Old 03-29-2011, 12:23 PM   #81 (permalink)
Yep, I assume as I am nearing 100 flights I'll probably have to replace the servos. I cleaned them and am still getting just a touch of shake on cyclic ...
ChrisH is offline        Reply With Quote Quick reply to this message
Old 03-29-2011, 07:44 PM   #82 (permalink)
Mine probably have 40 or 60 additional flights on them since the tear down, clean-up and adding contact cleaner/lubricant... no gltiches or failures after that one initial hiccup.
I'm down for a tail boom right now, but if I have any failure of the servos, I'll report back to the thread.
tracknoob is offline        Reply With Quote Quick reply to this message
Old 03-30-2011, 12:08 AM   #83 (permalink)
So what is a normal servo life?
I am guessing that these servos are seeing increased wear due to the FBL controller constantly making small corrections.
I wonder if those of us that spend our time hovering will see faster failures, since we don't move the servos as much as those who are doing 3d. The servo just sits there at 75%, making tiny moves back and forth. This may be something that was not really tested at HH, that is, hours upon hours of hovering, since those flyers were probably wringing it out doing stunts...
Perfect excuse for spending more time in the wind, where I have to do a lot more collective moves...
I sent HH an email asking if this kind of wear is considered normal.
Wayne Bengston
Gootch 450 Pro, Walkera 4G3 & 4G6
Blade 120 SR and mCP X
PZ Night Vapor, Ember and UM Mosquito. M-A-E Penguin
VaderSS is offline        Reply With Quote Quick reply to this message
Old 03-30-2011, 03:42 AM   #84 (permalink)
I think with a clean they should last a long time generally... to actually wear down the wipers and/or strip would take a long time.
Blade mCP X - Brushless, XP-7A, HP05S
Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i
Align AH-1 Cobra (T-Rex 500)
Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188
zeeflyboy is offline        Reply With Quote Quick reply to this message
Old 03-30-2011, 07:13 AM   #85 (permalink)
Blast. I just cleaned all three servos. The front two are fine. I'm not sure what I did, but after powering up I got the blue smoke of death from the rear servo: it's totally fried.
Trex 450 Pro V2 - Stock with BeastX
mCP X, Nano QX
Fuzzy Toaster is offline        Reply With Quote Quick reply to this message
Old 03-30-2011, 10:42 AM   #86 (permalink)
Originally Posted by 755 robert View Post
It seems maybe a conductive lubricant might be in order.
Yes!! There's something called DeOxit that does just this. It lubricates and is conductive. You can probably apply with a toothpick. It's available at Radioshack, but a bit pricey at around 14 dollars for a cleaner and lube package.
I have a conductive carbon based grease also, but I don't want to slow down the action of the linear servo or apply any more drag than necessary.
Thanks for this tip thread guys!
wkma7six is offline        Reply With Quote Quick reply to this message
Old 03-30-2011, 11:46 AM   #87 (permalink)
Contact cleaners and lubricants have been discussed earlier in the thread starting aroung post #15 I think.
I am currently using some stuff called "Tweek" that claims to be non-conductive except when it is in the microscopic voids within the contact space itself, and then and only then, it somehow conducts. However, this action is much different than material with actual conductive material in it, like carbon!
There is no way I would put fully conductive material into the servo, anywhere -- it will almost certainly short out, ruining the servo at a minimum and likely taking out your 3-in-1 as well.
I just read the product insert for De-oxit, and it claims to work just like Tweek, so while it may not be great stuff, at least it will likely not short out the servo:
DeoxIT® and DeoxIT® GOLD (ProGold) are designed to improve the flow of electricity between metal surfaces. These products are initially non-conductive... when subjected to an electrical field... promotes current flow. No short circuits will occur....resistance is high enough to prevent short circuits.
However, the carbon conductive grease might be a problem, IMHO:
Section 2: Hazardous Ingredients
CAS# Chemical Name Percentage by weight ACGIH TWA Osha Pel Osha Stel
1333-86-4 Carbon black 20-22 N/A N/A N/A
63148-62-9 Dimethylpolysiloxane 78-86 N/E N/E N/E
Electrical Resistivity 117 ohms^cm
I'd steer clear of this!
Old 03-30-2011, 04:00 PM   #88 (permalink)
Think I'll give the deoxit gold liquid a try. It comes in a small tube for $7. I'll try it on one of my bad servos first, and if it does not mess anything up, I'll put it on my new servos.
Wayne Bengston
Old 03-30-2011, 04:09 PM   #89 (permalink)
Looking forward to hearing the results. I haven't had problems yet but it sounds like it is almost inevitable so this will be good info. Thanks for being the guinea pig!
