Old 07-10-2013, 05:38 PM   #241 (permalink)
my two cents:
noticed on the bench that when moving the tail slowly and evenly the gyro doesn't seem too notice ( gp750 and spartan760) and thus the tailservo doesn't move
so for one i'll do the rate mode setup tomorrow (at 100% throttle) as best i can with the biggest possible tailblade size, guess this also why high headspeed which gives the tailblades more speed and so generates more thrust of the tailblades and gyroscopic effect helps the tail to stay neutral in hoover?
then i noticed that on my medium sloppy setups the tailblades do not hardly move when the tailservo ball is on 4.5mm and one moves the tail around neutral, the servohorn movement doesnot generate tailblade movement untill after so many degrees into the tail moving off neutral, maybe that's why the mks ds95i works so well as it is very fast and one can thus raise the gain evenmore which makes the gyro correction even stronger without causing a tailwag
so then it's mixing tailblade size/servoball length against slow tailservo/gyro deathband/gyro gain
wonder if a boom extension kit might not solve a lot of the tail wag issues?
EDIT:
mixed results, one with a ds8910 flies ok but tail not that there yet, my basher with tgy306 on tail needs
flies also ok but get wag during flight so will go with smaller tail blades
overall the headspeed is pretty important as my packs are tired it varies a lot and so does the tail behaviour...
apper001 is offline        Reply With Quote Quick reply to this message
Old 09-13-2013, 11:05 PM   #242 (permalink)
Default Finally cured the Wag
Been reading some of the comments on wag for the informass Tail wag issues with heli. My cure was simple removed the tail hub put it in a dremel removed the Shoulder that the blade grips bind on with a file fine,and slipped on a inner bearing off an old MSR main shaft i had lying around and spaced the blade grips with a alloy cover washer used a longer bolt for the blade grips no more binding ran it up with no main blades on easy as then flew it ,where i was running 35% gyro turned it up too 75% perfect Hope it helps some one else as you comments helped me Cheers .
tunner777 is offline        Reply With Quote Quick reply to this message
Old 09-13-2013, 11:15 PM   #243 (permalink)
Lynx 42mm TR removed my wag, even with 100% gyro gain
BladeScraper is offline        Reply With Quote Quick reply to this message
Old 09-14-2013, 05:25 PM   #244 (permalink)
Is it possible to show some pictures to clarify the modification ?
Nano CPx, Hirobo Quark
250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar
450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540
465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE
lcc014 is offline        Reply With Quote Quick reply to this message
Old 09-21-2013, 08:11 AM   #245 (permalink)
Default HK250 GT flies well
Yay! I balanced a troublesome HK250GT. I used spectral analysis (Audacity) to identify imbalances. see thread here: http://www.rcgroups.com/forums/showt...3#post26168424
Starting with the tail and running at half throttle I used Audacity to minimize the tail spike. Surprisingly the rotor head/flybar assembly needed a lot of balance weight. And then I spun it up with blades for the final tweaks. It came out smooth.
IT FLIES with no shakes. The tail holds well just like a good dbl bl mcpx. Now, if I can just speed up the slow handling. With TA at 150, DR at 125, expo at 0% and pitch curves maxed out, What else can I do to speed up the controls?
I now have two 250s to test fly along with my fleet of modded ultra micro Blades
I will try to put together screenshots and writing to document my efforts. I will do that later! It's getting light! And I gotta fly. There is a houseful of teenagers, too. I must come back with food or there will be trouble.
BTW, I have two small Chinese blade balancers for sale.
Good luck and happy landings.
daveapplemotors is online now        Reply With Quote Quick reply to this message
Old 09-21-2013, 11:41 AM   #246 (permalink)
Hey everyone again! I left the Trex sitting on a shelf for more than a year, really discouraged by the fact I couldn't solve the wag no matter what.
Last week I decided to upgrade my 450 to FBL and this allowed me to move the Spartan Quark I had on it to the 250. Needless to say the Quark was rock solid on the 450.
At the same time I changed the tail servo from the stock DS420 to a Turnigy S306G which is supposed to be a DS95i clone.
This morning, excited as never before, I went to the club and powered the 250 up. Guess what? Wag as before. I couldn't believe my eyes. I started lowering the gain, until I got to 4% real gain (I am using a DX8), but it only slowed down the wag.
So this is what I did, in the hope you see something dumb and help me out:
- changed the stock gp790 gyro for a spartan quark
- mounted the gyro with its metal plate between a thin foam layer and a thicker one
- changed the servo to a tgy s306G
- ball link is 4.5 mm from servo arm center (too close?)
- tail mechanism is pretty smooth, there is a tiny bit of slop but the 450 is the same and flew awesome
- vibes are not anyhing exceptional, the heli feels pretty smooth
- wags is slow at 4% gain HH, fast at 30% and crazy at 50%. It made for an interesting landing!
I am at a loss here, any idea?
Thanks heaps in advance!
Edit: I also changed the stock tail blades for KBDD 40mm.
Blade mSRX - Blade Nano S2 - Blade mCpx - XK K110 - Blade 150S - Blade 230S V2 - Blade 250cfx - Blade 400 - T-Rex 250 Pro DFC - T-Rex 450 PRO DFC - T-Rex 500 Pro DFC - T-Rex 550 DFC - A bunch of planks - Spektrum
gionir is offline        Reply With Quote Quick reply to this message
Old 09-21-2013, 12:20 PM   #247 (permalink)
Not to be flippant, but have you read the preceding 245 posts? Tons of ideas there.
