Old 03-05-2012, 01:19 AM   #461 (permalink)
Originally Posted by Davy Crockett View Post
and 2 versions for the Ducati fans...
Davy, thanks very much for doing these!!
Any time available to do some Monster Ducati designs based on The Doctor's bike, or a Repsol Honda Stoner edition?
Many thanks to tutelarRC, CyLLIKA, Mark and Davy for all you've contributed, great work!
Cheers
HelisRock is online now        Reply With Quote Quick reply to this message
Old 03-05-2012, 05:23 AM   #462 (permalink)
Default Upcoming
No Ducati, but race inspired nonetheless.
dr dremel is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 03:55 AM   #463 (permalink)
That looks very clean !! Care to share it with us? Pretty please?
Covids is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 06:40 AM   #464 (permalink)
I got bored so I thought, pfft paper... need to use something more manly... like an aluminum pop can.... well the heart was in the right place but its kinda not so pretty:
I think using the aluminum in a popcan is a viable option but i need to find a better way of assembling it then hot glue... a mini spot welder would be a dream
Edwii is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 11:36 AM   #465 (permalink)
Originally Posted by caseyjholmes View Post
More canopeeeeeeeeeeeeeeeeeeeeeeeeeeees nom nom nom
Using laser printer and three times through the machine.
Super hi-vis
Where can I get the pattern / picture for this design.
it looks great!
pgleesonuk is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 12:35 PM   #466 (permalink)
it looks great!
look back on the first page
MikeMT is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 01:14 PM   #467 (permalink)
You mite want to check you still get a radio signal .
Try a 2ltr bottle of coke and use the plastic might be better.
SAB Goblin 700 750MX BeastX - Compass Warp 360 Scorpion HK2520-1360KV V-Bar?
T-Rex 700N LogicTech 6100 - T-Rex 600N FBL OS55 -T-Rex 550FLB Spartan VorTex
T-Rex 450L-6S V-Bar? ----- Blade 130x ---- McpX BL--- DJI Phantom FPV
TBS Discovery FPV
dna001 is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 01:29 PM   #468 (permalink)
Default Finished Product
Im still fiddling with the PDF file to make it easier to cut/glue, will upload when finished. Im also working on a template for the msrx to make a nano-tdr.
Thanks a lot to CyLLIKA, who solved my canopy problem.
Old 03-06-2012, 01:41 PM   #469 (permalink)
Great job on the canopy and the skids also!
profilefan is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 05:05 PM   #470 (permalink)
I considered the problem that it might interfer with the signal, and tho i haven't tested it, if i were to solder a wire to the frame and then attach it to the lil antenna on the bored, would that fix it.. if not improve it?
Havent tried bottles yet, but wouldnt it be very hard to get the curve out of them... maybe a hair blower would help iron it out...?
Old 03-07-2012, 04:58 AM   #471 (permalink)
Plastic bottles act a bit like heat-shrink, I have see plankers make cockpit canopy's out of them, But not tried my self.
TBS Discovery FPV
Old 03-07-2012, 02:45 PM   #472 (permalink)
Default PDF, Paper Recommendation
Here is the PDF file of my race canopy. I traced the original template in Photoshop and reworked some areas. Especially the upper middle part is longer to give the board a little more protection. Also when I look at photos from other canopies mine seems to fit a bit tighter when printed at 100%.
After experimenting I highly recommend using inkjet or laser glossy white film as print medium, which is a white- opaque plastic paper. It is very light, does not tear as fast as paper and gives brilliant prints. It is available where you can get printable transparency sheets for overhead projectors. The only drawback is that the surface is highly hygroscopic, meaning that fingerprints will stay. I solved this by applying one coat of acrylic clear paint (rattle can) to the dried prints before cutting.
Nose evolution
Old 03-09-2012, 12:05 PM   #473 (permalink)
Default another one
I really like to make these. Heres the bespoke scaled msrx version of the tdr canopy with some new design. I also made it in the original size and added small corrections to the way it is assembled. As somewhere in the middle of this thread suggested I did the belly in a separate piece, much easier to glue IMO.
Old 03-10-2012, 11:20 AM   #474 (permalink)
Are you by any chance a Williams Formula 1 fan???
yautja01 is offline        Reply With Quote Quick reply to this message
Old 03-11-2012, 05:59 AM   #475 (permalink)
Cheers
Got a few MotoGP designs I have recently done, working away but will post soon as I return
Blade QX, Align Trex 500, Gaui 550 Hurricane, HK600GT, 450 Quadcopter
I have a perfect record in helicopter flight......I've never left one up there!!!!!
Davy Crockett is offline        Reply With Quote Quick reply to this message
Old 03-11-2012, 10:19 AM   #476 (permalink)
what thickness paper are you guys using? reg paper way to thin right?
I have seen one in person and it looked so nice.
Goblin 500,XLP 550,OMP M2,600N,600E,lots of Planes Powered by NX10 AMA 34 yrs.
Old 03-11-2012, 11:49 AM   #477 (permalink)
Not necessarily a Williams fan, but I like the color scheme. Im not even watching F1 anymore, pretty boring. But these race designs fit the tdr canopy quite well. Here are another two I managed to get ready this weekend.
So heres the deal: The first who guesses all of the 4 original designs and their respective drivers can determine the next template Im doing.
I will do every race design except Gulf, because this has already been beaten to death.
Have fun
Dr Dremel
Old 03-11-2012, 04:23 PM   #478 (permalink)
Uhm,
Can they be the Williams driven by Prost and Hill, the Williams driven by Senna and Hill, the Lotus driven by Andretti and Mansell and finally the Renault driven by Alonso?
gionir is offline        Reply With Quote Quick reply to this message
Old 03-12-2012, 09:58 AM   #479 (permalink)
Can someone please make a template for a shark one to match my 400?
That would be awesome! Thanks in advance.
"How far is the range on that thing?"
Martinarcher64 is offline        Reply With Quote Quick reply to this message
Old 03-15-2012, 06:04 AM   #480 (permalink)
Default Close enough
Originally Posted by gionir View Post
Uhm,
Very good guesses, gionir!
As no one else posted Im looking forward to your suggestion. BTW: Im a huge fan of the Bathurst 1000, true racing.
Disclosure: Williams Renault no. 5 driven by Mansell; the "Rotorman" was intended to be a Rothmans Porsche (Bell/Stuck/Holbert), although similar design to the Rothmans Williams; JPS Lotus no. 12 driven by Senna; Benetton Renault by Alonso. Sorry for the nitpicking, cant help Im German.
Cheers
Dr Dremel
Tags
free, hop-up, mcpx, paper canopy, red camo
