 Flybar Paddles Set (204534)
2. H550 Tail Rotor Blade Set (204554)
3. Main Rotor Blades Pack(W. 550L ) (204303)
4. I still don't have a motor but any recommendation will be great,I am using Phoenix ICE 75 Brushless ESC (http://www.heliguy.com/Extras/Electr...Brushless-ESC/).
Thanks.
justlikeit is offline        Reply With Quote Quick reply to this message
Old 01-10-2011, 09:57 AM   #5 (permalink)
re the motor - how do you fly ? How experienced are you ?
Mikej is online now        Reply With Quote Quick reply to this message
Old 01-10-2011, 11:53 PM   #6 (permalink)
I have a great motor for you ! scorpion 4020-910KV nice power house , like new, I was going to build a 550 but got a LOGO 500 sooooo ....
Pm if interested
DIABOLO - Spirit
goblin 500 Sport-- Spirit
TDR 1 2011-- Spirit
Kasama Faifa 700 -- Spirit
joliecoeur13 is offline        Reply With Quote Quick reply to this message
Old 01-11-2011, 12:25 AM   #7 (permalink)
1. About experience, I am a beginner.
2. Where can i buy these parts from?
Thanks.
Old 01-11-2011, 01:50 AM   #8 (permalink)
Thanks.
The Z-power ( or Tonic-x at HeliDirect ) Z20-980kv or Z30-1100kv motors are very popular for the Hurri 550. As for the other parts, the 3 main places here in the states that I know of to get Hurri parts are, HeliFlightCenter, RCDumbthumbs, and AlleRC.
Old 01-11-2011, 05:31 AM   #9 (permalink)
As Jerry said - go for a Z20A980 or scorpion 3026 1000, try Helidirect and Flying-Hobby
Old 01-15-2011, 09:42 PM   #10 (permalink)
Hi,
I also got a 425: And i think I might give him bigger blades
What is the best size to begin with? keeping it 425mm or upgrading to 470mm /upgrading 500mm.
430mm and 470mm seems to be better to find good fiberglass blades ( I don't want to start with carbon fiber blades). Wood one are cheap but I am afraid to brake them often
550 mm seems a lot for me now (but I already have 550 mm upgrade parts)
It is a plastic frame 425.Does it change the max blade size. I know MSH protos blade increase is recommanded only for CF frame
I get the heli with Z20 1700Kv but I will receive a Z20 980Kv next week
milliotseb is offline        Reply With Quote Quick reply to this message
Old 01-16-2011, 01:03 AM   #11 (permalink)
Originally Posted by milliotseb View Post
Hi,
I have tried my Hurris with 425mm, 475mm, 500mm and 550mm blades - my personal preference is for 500mm blades.
I used 500mm woodies for a long time and was very happy with them for hovering, circuits, loops etc. - I then found some low cost 500mm CF on HobbyKing (Z-weave) and now use them. If you crash with woodies and they break it saves the damage from possibly spreading further as it might if they don't break. However I generally find that in any crash that blades, boom, main shaft will break plus some other bits depending on the type of crash - irrelevant of the type of blades.
You can use any of the blades sizes with the plastic frame, the Z20A 980 is an excellent choice - I think that you will really enjoy flying a bigger heli
Old 01-16-2011, 02:02 PM   #12 (permalink)
Let's say i will buy the Z30-1100kv motor, which pinion will be the best for it?
Thanks.
Old 01-17-2011, 04:38 AM   #13 (permalink)
Thanks.
For a beginner using the Z30 1100 kV and 550mm blades I would suggest a 60T primary gear and a 15T pinion - don't just change the pinion - if you used a 15T pinion and a 42T primary you would be geared much too high
Old 01-17-2011, 08:38 AM   #14 (permalink)
Thanks, another question please:
Me and my friend are building together but he is advanced, We would like to get suggestion for him about engine, primary gear and pinion for 550 blades.
Thanks.
Old 01-17-2011, 09:41 AM   #15 (permalink)
for 550mm blades you can go as low as 1800rpm HS (you possibly could go even lower) - a 15T pinion would be perfect for this with a throttle % of 80%, your friend could run the same pinion and run a 95% TC to give around 1900 or go with a 14T pinion and a 50T primary gear to take the HS up to 2100rpm (or even 2200rpm on a flat 100%). 2200 should be all that he needs on 550mm blades, but he can go higher still with a 15T pinion.
I generally fly with 500mm blades so perhaps one of the 550mm blade guys can chime in also ....
Old 01-17-2011, 09:56 AM   #16 (permalink)
2200 RPM on 550 blades should be plenty - but make sure that you have a strong motor and high C packs.
You will of course need CF blades and CNC grips if you plan to run that HS and fly agressively.
The z30 1100Kv is a pretty powerful motor, other options might be some of the Scorpions but if you are using a plastic frame be careful... the frames flex with these more powerful motors and you will strip drive gears. You really need a CF frame is you're going for the more powerful motors (over 1500 watts).
ukgroucho is offline        Reply With Quote Quick reply to this message
Old 03-19-2011, 01:25 PM   #17 (permalink)
Hi
I decided to go on the z30 1100K, with the basic 425 kit (Advanced user) which pinion and gear (If needed to replace) do i need for:
1. 500mm blades.
2. 550mm blades.
Thanks.
Old 03-19-2011, 06:24 PM   #18 (permalink)
HF MR Support
Default Z30 / 1100
...With that motor, I see a 15t pinion and 42t 1st. gear will give you 2499 head speed (92% efficient)
15/50 will give 2099HS
84% Efficient will be lower, 2281 / 1916
both good for the 500 / 550 blades !
PT
Gaui 550(Need GOT ONE!) / KK2.1.5 steveis pro/ZMR250 / Alien 450 camera ship / HJ 450 all W/KK2.1.5 Steveis pro Estes Nano/ Hubsan X4 / Syma X1
AMA 953414 CONTRIBUTOR, TEAM LAVAQUAD
PTcaflyer is offline        Reply With Quote Quick reply to this message
Old 03-20-2011, 07:20 AM   #19 (permalink)
Can you give me the link to GAUI calculator?
Thanks.
Old 03-20-2011, 07:55 AM   #20 (permalink)
I'm using the one attached
Jack2010 is offline        Reply With Quote Quick reply to this message
Insurance
Human Verification
Copyright © VerticalScope Inc. All rights reserved.
