Old 04-17-2011, 10:39 AM   #21 (permalink)
Team Taco VP
Originally Posted by Jskrapper View Post
If it works for Bob, it must work for all. Good writeup.
I wish I knew who came up with the o-ring mod, I would buy him a :
Me too!
Will the guy that came up with the idea please come forward
Bob
Old 04-17-2011, 01:21 PM   #22 (permalink)
Originally Posted by Finless View Post
Me too!
Bob
I did a Google search and believe it came from a member at RCGroups.
To me, this forum is about the love of flying R/C helicopters. It is about the sharing of information and, on a good day, some humor. It is not about post count, brand of heli, or any other superfluous labels that lend themselves to a false sense of superiority. Respect one another, Try to pass on accurate information. Fly safe.
AverageJoe is offline        Reply With Quote Quick reply to this message
Old 04-17-2011, 06:25 PM   #23 (permalink)
Maybe make a post over there to tell them a cool brewski is awaiting!
ahahn is offline        Reply With Quote Quick reply to this message
Old 04-18-2011, 10:49 AM   #24 (permalink)
Team Taco VP
Update after another Sunday of flying this thing almost non-stop. In fact this is the only heli I flew all Sunday. Was working on inverted piro circles and making great progress.
As I posted in the first post I went to a solid CF boom. People pointed out that doing this can now break your frame. I crashed bunches of times and well, I did not break the frame but did crash right on the tail hard and it did bend the plastic back end area off center a bit. It was easily straightened out. But I could see crashing just the right way hard onto the tail and breaking the frame. So I can see that it is possible to break the frame with a solid rod.. However, I am still sticking with the CF rod though.
OK so I noticed that while doing a forward flight roll into inverted forward flight the heli wanted to break into a hover and I had to pull back elevator once I got inverted to stay in forward flight. Clearly this is a CG issue. So I broke the tabs off the pack and moved the pack all the way forward in the landing gear pack holder. WOW... made a big difference.
This little heli is very sensative to even small changes in weight distribution. The CF rod absolutly changed the CG enough that the heli was effected.
Just some more stuff I learned this weekend
Bob
Old 04-18-2011, 02:33 PM   #25 (permalink)
...<SNIP>
Bob
Right on Bob! The CoG is a MAJOR factor in the performance department with this heli... I have been experimenting with this alternate battery location for just that reason; you would be surprised at the difference it makes with respect to rolls and flips. This raises the center of mass by roughly 15% (rough estimate) but can only be done if the boom has been extended; otherwise it brings the CoG too far forward.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is online now        Reply With Quote Quick reply to this message
Old 04-18-2011, 09:43 PM   #26 (permalink)
Me too!
Bob
Yes, it came from RCG, but definitely not from that sviking guy.
Here is the first post where it appeared, in which it's actual origin is accredited to a German heli forum.
So if anyone's buying a beer, it should be a Warsteiner...
Sent from my Telegraph using Morse Code
antmeeks is offline        Reply With Quote Quick reply to this message
Old 04-21-2011, 03:18 AM   #27 (permalink)
Just thought id put some info in here myself being a newbee.. For the servo jitters instead ov taking them apart i just blew em out with 155Lbs ov air with my aircompressore and workd greate.. also lengthend my boom by 1 inch and big diffrence.. the srock battery looses power after 2 minuts and the hyperion 240 didnt do much better.. Stuch a thunderpower 325 45C and wow she came to life with no weight isues.. now i get 8 minut flights with 6 minuts full power.. U could probably use a 400mah if they make one .. But for now its thunderpower for me all the way.. Also got a 325 65C on the way doubt it will make much difrence but will let u all know.. I also use deans micro connectors and can tell a big diffrence in power and performance too.
archibald38555 is offline        Reply With Quote Quick reply to this message
Old 04-23-2011, 05:27 PM   #28 (permalink)
If anyone still flies with tail fin, take it off now. I've flown in 10 mph wind and no blow outs in backwards flying at all!
Great tip!
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote Quick reply to this message
Old 04-23-2011, 09:48 PM   #29 (permalink)
I just added the extended tail boom and WOW, what a differance. Flips are a piece of cake now!! Can't belive I waited soooo long to do this mod. "Im finless as well on this little hopped up bumble bee" works great!
Blade MCP-X Brushless, 300CFX, , Trex 450 Pro v2, Trex 600 ESP 6s 3GX v.3.1 and KDE head, Trex 700 Nitro, E-Conversion, Futaba 12Z controle!!
Stevendavis is offline        Reply With Quote Quick reply to this message
Old 04-25-2011, 08:30 PM   #30 (permalink)
Canopy pins. Would love to see Horizon change this design. Buying a frame for broken canopy pins is a pain. However I broke a front canopy pin. For now I just epoxied it back on using some micro balloons in the epoxy mix to strengthen the build up around the break. I know it's going to break off easy at some point but good enough till then.
Enjoy,
Bob
Thanks for collecting all of this in one place Bob.
Here's a suggestion for fixing canopy pins. I've done this going back to my mSR and it seems to work pretty well.
