Old 01-09-2012, 10:15 PM   #361 (permalink)
Ok, I'm having a problem printing these. I right click "save image as" and then in Pepakura I do setting, texture setting and change to the one I saved. Then I hit print and it comes out all blurry when it prints. It is so blurry that I cant tell where to cut. I hit no when it asks to resize or whatever which is what I have read. I'm confused
fire3 is offline        Reply With Quote Quick reply to this message
Old 01-09-2012, 10:59 PM   #362 (permalink)
Right click on texture and click "Save target as". I think thats what it says. That should give you the full resolution when you open it up.
Thx Davy for more of those sweet designs!
X5-12s/Yep120/KDE600-530/FullSizeVbar/belt/550mm
180cfx-ServoSaverMod/TorqueTubeClutch/CarbonBlades, DX7se
My son Enzo - X5, 180cfx, DX7se
ccnada is offline        Reply With Quote Quick reply to this message
Old 01-10-2012, 05:34 PM   #363 (permalink)
I read the "save target as" in this thread somewhere. When I "right click" it doesnt give me that option. When I import the texture into pepakura it looks like it is zoomed in.
I am using Firefox if that makes a difference.
Thanks for the help!
Old 01-11-2012, 03:15 AM   #364 (permalink)
Fire3, click the image you want, it'll open up, click again and it should open in a new window full size, right click and select 'save picture as'. Upload saved image in Pepakura, job done!!
Blade QX, Align Trex 500, Gaui 550 Hurricane, HK600GT, 450 Quadcopter
I have a perfect record in helicopter flight......I've never left one up there!!!!!
Davy Crockett is offline        Reply With Quote Quick reply to this message
Old 01-11-2012, 03:53 AM   #365 (permalink)
Originally Posted by CyLLlKA View Post
to be continued...
Upload a file after checking
How do you print this style?
itsmillertime0 is offline        Reply With Quote Quick reply to this message
Old 01-11-2012, 04:15 AM   #366 (permalink)
Do you have to open them up in that program or can you print from windows picture viewer?
MSH, Cyclone
Way2evl is offline        Reply With Quote Quick reply to this message
Old 01-11-2012, 04:58 AM   #367 (permalink)
There are 2 images, 1 with the texture and screen is for Pepakura, the 1 with 2 canopy sides and triangular top can be opened and printed with Windows viewer, photoshop etc, the triangle shape should be about 78mm long when printed
Old 01-11-2012, 11:42 PM   #368 (permalink)
Thanks Davy! I think that will work, I cannot print here at work so I will try in tomorrow. It looks a lot better now in Pepakura. Now I have to download all of them again.
Old 01-12-2012, 12:06 PM   #369 (permalink)
Davy,
I got it to look much better, but when I attempt to print it it comes out like this.
That is 3 pages and thats all that comes out. Any ideas?
Old 01-12-2012, 01:17 PM   #370 (permalink)
Fire3, I guess you can see 2 canopy sides and top in pepakura?
Try file,export,bmp/jpg, save as a jpg and see if it opens ok in windows viewer
Old 01-12-2012, 01:53 PM   #371 (permalink)
This was very helpful to me. I am a linux guy so Pepakura is not optimal. I have been just trying to get the jpegs to work. If I open jpeg and print from Gimp, the scale is wrong. If I print from Firefox, scale is correct. Not sure what is up there, but my point is that now that I know what the proper dimension is for that one part, I can adjust scale in Gimp to get output I need. Not only that, but is seems the scale of jpegs that are being posed are not consistent. Thanks a bunch.
there are 10 kinds of people in the world. Those that understand binary numbers, and those that don't.
cgriffith is offline        Reply With Quote Quick reply to this message
Old 01-14-2012, 01:59 AM   #372 (permalink)
Well, I have even a bigger thanks to Raggedyman. In post #138 he attached some photoshop files that i had not used until today. I opened that in Gimp no problem. I was able to select different sections and do all kinds of cool stuff. At print out time, I had to scale the image though. This may be to same problem with Gimp I mentioned before. Just trying to work out the best scale to use. BIG
Old 01-14-2012, 08:13 AM   #373 (permalink)
Originally Posted by odiewan View Post
So, other than magic tape, what you folks using for glue?
