Old 02-04-2012, 07:46 PM   #121 (permalink)
cmouton +1
In the case of a header (Hatori), I've torqued the header bolts, then heated with heat gun, and torqued again to "seat" the bolts. Good results with that approach. Consider however, we're talking about applying torque NOT gorilla power.
Paper gasket, optional, yet does ensure a good seal. Wet with a little fuel and apply as part of the header install above. Good Luck.
Haplo is offline        Reply With Quote Quick reply to this message
Old 02-10-2012, 02:23 PM   #122 (permalink)
Finless,
Could you do a video on tuning a 2 needle engine? I am only familiar with this type of engine and it would help out a great deal in understanding the process.
lucab617 is offline        Reply With Quote Quick reply to this message
Old 02-10-2012, 08:16 PM   #123 (permalink)
what does it mean when u do the climb out then at the top when u drop the throttle to come of the hi needle there is a couple seconds with no smoke ? im trying to tune a os55hz
geomecc is offline        Reply With Quote Quick reply to this message
Old 02-11-2012, 02:57 AM   #124 (permalink)
I'm having issue with the links. Anybody have issue with the links?
Hi my name is Jim and I am a Heliholic. Darn Heli-Crack Addiction!! lol
The heli virus has infected me and i hope that there is NO CURE!
rcjames is offline        Reply With Quote Quick reply to this message
Old 02-11-2012, 09:44 PM   #125 (permalink)
links are working for me
Patriot996 is offline        Reply With Quote Quick reply to this message
Old 02-25-2012, 11:24 AM   #126 (permalink)
If you're doing a full-throttle climb out, enough to get entirely on the HS needle, and the engine doesn't recover quickly and no smoke, when you go to mid-stick, then you're mid needle is too lean...if you're at least 1 3/4+ out on your mid needle, then you're too lean on the high.
HeliDirect.com Team Pilot/Rep
Align T-Rex 700LE FBL, OS 91HZ-R, Hatori SB-20, Beast X
Align T-Rex 600LE FBL, OS 55HZ, Beast X
Outrage Velocity 50N2 FBL, OS 55HZ, Beast X
memosteve is offline        Reply With Quote Quick reply to this message
Old 03-19-2012, 11:52 PM   #127 (permalink)
Just oredered a ys 120 and downloading video' now.
Should have more balls than my ys91sr.
Cheers
Blade
blade_900au is offline        Reply With Quote Quick reply to this message
Old 03-30-2012, 08:34 PM   #128 (permalink)
so could you do a tune on a redline engine bc it only has one nedle? i was jw how much of a difference it is from that to a 3 needle?
t-rex 600 n pro
added a new chopper to the fleet...
hk 450
razer t-rex is offline        Reply With Quote Quick reply to this message
Old 04-17-2012, 09:25 AM   #129 (permalink)
Tim and Bob:
Sorry if I missed it - I just skimmed this entire post again, and I didn't see it in the videos. Just to clarify, I assume you apply the hight temp Epoxy WITHOUT a gasket of any kind ? Correct ?
Gaui X7 mini Vbar,Trex 600N Full Vbar, Gaui X5 mini Vbar, Trex 600E 6S BeastX Night Ship, DX-18 radio.
Boeing Freak is offline        Reply With Quote Quick reply to this message
Old 04-18-2012, 05:11 AM   #130 (permalink)
That's correct. You can also use blue Loctite!
John
Old 04-18-2012, 06:42 AM   #131 (permalink)
Did you said it's okay using blue loctite as a gasket?
Old 04-18-2012, 09:35 AM   #132 (permalink)
Yep, sounds unlikely but used at least half dozen times and works well!
John
Old 04-18-2012, 08:47 PM   #133 (permalink)
Question OS 105 Heli Engine Question
Hopefully, this is an appropriate place to ask.
Anyway, my question is whether or not the new OS 105 Heli engines have the crankcase pressure takeoff nipple in the middle of the back cover like the 91 HZ's?
Thanks, and apologies if this is the wrong place for this question.
Cheers
jpooch00 is offline        Reply With Quote Quick reply to this message
Old 04-20-2012, 02:51 AM   #134 (permalink)
Hmm...... I rather not use anything.
Old 06-04-2012, 06:19 AM   #135 (permalink)
Default needle settings
Just out of interest, does anyone know what Tim arrived at with his needle settings? I know fuel and weather play a part but having been pretty finely tuned they may be a good guide (only) as what not to exceed with the 120 as far as being lean goes.
kmcevoy is offline        Reply With Quote Quick reply to this message
Old 06-10-2012, 05:18 PM   #136 (permalink)
thanks
my idle mix screw is centered mid needle is 2 turns and my high is 13/4 im using rotor rage 30% and os#8 plug it hovers and idles ok but it bogs a little in a full climb ( i use +-11 degrees pitch) when i come off full climb and bring throttle off the high needle to mid needle the smoke diappears for couple seconds i cant figure out why
Old 08-08-2012, 10:49 PM   #137 (permalink)
i know that tim jones recommended pc fahrenheit epoxy to seal up exhaust port. but man this stuff is hard to put on. also should i let it harden up a little before putting the exhaust pip back on and tighting down the bolts all the way?
joecass2 is offline        Reply With Quote Quick reply to this message
Old 08-23-2012, 10:51 AM   #138 (permalink)
Thanks for the vids!!! I love it. I hv a query though. I have an align 91hz, how do I restore the needles to factory defaults? Do I turn all needles CW until it doesnt turn anymore and start with 2.5 turns for high and 1.5 for low? I am seriously lost.
Heli-ADDICTION:
Xxtreme700, X7F and all Logos & 600esp (初恋)
Feeling of Hover at (28/12/2009) - PRICELESS!
feudallordcult is offline        Reply With Quote Quick reply to this message
Old 08-24-2012, 04:22 AM   #139 (permalink)
I found this but when I got to P31 it told me Adobe was out of memory and I am betting the manufacturer defaults are just past there.
http://heli.brixtonjunkies.com/wp-co...1HZ-Manual.pdf
Have a great day - John
"Do it to them before they do it to you" {Hill Street Blues}
When the blue light is flashing I am kidding. E&OE.
fourbie is offline        Reply With Quote Quick reply to this message
Old 08-31-2012, 03:32 AM   #140 (permalink)
Default Awesome videos
Thanks Tim for the Awesome videos!
scott90fzr is offline        Reply With Quote Quick reply to this message
