Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 06-18-2011, 08:06 AM   #41 (permalink)
@DeviousLemur and @liftbag
you might try another type of wiring, which I ran succesfully with EA-048 and HeliMax Novus BL-conversion-kit (Heli-Max ESC - should be same as the Walkera ESC - plus 11000kv BL, sama as Walkera 11000 BL).
Please do consider: my tests so far just contain the pure electrics plugged/soldered onto mCPX''s 3in1 - have not flown that configurationl, for the motor still needs to be implanted into the frame!
Here is my wiring configuration:
  1. connect EA-048 to main motor's out on 3in1 (red wire to the side where the green mark ist on the 3in1 main's plus)
    Note: EA-048 contains two pralleled 2,2K resistors, so no need to get an extra one and direct connection to main-motor plug possible, when correclty connected
  2. only connect the signal-wire from EA-048 to ESC ( (white)!
    Just leave black and red wires unconnected as well on EA-048 as well as on the ESC (the converter's LED will not glow, but EA-048 still is operable)
  3. connect the ESC's main power leads paralleled to stock battery connector (eiiher via 2nd plug or just soldered on 3in1)
Result on my mCPX (with EA-048, HM ESC and HM BL 11000KV):
  • smooth start at about 5-6% throttle
  • full throttle-range from almost no spin to full speed
  • softstart, when started with more the 55% throttle (like stock motor)
  • no need to reverse throttle in TX
Flying tests will be done over next week, if hopefully my 9th pinions (BP doesn't sell to Germany ) arrive.
HTH
Uli
[EDIT]
did a quick test w 12T pinion and attachted pic and video
MCP X Brushless w EA-048 HeliMax ESC and 11000kv (0 min 28 sec)
Name:	#MCPX 1 HM P1020264s.jpg
TRex 600GF VBar5.3-Blade 400-130x-mCPX BL- nCPX BL-UMX Yak54 -pQX-nQX-350QX2-200QX
TX: DX18 1.07
everyone's choice: either participating in solving a problem or beeing part of it
UliZ is offline        Reply With Quote Quick reply to this message
Old 06-20-2011, 08:46 PM   #42 (permalink)
Hey guys,
I've been out of the whole MCPX thing due to a recent 700E deal I got. The EA converter is a okay converter, but not the best. The initial thread was to point out that a brushless MCPX was possible if we put some thought into it. I took the step into creating a guide on what does what and where to help others with more knowledge expand on creating a flawless brushless setup for the MCPX. Since there are so many types of brushless motors to esc combos as well as converters, its impossible for my budget to carry on with the task of testing each and every one of them. I apologize if there were questions left unanswered, and would be awesome of Bob can get another member to create a brushless guide with a set of better suited electronics to modify the initial post.
ALIGN TREX 250SE 450SE V2 500ESP 550E 600ESP 700E
NOVUS CP
BLADE MSR BLADE SR 120 BLADE SR
so-fly is offline        Reply With Quote Quick reply to this message
Old 07-10-2011, 01:34 AM   #43 (permalink)
Default The ultimate mCP X brushless motor
After trying all motors currently in use, Novus CP, C05M, ADH50 and C05XL, I think I can say that the best motor for the mCP X is the Oversky HP05S.
I have discussed here.
liftbag is offline        Reply With Quote Quick reply to this message
Old 07-26-2011, 01:24 PM   #44 (permalink)
ive spent most of my time on the 'other forum'. this one kinda kicks the crap out of it. at least as far as the mcpx is concerned, and most other topics from the looks of it.
thanks guys!
BIGBEN1165 is offline        Reply With Quote Quick reply to this message
Old 07-27-2011, 08:14 AM   #45 (permalink)
Default Still looking for pinions
Im looking for a source of 9t pinions still. I saw mattbockman.com had them but he is now sold out. I'd rather not order from Europe. Great work on conversions everybody, I'm really
looking forward to trying this once I track down the pinion.
TheMaxx is offline        Reply With Quote Quick reply to this message
Old 07-28-2011, 01:16 AM   #46 (permalink)
I got mine here - http://www.radicalrc.com/search/GW/GM09T3.
3 of them shipped to Europe were still cheaper than one from Germany
Tom
RCHN#233 | Lynx Heli Innovations Team
Goblin 700
Carbon |
Protos Max | Goblin 570
baui2000 is offline        Reply With Quote Quick reply to this message
Old 08-06-2011, 03:28 AM   #47 (permalink)
I have mine connected up this way and it works , red is going to the resistor on the back of the board
SAB Goblin 700 750MX BeastX - Compass Warp 360 Scorpion HK2520-1360KV V-Bar?
T-Rex 700N LogicTech 6100 - T-Rex 600N FBL OS55 -T-Rex 550FLB Spartan VorTex
T-Rex 450L-6S V-Bar? ----- Blade 130x ---- McpX BL--- DJI Phantom FPV
TBS Discovery FPV
dna001 is offline        Reply With Quote Quick reply to this message
Old 08-12-2011, 12:36 AM   #48 (permalink)
@ so-fly: I cant make any sense of that diagram (single lipo), why do the motor wires from the esc go to the main board and converter? There is no motor in that diagram, where does it go?