The same amount of slop as a 450 on a bird a fraction of the size can be a problem.
Moving the ball link closer to the center is thought to help, so that shouldn't be a problem.
And of course, there's the old troubleshooter's rule about only changing one thing at a time...
Good luck! (You may need it--the 250 is a really fun little bird when it's flying well, but if it's in the mood to shake its butt, call the exorcist...)
Harbormaster is offline        Reply With Quote Quick reply to this message
Old 09-21-2013, 12:36 PM   #248 (permalink)
Hi harbormaster,
Thanks for the reply, yes I have read the previous pages, still I am a repetitive offender of the wag crime
My mistake, what I meant with the slop thing is that there is some but I wouldn't say that it is out of control, a degree or two of deflection of the blades.
And you are very right, next thing is to go back to the stock servo and see what happens..
If anyone else has ideas...I'll be very happy to hear them!
Cheers
Old 09-21-2013, 01:42 PM   #249 (permalink)
Going to the fastest tail servo around (a Ds95i) and Chinese weights pretty much did it for me (especially the servo--throwing lots of money at an intractable technical problem does sometimes make a difference! )
Old 09-21-2013, 07:04 PM   #250 (permalink)
haha I hear you, unfortunately I am not in the position to throw almost $100 in a servo...I'll have to try and solve this puzzle with what I have around..
But really what I cannot understand is why the tail wags even if the gain is as low as 4%, and still holds in pitch pumps. This sounds pretty wrong to me.
Old 09-21-2013, 08:31 PM   #251 (permalink)
My aeronautical engineer flying partner can go on at length about how that's all explained by control loop theory. The trick seems to be determining exactly which variable in the loop is out of whack. Me, I go with the theory that a little bird needs tighter tolerances, and that the 250 doesn't have them, so oscillations can start because of delays caused by slop. (And that super-fast servo can help to make up for that.) If you don't like that theory, there's always posts 1-250...
Old 09-22-2013, 01:49 AM   #252 (permalink)
You are most certainly right, I have read the posts before, I will do it again, especially post #1. I also like the idea of the loop theory, and I'll try and eliminate some slop from the tail first. Also I would like to extend the servo arm to 6mm because some Quark users report some success with that distance.
Still, I feel like I am searching for the classic needle in the haystack...
Old 09-22-2013, 10:53 AM   #253 (permalink)
What's REALLY frustrating is when you solve the wag and all is well (you think) and then it comes back.
Good luck!
Old 09-23-2013, 12:37 AM   #254 (permalink)
All wag in the 250 i've ever experienced/seen is due to the following:
Crap gyro - (which you don't have)
Crap tail servo - (I run the DS520/JR3500G servos)
Crap governor (or governor in general can do it if it's pulsing)
Bad tail grip bearings
'Sticking' in the tail assembly (grips, links, bell crank, etc).
Missing teeth in a belt.
Something in the teeth of the gear train that would add friction every rotation...
Basically, with the 250, everything must be extremely smooth. Ever since going to the 'mini' tail servos, I haven't had as many issues... still things here and there.
mCP X ||| mCP X BL ||| 130X ||| 250 FBL ||| 250 FBL #2 ||| 450 Sport V2 FBL ||| 450 Pro FBL ||| X5 ||| DX6i
Airman0386 is offline        Reply With Quote Quick reply to this message
Old 09-23-2013, 04:13 AM   #255 (permalink)
Your 250 must be tail heavy with 520/3500.
Even 306 is a clone of 95i, but sometimes, clone doesn't work as good as the original.
pinguin is offline        Reply With Quote Quick reply to this message
Old 09-25-2013, 03:08 PM   #256 (permalink)
Its not too bad actually. I dont even notice a difference in balance.
And, im not the only one that does it
Bert Kammerer - T-Rex 250 with Align GP-750 Gyro (4 min 44 sec)
Old 09-25-2013, 05:20 PM   #257 (permalink)
what is so different between this and the Gaui 200 tail? I never had these problems with my gaui 200 tail and I use a hyperion DS9 GMD servo.
I'm thinking of getting one of these and from what I read the mini size DS95i or clone variety is supposed to solve it, but if people still having problems even with that, I don't know if its worth bothering with.
robl is offline        Reply With Quote Quick reply to this message
Old 09-25-2013, 06:57 PM   #258 (permalink)
The 250's tail instability is a an ongoing mystery (as you can see by the length of this thread and the variety of posts). If you're happy with the Gaui, maybe just stay with that? (They do look like cool little birds.)
Old 09-25-2013, 07:19 PM   #259 (permalink)
It has its own issues,many of them, the tail just happens to not be one of them. But they are discontinued and the 250 has parts everyone.
Old 09-25-2013, 08:01 PM   #260 (permalink)
It has its own issues,many of them.
So do you think maybe small helis are just over all more demanding/less forgiving from an engineering perspective? You know--great big bird with a millimeter of slop in its linkage, no big deal; little tiny twitchy heli with a millimeter of slop in its linkage, major problem...
Just a guess, but I'll bet I'm right...
