Old 11-28-2010, 08:52 PM   #1 (permalink)
Default Proper High Current Setup
Maybe the mod can get some stickies started?
Helico-pteron is offline        Reply With Quote Quick reply to this message
Old 11-29-2010, 04:18 AM   #2 (permalink)
Here's my little contribution: basically the same, jsut different equipment
This is my T600 LE setup.
Ben
Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251
DX8, RF6
HeliBenj is offline        Reply With Quote Quick reply to this message
Old 12-22-2010, 11:33 AM   #3 (permalink)
bump
Old 01-03-2011, 01:24 PM   #4 (permalink)
can't u just run HV through the beast X? Specs look up to it, but now I'm hearing some rumors that you shouldn't run HV through the beast X unit????
KBDD
MKS Servos
Scorpion Power Systems/Batteries
Spartan RC
John Cook is offline        Reply With Quote Quick reply to this message
Old 01-03-2011, 01:49 PM   #5 (permalink)
Love the fancy drawings. I checked the spec. The Beast is good for HV. Not that this is any use if you have to fly a split-voltage setup coz you have an old-fashioned LV tail. Still, I think you guys are too fancy. Why not simply run everything of a 5V BEC and then peel away the +/- lines from the swash servo plugs. Insert these lines into a second plug, then simply connect those to a second 6V+ BEC/2s Lipo. That's my plan, since I need to beef up my current BEC anyway.
ollie2893 is offline        Reply With Quote Quick reply to this message
Old 01-03-2011, 02:09 PM   #6 (permalink)
You won't run your HV cyclics through it.
Old 01-03-2011, 02:10 PM   #7 (permalink)
I run a straight 2s lipo in my Nitro and E helis. I either use an Outrage HV tail servo or use the Spektrum 5.3v regulator for the tail. I want to MAKE SURE though that 8.4v to the Beast X is going to be ok. The specs say it is, but I've read in some threads that people were having issues. But I can't find specific cases, just rumors.
KBDD
MKS Servos
Spartan RC
Old 01-03-2011, 02:35 PM   #8 (permalink)
Hey Matt. Didn't see your reply before I posted a repsonse.
Don't mean to be obtuse, but what is the issue trying to run 8.4v through the Beast X unit and cyclics? If it can't run that voltage then why is it spec'd for higher volts. I don't like running regulators as I like a simple/clean setup and less points of failure then.
SPECS:
Operating voltage: 3,5V...8,5 V DC (Lipo 2s possible)
Processor: 32Bit ARM
Analog processing: 17Bit
Sensor technology: 3 MEMS angular rate sensors
Adjustable servo center pulse width:
Tail: 760μs / 960μs / 1520μs
Adjustable servo pulse rate:
Tail: 50 Hz / 165 Hz / 270 Hz / 330 Hz
Swashplate: 50 Hz / 65 Hz / 120 Hz / 200 Hz
Build-in swashplate mixer:
Mechanical / 90 / 120 / 140
Serial pulse input:
PPM / S-BUS / Spektrum-satellite*
Size: 34 x 25 x 13,5 mm
Weight without cable: approx. 20 g
KBDD
MKS Servos
Spartan RC
Old 01-03-2011, 02:53 PM   #9 (permalink)
I run my cyclics straight from the battery, only signal passes thru the beast. Yes, it will handle 8.4v easy, it's the load on it that causes the bottle neck effect.
My recommendation is to separate cyclics from the unit. There are a few different diagrams on how to do this with or without a reg in the BeastX forum here.
Old 01-03-2011, 03:18 PM   #10 (permalink)
simple question and looking for a simple answer Yes/No
Im running HV outrage servos for cyclic and tail can i just run a 2s pack into my AR7000 RX to micro beast?
Compass 7HV 9180/9188 Vbar
Compass 6HV 9180/9188 Skookum,4025-630KV
Compass 6HV Savox/ 9188, Vbar,
Fusion 50 9080/9088 Beast X
Velocity 50n 9080/9088 VbarSAB Goblin 9180/9188 Kontronik helijive Coming soon
AnTi Taco is offline        Reply With Quote Quick reply to this message
Old 01-03-2011, 04:51 PM   #11 (permalink)
Short answer- yes, but all that current passes through the BeastX.
Better answer- do one of these
https://www.helifreak.com/showpost.p...2&postcount=12
https://www.helifreak.com/showpost.p...4&postcount=13
Only TWO connectors provide power to your whole system after the beastx, elev and ail.
Old 01-03-2011, 06:11 PM   #12 (permalink)
yeah i have no idea what im looking at im just gunna plug my 2s pack like normal or just buy another vbar
Old 01-03-2011, 06:34 PM   #13 (permalink)
Whatever makes ya happy.
Old 01-04-2011, 12:06 AM   #14 (permalink)
Member
Looks like as good a thread as any for a first sticky.
Old 01-12-2011, 03:06 AM   #15 (permalink)
Another option: swash servos at HV and tail servo at VBEC.
Name:	double source MB.JPG
GAUI addict: EP100 PRO, EP100 V1, EP200 V2 BeastX/satellite, EP255 BeastX/satellite.
Now, TREX 250 SE BeastX/satellite as well.
egicar is offline        Reply With Quote Quick reply to this message
Old 01-12-2011, 03:44 AM   #16 (permalink)
Completely reasonable/logical solution!
Thanks egicar
clicky is offline        Reply With Quote Quick reply to this message
Old 01-12-2011, 05:36 PM   #17 (permalink)
Can you post the other one?
Old 01-13-2011, 06:18 AM   #18 (permalink)
Sorry, what other one?
Old 01-13-2011, 06:52 AM   #19 (permalink)
When you power feathering servos through microbeast and tail servo separately.
Old 01-13-2011, 08:24 AM   #20 (permalink)
OK!
This schema has a VBEC for RX, Microbeast and SWASH servo and another power supply (XV) for the tail servo.
Please, remember that in this configuration you shouldn't use high current swash servos, becasue the Microbeast V+ copper tracks are not designed for high current.
Name:	double source MB1.JPG