JAM3X is offline        Reply With Quote Quick reply to this message
Old 08-12-2011, 01:24 AM   #49 (permalink)
Yes it is a bit confusing as there are no motor wires shown in the picture
If you wire it up as in the picture you will have 3 wires left, guess were they go, ,, Motor
TBS Discovery FPV
Old 08-12-2011, 01:32 AM   #50 (permalink)
Actually just looking at so-fly diagram in the first picture its Wrong He has the ESC servo output wires feeding back to the + and - on the board.
The ESC gets its power from the battery and puts out 3 to 5 volts through the servo wire, he is feeding this voltage back to the and main board ?? this will only work if the ESC can suply enough voltage to the run the main board and all motors and servos. its probably can but it would be better to run the main board off of the battery.
Some one correct me if i am wrong :-/
TBS Discovery FPV
Old 08-12-2011, 07:36 AM   #51 (permalink)
It can work, but in the earlier stages of testing, the board/servos/BL drained too much power requiring a larger battery/discharge rate to function properly. The best combo so far would be the steve converter to save weight and have the proper power to weight ratio. The setup I went through did however push the headspeeds to nearly triple what it was stock and didnt even bog one bit
NOVUS CP
Old 08-12-2011, 09:34 AM   #52 (permalink)
Triple the head speed wow that's a lot, lets say standard is about 4000 so 4000*3 =12000 no way lol. :-)
I was using the same Brushed to Brush-less Signal Converter but now use the STEVEs,
I Did not notice much of a difference between the two.
TBS Discovery FPV
Old 08-12-2011, 12:46 PM   #53 (permalink)
Havent you seen the video?
[ame]http://www.youtube.com/watch?v=-3BPL2zo7Os[/ame]
NOVUS CP
Old 08-18-2011, 08:47 PM   #54 (permalink)
Hey gang,
OK its probably on here somewhere....but I am old and blind... but I have busted my tail boom into two...thrown it out in the garbage, went and bought new carbon rod. I am going to do the tail boom mod by adding 1 1/4" to the stock length.... heres my bone headed dilemma... I dont have a stock boom to measure to see what I am adding the inch and a quarter too...
...any one know what the stock tail boom length is???
Thanks...
Tony
hayamissle is offline        Reply With Quote Quick reply to this message
Old 08-19-2011, 02:47 AM   #55 (permalink)
Hi Tony,
I don't have the exact stock length either but I made my extended 150mm from end to end, worked perfect on brushed setup. Stock must have been 125 - 130 mm
Good luck
Ben
Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251
DX8, RF6
HeliBenj is offline        Reply With Quote Quick reply to this message
Old 08-19-2011, 06:32 AM   #56 (permalink)
Thanks very much Ben... I could have measured one at the hobby store, but they were all out of tail booms.
Cheers,
Tony
Old 08-21-2011, 12:20 PM   #57 (permalink)
Stock is 125, I just found an old one in my tool box,
And now for some thing completely different, when is some one going to go nitro with the mcpx, some one has done it on the Trex 250. :-P
[ame]http://www.youtube.com/watch?v=3QG739pD5pc[/ame]
Anyway at lease lets see if some bright spark can get twin main motors in the mcpx , would be cool :-)
TBS Discovery FPV
Old 08-26-2011, 07:15 PM   #58 (permalink)
Originally Posted by so-fly View Post
If you file the main output shaft the stock pinion will fit and you will not have to extend the motor mount slots. As for the tail you will have to flip the wire that plugs into either the main board or the motor. The sr colors are a bit different
@ so fly- how did you get off the stock novus pinion? If I understand, you took it off of the novus can and filed down its main shaft to a smaller diameter so you could fit the stock mcpx pinion on the novus motor shaft? how did you file it, and how hard did you press the mcpx pinion on? this step seeps critical to me and help would be much apreciated
Old 08-30-2011, 05:03 AM   #59 (permalink)
I just finished my second brushless conversion, this time I stayed with the stock frame.
The first time around was nerve wracking, experimental process in which I made many mistakes, was lucky not to destroy a main board and took about two weeks to get it right.
This time I had a fairly good idea what order to do things and everything fell into place with the whole process only taking about 2.5 hours to produce a flight tested bird.
Lunar is offline        Reply With Quote Quick reply to this message
Old 10-19-2011, 08:44 AM   #60 (permalink)
Default 2 Pack Special ;p
Why would you isolate the 2 Battery packs? It seems like a parallel connection or 2s with a lower potential amperage output, to avoid burning up the esc and 3in one, would be more suitable given the setup. Also I have found that the SR tail motor pulls a lot more amps than dual stock or mcpx tail motors. Probably because the Sr tail motor never reaches a high enough RPM to be efficient. Perhaps running a smaller tail rotor with the SR tail motor would produce a lower amperage draw? Another thing I would like to point out is that I have had much better throttle curve, flight time, and overall response by tapping the signal from the resistor just under the fet on the back of the main board. I will post scope graph when I get home and shoe you the difference. Plus you are not running a resistor on one speed controller to get the voltage down just to pass it to another ESC. Just a few thoughts.
**Bad Erse little Copter like your work!
probertsc is offline        Reply With Quote Quick reply to this message