I used to use glue sticks and pva, but that obviously gets a bit messy so now I use really sticky thin double sided tape which is fantastic and easy to use! Another trick I use to make these is, once I have cut out a piece, I put some of that clear sticky lamented plastic stuff over it which also works quite well in looks as well as strength.
montyZooma is offline        Reply With Quote Quick reply to this message
Old 01-15-2012, 01:59 PM   #374 (permalink)
Try to do it. I have not checked it.
I like to give this a try. How you open this file? It is a .pdo file?
Edited: Nevermind. I read you can use pepakura.
Duc S.
Talent in many, master at none.
duceduc is offline        Reply With Quote Quick reply to this message
Old 01-16-2012, 09:34 AM   #375 (permalink)
One for the Align supporters....
Name:	HF mTDR-Trex-yelloworange.jpeg
Old 01-16-2012, 04:20 PM   #376 (permalink)
Thanks Davy for all the posts.
Please post pdo file also.
Blade mCPX | TRex 550e | TRex 500DFC | DX8
Helix G700 17T, HC3sX, CY F270, GV1/SG, Century V2, Generator
FastRunner is offline        Reply With Quote Quick reply to this message
Old 01-16-2012, 07:27 PM   #377 (permalink)
OK, so I have been experimenting for a few weeks with the concept of using transparency sheets while making these. Inspiration came from 755_robert and tommy217xxx, so big thanks to them.
Much time has been spent finding just the right scale of image to get size of canopy I want. It turns out Gimp changes scale depending on what quality of printout I select. In the end, I go off the length of the long triangle side of center piece and distance from tip of nose to back fin on side pieces. ~72mm and ~132mm respectively.
Notes on paper and transparencies: I have tried both glossy and semi glossy photo as well as regular paper. Glossy is the best looking, but probably adds more weight. These were made with semi gloss only because I ran out of glossy. I know there are many types of transparency sheets. I went to Staples and saw packs of 100 for like $35. Ouch! In the end, I bought ten sheets from copy center for $.29 each. I wonder if they make one that will allow inkjet printing?
1) Print out your canopy.
2) Attach the transparency sheet to the photo using blue painters tape. Cut out each part seperately.
3) I used Contact Adhesive I had laying around. Spread thin even layer of adhesive on photo paper. Apply transparency later while pushing air boubles out and smoothing adhesive for an even layer. Notes: I found I had less boubles if I did parts of canopy seperately versus doing the whole sheet at once due to drying times. I experimented with different glues and this is the only one that held. However, I plan on trying the spray kind next as this tube is not easy to use.
4) Let dry for 12 hours.
5) Cut out the exact canopy parts. Clean surface if glue has gotton on it. Now is also a good time to make canopy mount holes. Notes: I think the bottom of canopy is not correct in template, so I kinda do my own thing there.
6) Using blue painters tape, tape the seems from outside. Notes: I tried several types of tapes, and this is the only one that does not leave glue residue. Also, I like how the pieces of tape can be re-used.
7) Apply Contact Adhesive on seems from inside of canopy. Let dry at least two hours. Notes: Again I am using contact adhesive because I like the strong yet flexible properties. If anyone has another suggestion, please let me know.
8) Assemble the halves along with center piece with tape. Glue inner seems. Let dry two hours.
9) Finish glueing bottom of canopy and apply more adhesive to corners that will see more action. Like the seems on back fins and near swash plate.
Again, I am sure there is room for improvement here. I would really like some imput on materials to try.
Enjoy!
ID:	281353   Click image for larger version
ID:	281354   Click image for larger version
ID:	281355   Click image for larger version
ID:	281356   Click image for larger version
ID:	281358   Click image for larger version
ID:	281359   Click image for larger version
ID:	281360   Click image for larger version
ID:	281361   Click image for larger version
Old 01-17-2012, 12:01 AM   #378 (permalink)
My first attempt.
Duc S.
Old 01-17-2012, 04:20 AM   #379 (permalink)
FastRunner
Align yellow arange PDO file
http://www.mediafire.com/?5r1hqx4kjhrnz51
Old 01-17-2012, 05:08 AM   #380 (permalink)
@ cgriffith... what type of glue did you use to sick your canopies together??
Tags
free, hop-up, mcpx, paper canopy, red camo
