Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Old 05-02-2012, 02:15 PM   #21 (permalink)
generally I replace all fuel tubing every year or so......just because
I've had some of the tubing sitting submerged in fuel now for about 4 months. Its just sitting there, still flexible
now, to be fair, its lantern fuel. I don't run gasoline
Carey Shurley
Proprietor - Gas Powered Helicopters
carey shurley is offline        Reply With Quote Quick reply to this message
Old 05-02-2012, 06:02 PM   #22 (permalink)
Great thread!
Should be sticky-ed.
AL
Synergy E7se HC3-SX
Align T-Rex 550E HC3-SX
Futaba 14SGH
RealFlight 7.5
al_voisine is offline        Reply With Quote Quick reply to this message
Old 05-02-2012, 06:03 PM   #23 (permalink)
Thanks, Carey
Great Thread, should be sticky-ed!
Al
Synergy E7se HC3-SX
Futaba 14SGH
RealFlight 7.5
Old 05-02-2012, 09:15 PM   #24 (permalink)
I've been trying to take a different approach on this forum, rather than sticky stuff that I think is important, I keep the Index, which IS in the sticky section up to date
If the forum ever supports adding thumbnails to the topics, that will be a more clear way for folks too see what the topics are at a glance
Carey Shurley
Old 05-05-2012, 10:35 AM   #25 (permalink)
Are you still using the Zenoah line in the tank or is it Tygon now too?
ben_beyer is offline        Reply With Quote Quick reply to this message
Old 05-05-2012, 09:54 PM   #26 (permalink)
no I continue to use the black fuel line that comes with Zenoah motors.
Carey Shurley
Old 05-11-2012, 09:44 AM   #27 (permalink)
Default Great post
Thankyou for a great post with clear explanation - I will use this info on my helibug
blade77 is offline        Reply With Quote Quick reply to this message
Old 05-11-2012, 03:28 PM   #28 (permalink)
great! I'll admit the approach is more complex than it could be, but it works every time and takes one more thing out of the potential problem list
Carey Shurley
Old 08-30-2013, 11:18 AM   #29 (permalink)
Default Whiplash Fuel tank -- Make simple
Carey,
I am new to gasssrs and have just purchased a Whiplash. I have a question on fuel tank plumbing
I really like the simple setup in this post with
  1. Vent -- with tube coil top
  2. Fuel Inlet –feed line to the carb
  3. Fuel Return -- line from the carb with T
In your Whiplash build thread the instructions are a little bit different and there is a fourth outlet there for “Overflow”. I understand that the tanks can be plumbed in many different ways.
My question is, if I wanted to plumb my tank like this post, can I use the “Overflow” (on top of the tank) for vent and install my tube coil on it?
cbrkhan is offline        Reply With Quote Quick reply to this message
Old 08-30-2013, 08:43 PM   #30 (permalink)
yes absolutely
if you are using the coiled tube as a vent, attach it to the molded nipple on the top of the tank
then use the supplied fitting as the return line from the carb primer. Plumb in a "T" fitting with a removeable plug. Fill the tank using this
run the fuel pickup/inlet line directly to the carb with no fittings, filters or anything else just a directl line to the carb pickup.
this setup will work perfectly
the 4 connection approach is needed if you are using a one-way vent valve.
Old 03-13-2014, 12:12 PM   #31 (permalink)
Hi Carey,
Now that MA has unfortunately gone the way of the buggy whip, (very sad, by the way), is there anywhere else to source the fuel tank fittings?
I'm trying to complete my Trex 600 Helibug conversion project, and I would like to set up the fuel tank/lines your way....
Thanks for any ideas!
Franz in NJ
The Helifreak formerly known as Charliedontsurf
Goblin 500Mini Vbar DX8 TRex500 Ikon DX8 Warp360 Ikon/Brain DX8
Blade m350QX DX8 Blade mCPX BL DX8
Assistant to the assistant manure spreader at Middle Creek Stables, LLC
VonRecktofen is offline        Reply With Quote Quick reply to this message
Old 03-13-2014, 01:47 PM   #32 (permalink)
looks like Bergen RC has something
part #1852 which is about the same parts as I was using from MA
Carey Shurley
Old 03-18-2014, 02:10 PM   #33 (permalink)
Originally Posted by Charliedontsurf View Post
Hi Carey,
Tettra makes fuel fittings, they are commonly used by pattern/F3A pilots. You can get them from Central Hobbies.
http://www.centralhobbies.com/Fuel/fittings.htm
MA Whiplash Gas v2, HelixHeli T700 Gas conversion, T450 Sport FBL
jharkin is offline        Reply With Quote Quick reply to this message
Old 03-19-2014, 10:40 AM   #34 (permalink)
Thanks Carey and jharkin!
Franz in NJ
Old 03-26-2014, 02:30 AM   #35 (permalink)
Thanks Carey, I'm using your scheme in my T-Rex 600 and works great!!!!
Actually thanks to you and the gasser guys around here that I was able to fly this bird!!
Don't do like me. Do not live in a s*hole
Calil is offline        Reply With Quote Quick reply to this message
Old 06-16-2015, 10:19 AM   #36 (permalink)
Default where do you get????yhard to find
90 degree inlet - Miniature Aircraft part #MA0410-90
cruzroy is offline        Reply With Quote Quick reply to this message
Old 06-16-2015, 02:27 PM   #37 (permalink)
I also offer a complete plumbing kit - Gas fuel plumbing parts
Old 06-28-2015, 01:23 PM   #38 (permalink)
Many thanks for a great thread.
Have a great day - John
"Do it to them before they do it to you" {Hill Street Blues}
When the blue light is flashing I am kidding. E&OE.
fourbie is offline        Reply With Quote Quick reply to this message
Old 07-15-2015, 09:17 AM   #39 (permalink)
Default ok big question
90 degree fuel fittings.....where to get now....cant find
Old 07-15-2015, 02:47 PM   #40 (permalink)
I am told MA will eventually make them again, you might want to touch base with Ron Lund
Carey Shurley