Always learning, and enjoying the process!
mejmea is offline        Reply With Quote Quick reply to this message
Old 03-30-2011, 06:52 PM   #90 (permalink)
Why do you say that? I'm not disagreeing, just curious. Are you worried about it shorting out the PCB, motor, etc? Or it interfering with the correct operation of the "wiper" and the potentiometer?
My understanding/assumption was that the resistive aspect of the potentiometer was done in the strips themselves, and was not really a function of the contact between the wiper and the strips. That is, improving the connection between the wiper and strips would not confuse the pot (and therefore the servo). Is that not correct? Or are you just worried about shorting out the motor, or something similar?
Old 03-30-2011, 07:07 PM   #91 (permalink)
I have not done any electronic and/or mechanical analysis of what the various failure modes could be, but suffice it to say that IMHO placing conductive material @ ~100 ohms/cm (made up of more than 20% carbon black) that is motile via suspension in grease, into an area with a moving contact arm whose function is to engage a graduated resistance strip whose job is to provide fine positional control to the rotor head of a helicopter spinning at 4,000 RPM, but where feedthroughs with missing conformal coating have been observed, strikes me as simply imprudent on the face of it, especially since any potential benefit you might gain from using the stuff is easily done better with a different material that is not inherently highly conductive. I haven't measured the actual impedance of the strips, but IMHO this stuff simply can't be doing any good in there. It is instead designed for application to switch contacts inside a sealed assy, or to the face of an already isolated circuit breaker tang, etc. to help what should already be a 'zero ohm' connection be close to that, and also ward off contact corrosion.
Old 03-30-2011, 08:53 PM   #92 (permalink)
Gotcha, thank you for the explanation. Interesting, as well as educational. Considering that the conductive stuff may well migrate with all the vibration, etc, and could touch any of the nearby items, I'm sure you're right, it would be a bad idea.
It does seem (from a beginner's perspective) that some sort of safe lubricant might be able to help extend the life of the strips on the servos. If they're lasting, say, 100 flights, that sounds good on the surface, but if people can churn through batteries like some have been, then $60 for a new set of servos is going to get fairly expensive. Hopefully we can help them last longer than that.
Old 03-30-2011, 08:59 PM   #93 (permalink)
Thank you so much Chris HH for the info, it took me half an hour to do all three servos and now it's as smooth as new again!
perlinauto is offline        Reply With Quote Quick reply to this message
Old 03-30-2011, 09:07 PM   #94 (permalink)
My MCPX #1 is running the 'Tweek' aka Stabilant 22 in all three servos. I placed it in there following the first tear down for cleaning due to a rear servo hang up, and so far so good since then, maybe 50 or 60 additional flights on the original servos.
If I did not already have a lifetime supply of that stuff for free (it doesn't take much) then if I ever took my servo apart for inspection/cleaning, I'd be inclined to use the Radio Shack spray clean/lube/enhancer which seems to work off the same principles -- it's an insulator at a distance, but at the microscopic level, it's a contact 'enhancer'.
Old 03-31-2011, 11:06 AM   #95 (permalink)
Tracknoob,
Thanks for the info on the carbon based grease. I've only used it in situations to prevent or minimize arcing of contacts and accelerated wear due to arcing of soft copper contacts. I'll use the deoxit stuff later when I am able to service the servos thoroughly. I'll keep in mind "non-conductive". That conductive stuff is suspended in a silicone based grease as I read on the product info.
Old 03-31-2011, 11:11 AM   #96 (permalink)
Tracknoob,
Old 04-01-2011, 05:54 PM   #97 (permalink)
Cleaned mine today and it works like new except BETTER!!! I did the grommet trick on swash and grip balls. Solid as a rock!!! Thanks guys for ALL the tips! Keep em coming.......
I love gyros!!! They're yummy!!!
rc247 is offline        Reply With Quote Quick reply to this message
Old 04-01-2011, 09:14 PM   #98 (permalink)
I also wiped down my contact strip on the aileron servos and affixed canopy grommets on the two front swash balls.
Smooth as butter.
uberbania is offline        Reply With Quote Quick reply to this message
Old 04-02-2011, 09:21 PM   #99 (permalink)
I had to do this today, my rear servo was hanging up. I pulled it apart and sure enough it was black. I cleaned it with a q-tip and 70% iso alc. When I put it all back together and put a battery in it, it started smoking and the rubber wire insulation on the servo began to melt. Can someone explain to me wtf happened?
JokazWild is offline        Reply With Quote Quick reply to this message
Old 04-02-2011, 11:04 PM   #100 (permalink)
It's very important that you DRY everything out and make sure nothing is binding when you put it back together. Also, the wires around the servo are very fragile so you have to be extremely careful when pulling the top servo mechanics off the board.
Sorry it happened but you are at your own discretion with this stuff !
