Like Tree1Likes
Old 06-03-2012, 05:17 PM   #41 (permalink)
Default Great videos
Just wanted to say thanks for taking the time to make these videos. They helped me out in my set up and saved me tons of time.
Adam
SMOKEMASTER60 is offline        Reply With Quote Quick reply to this message
Old 06-11-2012, 07:38 AM   #42 (permalink)
Default AR7200BX vs BeastX
guys, 1st, thanks for the vids!
OK... Being new to all this FBL stuff, other than the obvious, is there anything different between the two? if so, what do I need to do as far as anything different during setup/programming?
3M
DX8, HK-450V2, EXI-450, CopterX-450, HK-600GT-FBL DFC and AR7200BX (BeastX)
Mad Man Mark is offline        Reply With Quote Quick reply to this message
Old 06-11-2012, 11:24 PM   #43 (permalink)
Same FBL insides, the AR just includes a Spektrum RX in the same case. Setup is the same, but you skip the RX type steps on the AR7200BX.
-DX8
desertstalker is offline        Reply With Quote Quick reply to this message
Old 11-05-2012, 12:25 PM   #44 (permalink)
This is great I will be watching these tonight. Thanks, Plank
3dplank is offline        Reply With Quote Quick reply to this message
Old 01-12-2013, 06:17 AM   #45 (permalink)
Just wanted to say thank you taking the time to make these videos. They helped me to get an idea what are the next steps for me to make the T-REX ready for maiden flight this summer
bitbyter is offline        Reply With Quote Quick reply to this message
Old 03-03-2013, 05:54 PM   #46 (permalink)
One step i'm a little concerned with, Step L - Adjusting the cyclic swashplate limit
Let me see if I understand this. I take my cyclic stick and move it up and to left to see deflection. If I want more, I use my rudder stick - making sure the light stays blue at say 10-12 degrees cyclic pitch. Anyway, from that point, I assume I repeat the above process with the 3 remaining cyclic inputs, (up and to the right, down and to the right and finally, down and to the left).
Just to clarify, when I'm moving my cyclic down and either to left or right, I'm assuming I'm still wanting to see 10-12 pitch with blue light.
Is this correct?
nexus2911 is offline        Reply With Quote Quick reply to this message
Old 03-03-2013, 06:35 PM   #47 (permalink)
Just wanted to post to this thread and thank you for doing these instructional videos. When you are a newbie like me, reading the instructions first is a must. But it is so helpful to actually see someone do the things in the manual - EXTREMELY beneficial.
So, thank you very much. My BeastX is set up and ready to be inspected by a pro just prior to it's maiden flight.
Awesome!
/Hal
____________________________________________
Goblin Kraken, Goblin RAW - VBar Neo
MIKADO VControl Touch | iCharger 406 Duo | Meanwell RSP-1500W-24V
CaptHal8HS is offline        Reply With Quote Quick reply to this message
Old 05-17-2013, 04:30 PM   #48 (permalink)
Good thread, videos are very helpfull. Sometimes the manuals can be hard to understand, but seeing in a video is much better..
http://www.alignrccdn.com/
Mr.Gobler is offline        Reply With Quote Quick reply to this message
Old 08-08-2013, 03:01 PM   #49 (permalink)
Great videos, clear and to the the point
Grahamc
Grasie is offline        Reply With Quote Quick reply to this message
Old 08-14-2013, 07:13 AM   #50 (permalink)
Thumbs up
Great vids!
Can you make videos of the parameter menu also??
Thanks.
dgunawan is offline        Reply With Quote Quick reply to this message
Old 09-04-2013, 10:54 AM   #51 (permalink)
Thank you SOOOO much for these videos! This actually helps me with a setup problem I have been having...
dpullen is offline        Reply With Quote Quick reply to this message
Old 09-04-2013, 11:08 AM   #52 (permalink)
I was wrong...this answers a BUNCH of questions that I had. Thanks again for saving me a ton of trouble and angst!
Old 05-27-2014, 06:45 PM   #53 (permalink)
Default great videos
thanks for the post . great help with my beast x setup on my dominator! thanks again
nick1078 is offline        Reply With Quote Quick reply to this message
Old 07-15-2014, 06:37 PM   #54 (permalink)
I have a Blade 500 X with Beast in the stock position, upside down underneath. I have read you can power up with the heli on its side but that makes me nervous and I haven't tried it yet. What is the best way to power up amd make adjustments in this configuration?
Blade 450 3D, 500 X, 480 Fusion Stretch to 550. Align Trex 700DFC, 700X Dominator. Traxxas Aton, DJI Spark.
wehlke is offline        Reply With Quote Quick reply to this message
Old 07-28-2014, 03:55 AM   #55 (permalink)
Hi,
the unit only measures rotation rates, not the absolute position. It makes no difference if the heli is standing on the ground, lying sideways or whether it is upside down during initialisation (and so it also makes no difference if the unit is mounted in normal or inverted postion) Only make sure that it does not get moved when sensor zero positions are being calibrated.
best regards from Germany
Stefan
BEASTX r&d Team
freakware.com
Frenchdress is offline        Reply With Quote Quick reply to this message
Old 04-09-2015, 01:46 PM   #56 (permalink)
Default AR7200 bx help needed please
Hey guys, I crashed my 500x so I have it rebuilt and replaced the servo gears. Went through the beast and got everything centered, etc. But now when I hit throttle hold, it shows on my DX8 however the swash doesn't lower like it did before. Now even thought I can see hold on the radio...if I move the throttle, it still acts like its in hold. But before when I hit throttle hold, the servos / swash would adjust a little and when I flipped out of throttle hold the swash and servos would adjust again.
Any help would be GREATLY appreciated.
3DLee Live Action
3DLee's Youtube Channel, Protos Max V2, TRex 500,550, 600, Blade 300,450,360CFX, MCPX-BL--I have flown it all.
3DLee is offline        Reply With Quote Quick reply to this message
Old 07-23-2016, 06:51 AM   #57 (permalink)
Subed
jimmitch is offline        Reply With Quote Quick reply to this message
Old 10-23-2019, 10:54 AM   #58 (permalink)
So I purchased a used Beastx and need to find out what software version it is. The manual says that the letter C during initialization means version four. It doesnít say why that is and Why the letter D isnít version 4 since itís the 4th letter in the alphabet.
TIA.
smaze17 is offline        Reply With Quote Quick reply to this message
Old 10-23-2019, 12:23 PM   #59 (permalink)
See your other thread for answer.
Regards, Sutty
BeltEXI, mCX, mSR, 4G3, FBL Trex250SE ĶB, FBL Trex450Pro ĶB,
sutty is offline        Reply With Quote Quick reply to this message
