Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > 330X
330X Discussion and support of the Gaui Hurricane 330X QuadCopter
Old 02-22-2011, 01:34 AM   #1 (permalink)
Default Gaui 330XS - ESC options
Hi All,
Pls help me by suggesting the best ESC for Gaui 330X-S. My stock ESC got burnt out... not sure why.. because I was using FY90Q for whcih only one ESC power was required.. hence for all the other 3, I had to disconnect the power.. now my FY90Q has a problem & hence back to GU-344. I tried connecting the Esc, but it burnt off.. so Ideally want an ESC that can work well with both GU-344 controller + FY90Q and also be able to support any ugrade interms of better motor & larger props.. Pls do advice.. Thanks in advance!!
mpnchar is offline        Reply With Quote Quick reply to this message
Old 02-22-2011, 09:05 AM   #2 (permalink)
Here are ones I know others have used - it is probably a good idea for all them to be the same - so I would order 5, so if one goes bad you have a backup.
http://hobbyking.com/hobbyking/store...idProduct=6456
If you ever plan on going with larger motors then this one might be useful (I think I ordered these):
http://www.hobbyking.com/hobbyking/s...idProduct=6457
Here is another one that would probably work:
http://www.rctimer.com/index.php?gOo...8&productname=
When you you connect the cables it is important to get those in the right orientation going into the 344.
mbsteed is offline        Reply With Quote Quick reply to this message
Old 02-27-2011, 08:35 AM   #3 (permalink)
Default ESC for Gaui..
Hi mbsteed,
Thanks somuch for the suggestions. I will go with the 18A one..
Old 09-11-2012, 02:28 AM   #4 (permalink)
Hi mpnchar,
I was just wondering which ESC's you ended up with in the end.
Also, how did you go about connecting them. Did you just cut the connectors off the old ones and solder them all to the new ones?
I'm about to replace mine and want to know what the best way to handle the connectors on the Gaui 330X-S.
Cheers.
benthomas is offline        Reply With Quote Quick reply to this message
