Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis
Thunder Tiger Electric Helis Mini Titan E325, Raptor E550 and E620 SE Helicopters
Old 03-01-2011, 03:57 PM   #741 (permalink)
Default My little Mini Titan
Here's my baby before she exploded yesterday. My friend told me it was because taking the pictures stole its soul. Maybe he's right ... Anyway, I'm proud of the way it looks (looked).
My setup:
  • Microbeast BeastX FBL system.
  • Hs-65MGs on cyclic.
  • Futaba S9257 on tail.
  • Scorpion 2221-8v2.
  • Scorpion Commander 55av2 ESC.
  • KBDD tail blades.
  • Cheapo CF main blades that I got because I liked the color.
  • TT/Sonix head converted to flybarless using whto's method.
  • Metal tail gear drive pulley.
  • Bunch of other aluminum/CF pieces added as I saw fit (I particularly liked the CF version of the stock tail fin).
  • And, just for B335, those are the MSH Gorilla Gear one piece landing skids.
-Jay
Major Equipment Sponsor - AdventureRC
Discount_Bob is offline        Reply With Quote Quick reply to this message
Old 03-01-2011, 05:04 PM   #742 (permalink)
Looks really nice. How bad was the damage?
Sent from my ZTE-BLADE using Tapatalk
Thunder Tiger Mini Titan E325 | Trex 250 | HBFP V1 with V2 frame with Tonic-X 4850kv MM | EFlite Blade MSR | Walkera 4/3B | Walkera CB100 | Gaui 425 to build | Gaui Mini Zoom
chipbutty is offline        Reply With Quote Quick reply to this message
Old 03-01-2011, 05:08 PM   #743 (permalink)
I was so frustrated I hardly even looked in-depth. Entire tail pitch slider assembly, main shaft, nearly every link on the head, pitch servo arm, antirotation bracket, battery tray (of course), canopy windshield, and not sure what else. I think it also hurt my pitch servo (even with metal gears). I was in a solid hover and she just made a loud sound and exploded 4 feet in the air. 3rd time in a row ... getting tired of it.
-Jay
Old 03-01-2011, 07:23 PM   #744 (permalink)
Really sorry to hear this Bob. We gotta get to the bottom of what's doing it. I've had hundreds of flights on mine with no issues (other than my dumb thumbs) and this exploding thing's just started happening. Just it's you it keeps happening to.
The last I read people were putting it down to Sonix shafts, but I thought you'd gone back to TT OEM ones.
It's got to be down to either what you're using, your setup, or something you're doing. That last bit I add lightly, as I used to read where people had this happen on spooldown, which turned out to be inadvertent rear cyclic input. As a result, I'm consciously "paws off" during spooldown now.
In any event, 4 times unlucky, I wouldn't blame you moving to a different heli.
B335 is offline        Reply With Quote Quick reply to this message
Old 03-01-2011, 09:14 PM   #745 (permalink)
It had something to do with the BeastX yesterday, I've decided, and maybe before that, too. It's happened 3 times to me, and I know for sure that the last two somehow caused or were caused by a serious vibration in the tail. I spooled it up in the driveway the day before and ran a whole pack through it on the ground with not even a hint of vibes, but at the field I got 'er in the air, noticed the tail vibrating after about 5 seconds, decided now would be a good time to hit T/H, and BOOM. Right before I hit T/H. The tail was vibrating so badly it looked like I had 2 tail rotors. My suspicion is that the incredible vibe on the tail caused the BeastX to go nuts, and it ... did ... something.
EDIT: Sorry to clutter up the pics thread with this ... I could put in a picture of the damage, but it would break my heart.