1) Get a straight pin, grab it with a small pair of pliers, heat it in the flame on your stove, and use it to make a hole about 1/4" deep in the end of the canopy pin. Push it in and then remove it several times if you have to. Be careful not to get it too hot or it will melt the entire pin rather than just making a hole. See the 1st and 2nd photos. It's hard to see the hole in the 2nd but it's there (I got it a little too hot but it still worked).
2) Heat the pin again and this time make the mating hole in the frame. When you get it deep enough leave it in this time and let the plastic solidify around it. (3rd and 4th photos)
3) Clip the pin to the appropriate length to match the hole you previously made in the end of the canopy pin. (5th picture)
4) Get out your epoxy and glue the canopy pin over the straight pin as well as making a little bit of a "cast" around it. (6th picture)
It takes a bit of a steady hand but it's not hard to do if you are patient. I expect that the pin should give it a bit more structural strength than epoxy alone.
ID:	224315   Click image for larger version
ID:	224316   Click image for larger version
ID:	224317   Click image for larger version
ID:	224318   Click image for larger version
Always learning, and enjoying the process!
mejmea is offline        Reply With Quote Quick reply to this message
Old 05-03-2011, 02:18 PM   #31 (permalink)
Talking
Found that if you dont push the canopy pins all the way through the grommets when you attach the canopy, they are much less likely to break off in a crash.
Warning this hobby is very addictive and may damage your wealth.
Pigs dont fly is offline        Reply With Quote Quick reply to this message
Old 05-04-2011, 07:17 AM   #32 (permalink)
Great write up. Lots of good info here as usual
"If you must choose between two evils....choose the one you haven't done before"
Darkkaos is offline        Reply With Quote Quick reply to this message
Old 05-06-2011, 08:39 AM   #33 (permalink)
maybe use with the stock boom could just cut a lil off the battery plastic thing to make it fly better?
Oxy 4AR7200BX,Torrent 110,Theroy XL,27% bipe,lots of E-planes Powered by iX12 AMA 30 yrs.
Old 05-06-2011, 09:58 AM   #34 (permalink)
Huh?
AMA# 977012
Old 05-06-2011, 11:28 AM   #35 (permalink)
Originally Posted by Vicovaludemero View Post
Huh?
I think perhaps the question relates to Finless' post #24 where he found that taking the tabs off of the sides of the stock batteries so they can slide further forward helped compensate for a slight rearward CG shift that occurs with the extended/solid CF tailboom.
My experience is that the overall set-up is slightly nose heavy to begin with. If I pull the main gear down to disengage it from the pinion so the head/shaft can freewheel, install a battery, and then hold the heli on its side (main shaft horizontal) by the head, the nose tips down on mine (even with the extended tail boom). Thus I'm not sure I'd want to shift it further forward, particularly with the stock tailboom. Having said that, I'm not a skilled enough pilot that I'm doing the types of things Finless talked about and so I can't comment on whether mine seamlessly transitions from forward flight to forward inverted flight without excessive elevator stick correction! Someday......
Old 05-06-2011, 02:24 PM   #36 (permalink)
Maybe... but that sentance makes absoluteley no sence, at least not on this side of the hudson anyway.
You are right about it being nose heavy... even with the extended boom. However, for aerobatic flight I have found that a slightly forward CoG is actually beneficial, thatís probably why itís like that in the first place. On the other hand, for slow precise flight a balanced bird is a must, and works much better than it does with a forward bias.
AMA# 977012
Old 05-06-2011, 02:52 PM   #37 (permalink)
Being relatively new to this all, that's new information for me. Thanks! Is there any rule-of-thumb for how far forward (percent of overall length in front of the main shaft or some such thing) or is it pretty much a personal preference?
Old 05-06-2011, 03:22 PM   #38 (permalink)
Just experiment till you find your sweet spot... and also keep in mind I said aerobatics, not 3D... for backwards or sideways flight a more balanced CoG is optimal. But the mCP X isnít really a "3D" heli, I know it all depends on ones definition of 3D, but nobody is doing Piro toc tocs with this thing so...
Personally, when I fly outdoors with a bit of wind I get that battery as far forward as I can, for indoors or calm conditions I keep it close to neutral with a bit of nose bias. I only make it truly balanced for precision slow flight. Also, itís nearly impossible to get it perfect with this little heli so donít go crazy over it but donít be afraid to play around with battery position.
Here is a fun little experiment and interesting piece of info... because of the 3 axis gyro, a nose heavy bird will want to drift backward more, thatís the gyro overcompensating... Perfectly balanced it will almost hands-off hover.
AMA# 977012
Old 05-12-2011, 09:31 PM   #39 (permalink)
Bob, you still flying this thing or have you moved on?
Just curious, I love mine, but worry it will wear out soon
janol is offline        Reply With Quote Quick reply to this message
Old 05-13-2011, 10:45 AM   #40 (permalink)
I have noticed that an even slightly rearward CG make this heli difficult to hover. I think the FBL system gets a little confused with a rearward CG.
Somethings burning
Gardner is offline        Reply With Quote Quick reply to this message
