Old 04-22-2011, 05:58 AM   #21 (permalink)
Hi Rick, In most cases yes, however I can not confirm what side is which on the main case. I usually try to orientate my main receiver to get a clear signal path (clear air) to both wires on the main case, where ever possible. That said, if you look at the JR 1221, it only has one antenna on the main case, which I presume must be an active antenna. Sorry cant confirm this one for you re the main case. When I open the next one to do a repair for someone (usually new antenna wires), I'll take a look for us...
M.
Originally Posted by Rick Dizzle View Post
Wizza, Is that the same principle for the actual receiver too? You know the main unit not the satellite. Meaning that only the left wire picks up signal?
Regards, Mark R (#248)
TRex 700E V-Bar NEO, BLS251, DS8915's, HJive120, JLog, VControl Carbon
TDR 710 CYs, V-Bar NEO, MPH83s, Jive 120, JLog, R2 Buffer, VControl Carbon
Logo600SX 600 CYs, V-Bar NEO, 8715s, Jive120, JLog, R2 Buffer, VControl Carbon
Wizza is offline        Reply With Quote Quick reply to this message
Old 04-22-2011, 11:10 AM   #22 (permalink)
I remember reading that on the actual main receiver, both antenna wires are active.
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote Quick reply to this message
Old 04-22-2011, 04:44 PM   #23 (permalink)
Thanks guys!
Trex 500 ESP w/ KBDD Tail blades and paddles
Trex 600 Nitro DFC/ OS 55HZ limited edition
Phoenix 5.0 Sim, DX9
Rick Dizzle is offline        Reply With Quote Quick reply to this message
Old 04-23-2011, 03:06 AM   #24 (permalink)
Depends on which receiver, on spektrum systems their is 1 active antenna element per receiver. The other wire is connected to ground and is used for impedance matching. No rf is ever switched, signals are compared after they leave the receiver and the strongest is used.
What gets confusing is some spectrum receivers have a single receiver, others have two. The easiest way to check is to use a voltmeter and check continuity between the ground servo pin and each antenna stub. You will have no continuity on an active antennas (actual receivers).
All satellites are single receiver.
ping is offline        Reply With Quote Quick reply to this message
Old 04-23-2011, 01:14 PM   #25 (permalink)
Here is where i put mine, so far so good.
ID:	223738   Click image for larger version
DX8 | TREX 700E | BEASTX | CC80HV | 700MX | AR8000 | HW 15Amp UBEC |
DX8 | TREX 550E | BEASTX | 600MX | CCBEC PRO | 70G ESC | AR8000 |
HELIIMAGE Printed BOOM WRAPS & CUSTOM CANOPY NAME
XSTAR is offline        Reply With Quote Quick reply to this message