-Jay
Old 03-01-2011, 09:27 PM   #746 (permalink)
Hi Bob, I feel your pain . I have had 90 odd flights with my stock standad titan, and its never done anything like that. I had a trex 450s that had a bad habit of burning up esc's though. Sorry to hear. .jump back on the horse buddy. happy flying
steve2240 is offline        Reply With Quote Quick reply to this message
Old 03-01-2011, 09:44 PM   #747 (permalink)
Bob,
Sorry about your repeated incidents. It seems to make sense that vibe caused the beastx to act weired.
It happened to my MT after a rebuilt with new tail blades. I weighted the blades and they weight the same. But there was still vibe on the tail and causing the tail to wag when spooling up. It went away once it lifted off the ground. However, the wag returned when I was doing inverted FF during turns. So I dynamically balance the tail blades and it seemed to get rid of some of the vibes. Since then, I also replaced the main blade grip bearings and the main shaft bearings. They were all very worn out, especially the main shaft bearings. They will also cause vibe if they are bad, which in turn cause tail problem. I haven't got a chance to fly it but only hovering in my backyard after replacing the bearings due to weather. But I had several spooling up the bird without any tail wag. So it's looking quite promising.
May be you can check those bearing as well.
whto is offline        Reply With Quote Quick reply to this message
Old 03-02-2011, 12:08 AM   #748 (permalink)
I'll have to do that- thanks for the advice. I had only thought about checking the tail bearings.
-Jay
Old 04-06-2011, 07:51 PM   #749 (permalink)
Default Mini Titan E325 V2
This is my new V2 First Electric
ID:	220151   Click image for larger version
FultonFlyboy is offline        Reply With Quote Quick reply to this message
Old 04-07-2011, 04:27 AM   #750 (permalink)
Default mini Titan E325 SE
Finished 2 days ago and waiting for maiden flight.
shelved : Titan e325 SE flybarred | Titan X50 flybarred torque tube
Futaba 10C in mode 3
KouDy is offline        Reply With Quote Quick reply to this message
Old 04-07-2011, 05:41 AM   #751 (permalink)
What head is that?? Those grips look nice and beefy
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 04-07-2011, 12:38 PM   #752 (permalink)
looks like the stock SE (metal) grips to me.
Old 04-07-2011, 04:25 PM   #753 (permalink)
B335 is right. It's stock metal head from SE edition.
Old 04-07-2011, 05:48 PM   #754 (permalink)
Maybe my eyes are playing tricks on me, but are you running a Beast X and a flybar at the same time?
krefi is offline        Reply With Quote Quick reply to this message
Old 04-08-2011, 02:58 PM   #755 (permalink)
Your eyes don't trick you. You can put BeastX for tail onl. In the case you have BeastX, see manual point 3.6 .
In future i will eventually convert this to FBL so to have another gyro doesn't make too much sense...
Old 04-16-2011, 04:57 PM   #756 (permalink)
mini titan se v1
6S = 6'30 of smooth 3d at 2600 rpm with 900 mAh (out of a 1350 mAh pack) and full power all flight long ...
[ame]http://vimeo.com/22356814[/ame]
atom 6hv, logo600
nessie is offline        Reply With Quote Quick reply to this message
Old 05-09-2011, 02:24 PM   #757 (permalink)
Soon to be converted to FBL.
merg is offline        Reply With Quote Quick reply to this message
Old 05-09-2011, 02:25 PM   #758 (permalink)
Old 05-26-2011, 06:40 AM   #759 (permalink)
Default MY FBL Mini Titan
Love it!
Nick
Flying your heli the world is still out there, but at least for the time it hasn't got you by the throat.
Mini Titan E325 FBL, Blade Nano Cpx
nickyd is offline        Reply With Quote Quick reply to this message
Old 05-26-2011, 06:55 AM   #760 (permalink)
One of my Mini Titans in the Thunder Tiger AH-1W Cobra Fuse:
ID:	230009   Click image for larger version
ID:	230010   Click image for larger version
ID:	230011   Click image for larger version
Name:	cobras on call.jpg
ObiCanobi is offline        Reply With Quote Quick reply to this message
Tags
mini titan 325
